LM5109B: spice simulation using the TI model does not compute
Part Number: LM5109B
Other Parts Discussed in Thread: PSPICE-FOR-TI
Trying to use the spice model of the LM5109B in LTSPICE.  I get an error:
However, if I just put the part by itself in a schematic, it just runs forever with no error message, as if it can't figure a stable operating point.  Do you wish to see the entire file I am using for the ltspice simulation?  I think it is not proprietary.  Let me know.
  • Here is the model from TI:
    * LM5109B
    * (C) Copyright 2016 Texas Instruments Incorporated. All rights reserved.
    ** This model is designed as an aid for customers of Texas Instruments.
    ** TI and its licensors and suppliers make no warranties, either expressed
    ** or implied, with respect to this model, including the warranties of
    ** merchantability or fitness for a particular purpose. The model is
    ** provided solely on an "as is" basis. The entire risk as to its quality
    ** and performance is with the customer.
    ** Released by: WEBENCH Design Center, Texas Instruments Inc.
    * Part: LM5109B
    * Date: 08MAR2016
    * Model Type: Transient
    * Simulator: PSpice
    * Simulator Version: 16.2.0.p001
    * EVM Order Number: NA
    * EVM User's Guide: NA
    * Data sheet: SNVS477C�FEBRUARY 2007�REVISED JANUARY 2016
    * Model Version: Final 1.00
    * Updates:
    * Final 1.00
    * Release to Web
    * Model Usage Notes:
    * A. Features have been modelled
    * 1. Output timing characteristics
    * 2. UVLO for High side & Low side driver
    * 3. Peak Source & Sink Current for VDD = VHB = 12V
    * 4. HI,LI-Input Thresholds vs VDD supply voltage
    * B. Features haven't been modelled
    * 1. Quiescent Current vs Supply Voltage
    * 2. Temperature dependent characteristics
    * 3. Frequency dependent plots
    .SUBCKT LM5109B_TRANS VDD HI LI VSS HB HO HS LO
    C_U3A_C1 U3A_N16789866 HB 5p
    C_U3A_C3 HO U3A_N16789866 10p
    E_U3A_E1 U3A_N16790231 HO VALUE { IF(V(GATE_HD, 0) > 0.5, 5, -5) }
    R_U3A_R1 U3A_N16790231 U3A_N16789866 151
    M_U3A_M2 HS U3A_N08192 HO HO PMOS01
    X_U3A_U10 HS HO d_d1
    R_U3A_R2 U3A_N16789868 U3A_N08192 150
    C_U3A_C2 HS U3A_N08192 5p
    X_U3A_U9 HO HB d_d1
    C_U3A_C5 HO HB 10pF
    C_U3A_C6 HO U3A_N08192 10p
    C_U3A_C4 HS HO 10pF
    M_U3A_M1 HB U3A_N16789866 HO HO NMOS01
    E_U3A_E2 HO U3A_N16789868 VALUE { IF(V(GATE_HD, 0) > 0.5, -5, 5) }
    X_U1 VDD_INT VDD_TH VDD_UVLO COMP_BASIC_GEN PARAMS: VDD=1 VSS=0
    + VTHRESH=0.5
    C_U3B_C1 U3B_N16789866 VDD 5p
