Hello team,
I have two questions on TPS7B81-Q1 EN pin specification.
1. Are there any cases that current may flow from EN pin?(i.e. minus surge test)
2. Is there any pull-down resistor inside EN pin?
Thank you,
Muwei Zheng
Hello team,
Thank you,
Muwei Zheng
I am looking into this, I will get back to you within two business days. Thanks!
Srikanth
Hello Muwei,
If operated within recommended conditions, there is no pull-down resistor at the EN pin and the current flow should only be around 10nA. Thanks!
Srikanth
