Dear team,
At datasheet of TPS62410, If the customer use EasyScale One-Pin Serial Interface for Dynamic Output Voltage Adjustment, Vout1 output is up to 1.575, Vout2 output is up to 3.3V. is it right?
Is there other solution having up to 5V output range? Needed voltage step is 0.1V. I2C , serial interface or PWM control would be OK.
Please let me know your opinion regarding having up to 5V output range for Dynamic Output Voltage Adjustment.
Thank you.