    C_U3B_C3 LO U3B_N16789866 10p
    E_U3B_E1 U3B_N16790231 LO VALUE { IF(V(GATE_LD, 0) > 0.5, 5, -5) }
    R_U3B_R1 U3B_N16790231 U3B_N16789866 151
    M_U3B_M2 VSS U3B_N16789871 LO LO PMOS01
    X_U3B_U10 VSS LO d_d1
    R_U3B_R2 U3B_N16789868 U3B_N16789871 150
    C_U3B_C2 VSS U3B_N16789871 5p
    X_U3B_U9 LO VDD d_d1
    C_U3B_C5 LO VDD 10pF
    C_U3B_C6 LO U3B_N16789871 10p
    C_U3B_C4 VSS LO 10pF
    M_U3B_M1 VDD U3B_N16789866 LO LO NMOS01
    E_U3B_E2 LO U3B_N16789868 VALUE { IF(V(GATE_LD, 0) > 0.5, -5, 5) }
    E_E2 VDD_INT 0 VDD VSS 1
    E_ABM1 VDD_TH 0 VALUE { IF ( V(VDD_UVLO) < 0.5, 6.7, 6.2 ) }
    C_U7_C1 U7_N14683769 0 1n IC=0
    X_U7_U46 GATE_LD N18200399 U7_N14683159 NOR2_BASIC_GEN PARAMS: VDD=1
    + VSS=0 VTHRESH=500E-3
    X_U7_U43 U7_N14683769 GATE_LD BUF_BASIC_GEN PARAMS: VDD=1 VSS=0
    + VTHRESH=0.5
    X_U7_U48 U7_N147032561 U7_N14683769 d_d1
    V_U7_V6 U7_N147032561 0 80m
    X_U7_S2 U7_N14683147 0 U7_N14683887 U7_N14683769 TON_TOFF_U7_S2
    G_U7_ABM2I1 U7_N14683173 U7_N14683769 VALUE { IF(V(N18200399) > 0.5,
    + 22.8m,0) }
    X_U7_U44 N18200399 GATE_LD U7_N14683147 AND2_BASIC_GEN PARAMS: VDD=1
    G_U7_ABM2I2 U7_N14683769 0 VALUE { IF(V(N18200399) < 0.5, 26.5m, 0)
    V_U7_V4 U7_N14683887 0 1Vdc
    X_U7_S1 U7_N14683159 0 U7_N14683769 0 TON_TOFF_U7_S1
    V_U7_V5 U7_N14683173 0 1Vdc
    X_U7_U47 U7_N14683769 U7_N14683173 d_d1
    X_U17 N18187886 N18187850 N18200399 N18208809 srlatchrhp_basic_gen
    + PARAMS: VDD=1 VSS=0 VTHRESH=0.5
    X_U5_U5 LI U5_THRISE U5_HYS N18187886 COMPHYS_BASIC_GEN PARAMS: VDD=1
    + VSS=0 VTHRESH=0.5
    R_U5_Rin LI VSS 200k
    E_U5_E1 U5_THRISE VSS TABLE { V(VDD, VSS) }
    + ((8,1.861)(9,1.87)(10,1.878)(11,1.886)(12,1.895)(13,1.899)(14,1.908)
    +(15,1.913)(16,1.915))
    E_U5_E2 U5_HYS VSS TABLE { V(VDD, VSS) }
    + ( (8,53m)(9,51m)(10,48m)(11,49m)(12,51m)(13,49m)(14,52m)(15,50m)(16,47m) )
    X_U33 N18188010 N18187855 N18187850 OR2_BASIC_GEN PARAMS: VDD=1 VSS=0
    + VTHRESH=500E-3
    X_U15 VDD_UVLO N18188010 INV_BASIC_GEN PARAMS: VDD=1 VSS=0
    + VTHRESH=500E-3
    X_U13 N18187886 N18187855 INV_BASIC_GEN PARAMS: VDD=1 VSS=0
    + VTHRESH=500E-3
    X_U16 N18187973 N18187939 N18203660 N18187960 srlatchrhp_basic_gen
    R_Rss 0 VSS 1 TC=0,0
    X_U12 N18187973 N18187942 INV_BASIC_GEN PARAMS: VDD=1 VSS=0
    + VTHRESH=500E-3
    X_U1_U5 HI U1_THRISE U1_HYS N18187973 COMPHYS_BASIC_GEN PARAMS: VDD=1
    + VSS=0 VTHRESH=0.5
    R_U1_Rin HI VSS 200k
    E_U1_E1 U1_THRISE VSS TABLE { V(VDD, VSS) }
    E_U1_E2 U1_HYS VSS TABLE { V(VDD, VSS) }
