Part Number: REF2125
Is a resistor really necessary on the clean start pin of the REF2125? Also, equation 5 in the data sheet for the CS pin doesn't make sense. It has Ipeak equal to a current plus a voltage (13.54uaXRcs)
Hi Dave
I will check and let you know.
Trailokya
Hi Dave
Thanks for highlighting the equation. There is a typo. The correct equation will be -
IPeak = 466uA + (13.54uA/Kohm )* RCS
The peak current will be around 0.5mA if you short it. It will increase with the resistor and max it can go upto 19mA (it will saturate at that point.).
Trailokya
This makes sense now. My other question is: Do I have to connect a resistor to this pin if I don't need the clean start feature?
Hi Dave
Peak current will be maximum for open condition. You don't need any resistor if you don't need clean start feature.
Trailokya
