TPSM8D6C24: SLAVE ADDRESS
Part Number: TPSM8D6C24
Other Parts Discussed in Thread: TPS546D24A
Hi team,
My customer points out that the words SLAVE_ADDRESS and Loop Follower_ADDRESS are mixed up in the datasheet.
In the table 7-14, Loop Follower_ADDRESS should be SLAVE_ADDRESS.
I suspect this should be due to a mistake from simple search & replace process applied to TPS546D24A datasheet.
I also find  SLVAE_ADDRESS survived from this process in p.140.
Could you please double check?
Itoh
