Other Parts Discussed in Thread: TPS7A30
Is there an eval kit for the for the TPS7A3401 (I believe the TPS7A3401EVM-042 is obsolete)? Also, would it be possible to obtain an unencrypted model for the TPS7A3401 negative regulator?
Adam
Adam
Hi Adam,
I would use this EVM here it is for the TPS7A30, which has a very similar pinout. Typically for negative LDOs we recommend the use of TPS7A30 as you get the NR/SS pin included.
https://www.ti.com/tool/TPS7A30-49EVM-567
I am working on getting access to the site with our encrypted models, but will have to send that offline as it can't be posted on the forum.
Mark
