For the Part REF102, we have ordered and received samples. Attached top marking of the IC we received. But, it doesn’t give clarity about the grade of the IC as shown in the below snip:
Kindly clarify on this.
Hello.
Device marking are in the datasheet and can be verified online at: Packaging Part Marking Lookup | Texas Instruments (ti.com)
But the part we received does not specify A,B OR C. Instead it is given as K. Can you pls explain on this?
Do you mind opening a case here as we may need additional information not covered in this forum: https://ticsc.service-now.com/csm/
Thank you.
