Hi,team:
It is not necessary to supply power to the system.
Can the circuit supplying power to the system be deleted directly?
Will the deletion affect the charging circuit
Hi,team:
Hi, Guoqing,
PowerPath is a feature to enable the customer using either the adapter or the battery as the power source. You can remove this portion of circuitry if not needed. This portion of circuitry does not help the charge function, I don't see any side effect without them.
Tiger
