LM74502-Q1: Shoule we add a 10k resistor between G-S?
Part Number: LM74502-Q1
hello,
      For LM74502-Q1, is there internal pulldown between Gate-Source to avoid false turn ON of the FET?I can't find any information about this issue from the datasheet
     Shoule we add a 10k resistor between G-S of the MOS?
  • Hi Zhang,
    We should not add 10k resistor between G-S of the MOS as it will lead to failed turn-on due to limited source current of the GATE. The internal gate drive has pull-down to avoid false turn-ON.
    Rakesh
