Other Parts Discussed in Thread: BQ76942
Hi Team,
Customer's application is 7-cells battery monitor. Currently they want to do co-layout design between our BQ76952 and BQ76942 because of device shortage. I see all most every pins of above two devices are same except voltage sense pins.
Here are the support needed:
1. Is that okay to do co-layout design between BQ76942 and BQ76952? If yes, how to cope w/ the voltage sense pins since they only use 7-cells. Better you can share some schematic drawing. Thanks.
Stanley
