Hi
I have an issue with the BQ40Z50 where it is switching off the discharge FET under loads of around 15 amps and therefore disconnecting from the battery, I have set my OCD1 and 2 thresholds much higher and also have set the AOLD threshold hardware protection threshold higher, but the issue persists.
Is there anything else configuration wise that needs to be looked at to prevent this sort of issue.
Ian
