BQSTUDIO: programming the golden file
Guru 29720 points
Part Number: BQSTUDIO
Hi Team,
After programming the golden file by BQSTUDIO, does BQSTUDIO check that the programmed content is correct?
Is there any way to confirm if the programmed content is correct or not?
Yaita
  • bqStudio will report any errors on the GUI - usually in the bottom left status bar. Sometimes it will show a message box. If there are no errors, then you can assume that the content is correct because the communication uses checksums.