    X_U34 VDD_UVLO VHBHS_UVLO UVLO NAND2_BASIC_GEN PARAMS: VDD=1 VSS=0
    + VTHRESH=500E-3
    X_U6 HB_INT HB_TH VHBHS_UVLO COMP_BASIC_GEN PARAMS: VDD=1 VSS=0
    + VTHRESH=0.5
    X_U32 UVLO N18187942 N18187939 OR2_BASIC_GEN PARAMS: VDD=1 VSS=0
    + VTHRESH=500E-3
    C_U2_C1 U2_N14683769 0 1n IC=0
    X_U2_U46 GATE_HD N18203660 U2_N14683159 NOR2_BASIC_GEN PARAMS: VDD=1
    X_U2_U43 U2_N14683769 GATE_HD BUF_BASIC_GEN PARAMS: VDD=1 VSS=0
    + VTHRESH=0.5
    X_U2_U48 U2_N147032561 U2_N14683769 d_d1
    V_U2_V6 U2_N147032561 0 80m
    X_U2_S2 U2_N14683147 0 U2_N14683887 U2_N14683769 TON_TOFF_U2_S2
    G_U2_ABM2I1 U2_N14683173 U2_N14683769 VALUE { IF(V(N18203660) > 0.5,
    + 22.8m,0) }
    X_U2_U44 N18203660 GATE_HD U2_N14683147 AND2_BASIC_GEN PARAMS: VDD=1
    G_U2_ABM2I2 U2_N14683769 0 VALUE { IF(V(N18203660) < 0.5, 26.5m, 0)
    V_U2_V4 U2_N14683887 0 1Vdc
    X_U2_S1 U2_N14683159 0 U2_N14683769 0 TON_TOFF_U2_S1
    V_U2_V5 U2_N14683173 0 1Vdc
    X_U2_U47 U2_N14683769 U2_N14683173 d_d1
    E_ABM5 HB_TH 0 VALUE { IF ( V(VHBHS_UVLO) < 0.5, 6.6, 6.2) }
    E_E6 HB_INT 0 HB HS 1
    .ENDS LM5109B_TRANS
    .SUBCKT TON_TOFF_U7_S2 1 2 3 4
    S_U7_S2 3 4 1 2 _U7_S2
    RS_U7_S2 1 2 1G
    .MODEL _U7_S2 VSWITCH Roff=100e6 Ron=1m Voff=0.2 Von=0.8
    .ENDS TON_TOFF_U7_S2
    .SUBCKT TON_TOFF_U7_S1 1 2 3 4
    S_U7_S1 3 4 1 2 _U7_S1
    RS_U7_S1 1 2 1G
    .MODEL _U7_S1 VSWITCH Roff=100e6 Ron=1m Voff=0.2 Von=0.8
    .ENDS TON_TOFF_U7_S1
    .SUBCKT TON_TOFF_U2_S2 1 2 3 4
    S_U2_S2 3 4 1 2 _U2_S2
    RS_U2_S2 1 2 1G
    .MODEL _U2_S2 VSWITCH Roff=100e6 Ron=1m Voff=0.2 Von=0.8
    .ENDS TON_TOFF_U2_S2
    .SUBCKT TON_TOFF_U2_S1 1 2 3 4
    S_U2_S1 3 4 1 2 _U2_S1
    RS_U2_S1 1 2 1G
    .MODEL _U2_S1 VSWITCH Roff=100e6 Ron=1m Voff=0.2 Von=0.8
    .ENDS TON_TOFF_U2_S1
    .SUBCKT INV_BASIC_GEN A Y PARAMS: VDD=1 VSS=0 VTHRESH=0.5
    E_ABMGATE YINT 0 VALUE {{IF(V(A) > {VTHRESH} ,
    + {VSS},{VDD})}}
    RINT YINT Y 1
    CINT Y 0 1n
    .ENDS INV_BASIC_GEN
    .SUBCKT OR2_BASIC_GEN A B Y PARAMS: VDD=1 VSS=0 VTHRESH=0.5
    E_ABMGATE YINT 0 VALUE {{IF(V(A) > {VTHRESH} |
    + V(B) > {VTHRESH},{VDD},{VSS})}}
    RINT YINT Y 1
    CINT Y 0 1n
    .ENDS OR2_BASIC_GEN
    **Reset has higher priority in this latch
    .SUBCKT SRLATCHRHP_BASIC_GEN S R Q QB PARAMS: VDD=1 VSS=0 VTHRESH=0.5
    GQ 0 Qint VALUE = {IF(V(R) > {VTHRESH},-5,IF(V(S)>{VTHRESH},5, 0))}
    CQint Qint 0 1n
    RQint Qint 0 1000MEG
    D_D10 Qint MY5 D_D1
    V1 MY5 0 {VDD}
    D_D11 MYVSS Qint D_D1
    V2 MYVSS 0 {VSS}
    EQ Qqq 0 Qint 0 1
