TPS65910: TPS65910A31A1 Power up issue
Part Number: TPS65910
Other Parts Discussed in Thread: AM3358
Hello everyone,
I have a question about TPS65910A31A1 power-up.
I have designed the PMIC schematic.
Then, When I test; I could not get the right values of the PMIC outputs.
When I research, I see the https://www.ti.com/lit/ug/swcu093f/swcu093f.pdf?ts=1635192633193
I read the this section and I have re-designed for PWRON pin.
When I push the button one time, PMIC works fine only 1 (one) second.
When I press this button for 7 seconds, It do not work. It turn-off.
I could not find the solution.
How can I the power-up this PMIC (TPS65910A31A1)?
Thank you.
Mert
