Hi
We found our PD PCB sometimes can't power on.And this is not happened on all PCB.
I found that the issue was happened easily when VOUT of un-normal PCB power on "with loading"
Please see attached circuit.In our design, Vout = 15V.
And I caught some waveform in normal case and un-normal case of tha same PCB
Left picture : VOUT output fail Right picture : VOUT output normal
Could you help to check design and waveform to clarify the issue. Thanks.
Wendy
