Part Number: LMS3655
Other Parts Discussed in Thread: LM5017
Hello TI!
We are using LMS3655 in Fly-Buck configuration. Datasheet does not mention Fly-Buck configuration so i had to get inspired by other app notes.
As i understand, there are two ways to implement snubbers - 1) Across primary windings and to FB via a cap, 2) Across output diode.
- How come these two documents only mention one of the options each and not both? Can they be used both at the same time?
- Are there any other ways to reduce EMI? We dont care about efficiency, as long as EMI is low.
- Should Cac be specifically 100n or should we try adjust it for the perfect value?
Thank you,
Valentinas