    X3 Qqq Qqqd1 BUF_BASIC_GEN PARAMS: VDD={VDD} VSS={VSS} VTHRESH={VTHRESH}
    RQq Qqqd1 Q 1
    EQb Qbr 0 VALUE = {IF( V(Q) > {VTHRESH}, {VSS},{VDD})}
    RQb Qbr QB 1
    Cdummy1 Q 0 1n
    Cdummy2 QB 0 1n
    .IC V(Qint) {VSS}
    .MODEL D_D1 D (IS=1e-15 TT=10p Rs=0.05 N=0.1)
    .ENDS SRLATCHRHP_BASIC_GEN
    .SUBCKT D_D1 1 2
    D1 1 2 DD1
    .MODEL DD1 D (IS=1e-15 TT=10p Rs=0.001 N=0.1 )
    .ENDS D_D1
    .SUBCKT BUF_BASIC_GEN A Y PARAMS: VDD=1 VSS=0 VTHRESH=0.5
    + {VDD},{VSS})}}
    RINT YINT Y 1
    CINT Y 0 1n
    .ENDS BUF_BASIC_GEN
    .SUBCKT COMP_BASIC_GEN INP INM Y PARAMS: VDD=1 VSS=0 VTHRESH=0.5
    E_ABM Yint 0 VALUE {IF (V(INP) >
    + V(INM), {VDD},{VSS})}
    R1 Yint Y 1
    C1 Y 0 1n
    .ENDS COMP_BASIC_GEN
    .SUBCKT NAND2_BASIC_GEN A B Y PARAMS: VDD=1 VSS=0 VTHRESH=0.5
    E_ABMGATE YINT 0 VALUE {{IF(V(A) > {VTHRESH} &
    + V(B) > {VTHRESH},{VSS},{VDD})}}
    RINT YINT Y 1
    CINT Y 0 1n
    .ENDS NAND2_BASIC_GEN
    .MODEL NMOS01 NMOS (VTO = 2 KP = 0.22 LAMBDA = 0.001)
    .MODEL PMOS01 PMOS (VTO = -2 KP = 0.22 LAMBDA = 0.001)
    .SUBCKT AND2_BASIC_GEN A B Y PARAMS: VDD=1 VSS=0 VTHRESH=0.5
    RINT YINT Y 1
    CINT Y 0 1n
    .ENDS AND2_BASIC_GEN
    .SUBCKT COMPHYS_BASIC_GEN INP INM HYS OUT PARAMS: VDD=1 VSS=0 VTHRESH=0.5
    EIN INP1 INM1 INP INM 1
    EHYS INP1 INP2 VALUE { IF( V(1) > {VTHRESH},-V(HYS),0) }
    EOUT OUT 0 VALUE { IF( V(INP2)>V(INM1), {VDD} ,{VSS}) }
    R1 OUT 1 1
    C1 1 0 5n
    RINP1 INP1 0 1K
    .ENDS COMPHYS_BASIC_GEN
    .SUBCKT POWERMOS G D S PARAMS: RDSON=16m Ciss=1375p Crss=70p Coss=340p VSP=3.5 RG=1
    * This is a simple model for Power MOSFET.
    * The parameters modeled are
    * - RDSon,
    * - Input Capacitance,
    * - Reverse capacitance,
    * - Output capacitance,
    * - Switching point voltage (Gate voltage where the FET starts switching),
    * - Gate Resistance
    C_C1 S Da {Coss} IC=0
    R_R1 Da D 10
    C_C2 Ga D {Crss} IC=0
    R_R2 G Ga {RG}
    C_C3 Ga S {Ciss} IC=0
    D_D1 S Db Dbreak
    R_R3 Db D 1m
    S_switchM D S Ga S _switchM
    RS_switchM Ga S 100Meg
    .MODEL _switchM VSWITCH Roff=100e6 Ron={RDSON} Voff=1.1 Von={VSP}
    .model Dbreak D Is=1e-14 Cjo=.1pF Rs=.1
    .ENDS POWERMOS
    .SUBCKT NOR2_BASIC_GEN A B Y PARAMS: VDD=1 VSS=0 VTHRESH=0.5
    RINT YINT Y 1
    CINT Y 0 1n
    .ENDS NOR2_BASIC_GEN
  • both U1 and U2 in my simulation are LM5109B
  • Hi John,
    This model is designed for PSPICE. Please use PSPICE or PSPICE-FOR-TI to simulate your system and update if the error persists.
    Daniel W
