Hi support team,
Please let me know the difference between the following devices.
Between TPS7B8633DQDDARQ1 and TPS7B8633QDDARQ1.
Between TPS7B8650DQDDARQ1 and TPS7B8650QDDARQ1.
Do they have PG or not?
Dice-K
Hi support team,
Dice-K
Hi Dice-K,
The TPS7B8633DQDDARQ1 and TPS7B8650DQDDARQ1 do have PG functionality. These are custom made devices and the pin out is different compared to the non-D version. other than that, they are the same silicon.
Edgar Acosta
Hi Edgar,
Thank you for your reply.
The data sheet SBVS362B states that the B version is equipped with PG.
What is the difference between B version and D version?
Which is the load regulation for the D version?
Dice-K
Hi Dice-K,
The B and D versions have PG, TPS7B8633QDDARQ1 and TPS7B8650QDDARQ1 do not.
The D version will follow the specs for the B version. As stated before, the only difference is the Pin Out since D version is a custom made part.
Edgar Acosta
Hi Edgar,
Is Figure 5-3 the B version of the pin assignment?
What is the D version of the pin assignment?
Even if it is a custom product, if it is an orderable product, it is better to describe it in the data sheet.
Dice-K
Hi Dice-K,
Yes, figure 5-3 is the pin out for the B version.
We are currently working on updating the DS. The D version is available as an orderable. Here is the Pin out:
Edgar Acosta
