Can you provide the Ext temp coefficient calculator's spreadsheet for BQ34110 IC to update under Temp Model in the data flash , as the one we have "sula398" doesn't seem to work with the mentioned IC.
Thank You
Thank You
Hello Sahaj,
We always recommend you to use the thermistor mentioned in the datasheet or one with the same characteristics so the coefficients don't need changed.
If you can send the full table of resistance vs. temperature data I can share adjusted coefficients.
Sincerely,
Wyatt Keller
Hello Wyatt,
We have decided to choose a different NTC thermistor from Vishay with part number NTCALUG54A103G351. I have attached a excel sheet below with the temperature v/s resistance values. Please share the external temperature coefficients.
RT_curve_NTCALUG54A103G351.xls
Thank You
Hello Sahaj,
Please see the coefficients below:
ext_coeff_1 = 38588
ext_coeff_2 = -25567
ext_coeff_3 = 6936
ext_coeff_4 = 240
Let me know if you have any issues.
Sincerely,
Wyatt Keller
