Other Parts Discussed in Thread: TPS62172, TPS62162-Q1, TPS62162
Hello team,
Due to the delivery issue of the TPS62172-Q1, we are considering the alternative part.
We believe below are the candidate. Non-automotive grade is also under consideration.
1. TPS62172
2. TPS62162-Q1
3. TPS62162
Question
1. What is the difference between TPS62172-Q1 and TPS62172 except the auto/non-auto grade?
2. What is the difference between TPS62172-Q1 and TPS62162-Q1? only current limit?
3. What is the difference between TPS62162-Q1 and TPS62162 except the auto/non-auto grade?
4. If they go to the TPS62172 from TPS62172-Q1, no change is needed for the schematic?
5. If they go to the TPS62162-Q1/TPS62162 from TPS62172-Q1, the portion they need to change in the schematic is only inductor to meet the new current limit? Are there any other portion they need to change?
I appreciate your support.
Hirata
