Because of the Thanksgiving holiday in the U.S., TI E2E™ design support forum responses may be delayed from November 25 through December 2. Thank you for your patience.
LMS1585A: Application Inquiry
Part Number: LMS1585A
Hello Team,
My customer is using PN LMS1585ACS-1.5/NOPB in an application. Per the datasheet, Cout is supposed to be a tantalum cap. So far, since this is an SMT PCBA they are using a ceramic cap. Is that acceptable? What is ESR for PN: LMS1585ACS-1.5/NOPB?
Renan
  • Hi Renan,
    This older device is not very well characterized and I don't know the range of ESR for stability. I would recommend including a series resistor with the output cap to add ESR. The resistance of this resistor will need to be probably around 1Ω or so but we can't give an exact range.
    Nick
