Hi team,
what would happen if 5V VBUS drop below VBUS_CONVENZ for a short period of time?
this is not listed in the datasheet?
please help elaborate, thanks
Hi team,
Hi Fred,
If VBUS drops below VBUS_CONVENZ, the converter operation will stop (no charging), REGN LDO will turn off, and CHRG_OK will go low.
When VBUS again goes above this threshhold, the device will behave as it does on power up from VBUS:
1. 50 ms after VBUS above VVBUS_CONVEN, enable 6 V LDO and CHRG_OK goes HIGH
2. Input voltage and current limit setup
3. Battery CELL configuration
4. 150 ms after VBUS above VVBUS_CONVEN, converter powers up.
Khalid
