Hi support team,
I have a question about the default sequence.
By default, do all VOUT1~4 start at the same time and stop at the same time?
Dice-K
Hi support team,
Dice-K
Hi Dice-K!
Sorry to late! Four sequence order registers has the same default value. So four outputs should be in same time to start or stop. Please refer our datasheet P46. And I saw you post another ticket which is also about TPS65400, actually, you can answer question in the same ticket, response may more quick.
Shuai
