Other Parts Discussed in Thread: BQSTUDIO, EV2400
Hi TI team,
I've been looking to use the BQ40Z80 as a part of our new BMS system and I jsut have a few questions about the chip that confuse me a little.
When it comes to the LED display, we are planning to use 4 LEDs rather than 6 LEDs. This means that I can short the LEDCNTLC pin to VSS and use the remaining LEDCNTLx pins to controll the 4 LEDs, correct? Staying on the topic of the LEDs, I have read up that there is an option to allow the display of LEDs while charging, but is it possible to program the LEDs so that they can start iluminate in diffrent directions? Example being if the battery pack is upside down in the charger the LEDs will go from Left to Right, rather than Right to Left.
The question I have which I have difficulty understanding right now is how could the BQ40Z80 be programmed? Do I need to use a small pogo-jig on the SMBus line in order to upload the code? Is there other pins that are in charge of flashing new program to the memory of the chip? And what would be the most efficient way of uploading a developed code in a production scenario?
Kind regards,
Patryk.
