Hi, total novice here, so please bear with me. I'm using the bq2750xEVM. After completing the bqEASY configuration and calibration steps, nothing in the Data Flash display changes. Isn't bqEASY supposed to update the configuration? Thanks...
Hi Chris,
By no means am I an expert on this, but I might be able to offer some advice.
First, go through your bqEasy calibration.
Then, go to the Data Flash tab and up top click "Read All". That should update the Data Flash page with everything that was then configured from the bqEasy calibration.
If you change anything on that screen (note that you have to enter a value in the field AND hit enter to save it) then click "Write All" to write all of the changes to the board your using.
If you make changes with the bqEasy setup and then want to save those changes, go to File-> Export and save the .gg file. Later, if you accidently reset the chip or want to load in that version, goto the Data Flash tab, click File->Import->The file you saved, then click "Write All" to write it to the board.
Hope this helps,
Nick
