Hi team,
Is it allowed to enable TPS6287x with open drain signal as shown below?
Itoh
Hi team,
Itoh
Hi Tanvee-san,
I don't mean I'm laeving EN pin floating.
I mean EN is pulled up to VIN, and open-drain control signal is connected to EN directly as shown in the schematic I attached.
Does it make sense?
Itoh
Hi Itoh-san,
I would not expect this approach will create problems for device behavior. It can consume from supply during disable mode.
Can you share more detail on an application that requires for this setup?
Thanks, Tanvee
