Hi, support team
My customer has the questions as follow:
1. About LP3965-ADJ, datasheet said that:
"To obtain a desired output voltage, can be used with R1 always a 10kΩ resistor."
Could you tell me the detailed reason of "R1 always a 10kΩ resistor"? (Detailed reason about why must R1 use 10kΩ resistor)
2. Cf and Cout are used for output stability.
Could you tell me their respective uses and why they are connected in different places?
3. And why Cf must be between 68pF ~ 100pF?
Thanks so much.
Yuki
