For instance, I have a TPS65916 and I would like to know what processors are available from TI.
Also, when I find a processor that works with my solution, how would I place the interconnects?
Hello everyone,
a question often asked is, “What processor or SoC does TI offer with their PMIC devices or vice-versa?”
Due to the great folks like you who ask questions and the engineers here at TI, we have a solution.
The section below contains the part number along with the associated processor/SoC with companion guides to power it.
Note “x” denotes a suffix for a part number
For example, AM572x could stand in place for: AM5729, AM5728, or AM5726
AM570x: https://www.ti.com/lit/pdf/slvub99
AM571x: https://www.ti.com/lit/pdf/slvuao4
DRA71x: https://www.ti.com/lit/pdf/slvuax9
DRA72x: https://www.ti.com/lit/pdf/slvuaj1
DRA78x: https://www.ti.com/lit/pdf/slvuas4
DRA79x: https://www.ti.com/lit/pdf/slvuax9
DRA7xxP: https://www.ti.com/lit/pdf/slvubc8
TDA3x: https://www.ti.com/lit/pdf/slvuas4
TDA2E-17: https://www.ti.com/lit/pdf/slvuax9
TDA2Pxx: https://www.ti.com/lit/pdf/slvubc8
If your solution may require more power rails, then look into the TPS65903x PMIC lines with similar partner processors/SoC solutions [FAQ] is located
Link: HERE
