Other Parts Discussed in Thread: MSP432E411Y, LM36010, MSP432E401Y, MSP-EXP432E401Y, UNIFLASH
Hi team,
In EVM's datasheet, MSP-EXP432P401R is needed. But I didn't find a MSP in this EVM. How can I solve this problem?
Peter Xu
Hi team,
Peter Xu
hi Peter
Pls notice MSP-EXP432P401R is not a must MCU for LM36010. Some alternatives can be MSP432E411Y, MSP432E401Y
Hi Mason,
Thanks for your answer. I don't have any MSP now, should I apply for one in TIsample? Or any other solution can help?
Peter Xu
hi peter
sorry I got a misunderstanding. Currently MSP-EXP432 is EOL and it’s launchpad cannot be applied online anymore. The devices mentioned above are still valid and can be chosen in customer design.
Hi Mason,
I used MSP-EXP432E401Y to provide control signal. And I got problem when I tried to flash the MSP432. The screenshot is shown below.
And I asked questions in MCU forum, they told me to flash the MSP432 in Uniflash and I did it successfully. You can see the screenshot below.
However, I still cannot read/write the register. The error still occurs whenever I open the software.
I browsed the forum and I saw a user named "Kay Chen53". I have a same problem as him. I don't have another launchpad to test and I wonder if we have some solution.
Peter
hi Peter
How do you set up the bench? you got a MSP-EXP432E401Y launch board and try to communicate with LM36010 EVM? More detailed description would be helpful. thanks
Hi Mason,
I just follow the user guide. I plug the EVM into launch board and give it a 3V supply. Then connect the launch board and my computer. Then open the software.
hi Peter
first of all, can you double check if SCL, SDA, GND of launch board have been correctly connected to EVM corresponding pins?
After this, can you provide the waveforms of SCL and SDA at EVM side?
