Hello
I have a problem that I encounter to perform some DC tests of the UCC5870 driver.
After carefully performing the test configuartion, indicate in the EVM user’s guide. We are not able to display the signals generated by the GUI test softwrae.
I am very afraid that it is the MCU board that causes the high current consumption(see attached). Do you think this problem may be from the MCU bord? If so, can a PWM be applied directly to the IN+ and IN- inputs from an external frequency generator?
Amadou
