TLC6983: Question about alternate usage
Part Number: TLC6983
Other Parts Discussed in Thread: LP5890
Hi Team,
We need your help ont the clarification for alternative usage for TLC6983. The customer wanted to drive higher voltage devices rather than LEDs.
They plan to have the row RGB outputs drive an Op Amp, and power resistors. They would use the Line outputs to be either off or on. When a line is off, it will sometimes be exposed to the higher voltage of the op-amp output.
Our question is "how high of a voltage can the line output FETs withstand without breaking down, when in the OFF state."?
Thank you in advance for the support.
Jonathan
