Hi Sir,
I tested TPS2561 with different current limit setting and got abnormal behavior when over current occur.
For 1.4A current limit, TPS2561 is auto retry when OC occur; but for 1A current limit setting, TPS2561 isn't auto retry.
Both test are using the same TPS2561 part and just change R_limit value.
Please see the waveform and schematic below.
I have no idea why the different result with the R_limit value.
Would you help explain it?
Thank you.
Amos.
