Part Number: BQ25060
Other Parts Discussed in Thread: CSD25484F4
Hi team,
In our design, We are using bq25060 in power path mode. This is our schematic.
If the battery is NOT connected, after the first time apply 5v on the IN pin, the voltage on OUT and BGATE pin are close to 5v and the BAT pin voltage is 0 volte. But when we remove the power supply and apply it again, the OUT and BAT pin voltage is about 4.2v. At the same time, we observe a 10hz square wave on the BGATE pin with an amplitude of 4.2v.
is this the expected behavior of bq25060? Why do we see the 4.2v on the BAT pin only when we remove and apply the power again?
thanks
Tony
