Hi All,
I am trying to create a very smooth fade in/fade out process using this device but for some reason when entering very low numbers
into the PWM value of a given channel (say the values 1 and then 2 and then 3) I see relatively big changes that should not be there.
In the past two years I have been working a lot with 16bit PWM for leds fade in/out processes and I know something is wrong here. For a range of 65535 possible values, such
small changes should not be even noticeable to the eye.
I guess I am missing something when controlling this device. I would to learn what is the reason for what I am seeing and how can I fix it.
Thank you,
Nir
