bq20z95 Software Questions
Other Parts Discussed in Thread: BQEVSW, BQ20Z45
1.       How to clear PFStatus bits? I tried to issue Permanent Fail Clear (PFKey) to the ManufacterAccess but I can’t clear the flag. The “bq20z95 Technical Reference.pdf” is being very vague about this process. Can you clarify it?
a.       SBS (0x62) read PFKey command returns hex-string (using the I2C Bus Analyzer). We can ignore the  since it is a garbage byte, but  of valid data is 1 byte too many for the PFKey.
b.      Which of those four bytes to use as PFKey? From the BQEVSW Pro Read SMB Block I got  are these bytes correct?
c.       How exactly do you issue the Permanent Fail Clear command? I’m only concern about the protocol itself; I understand that you have to send the word in byte-swap order.
6.       2. Once I’ve done the testing for battery modules & chemistry selection & battery learning process. How long does it take for you to create the Golden Image? I thought BQEasy should be able to create that Golden Image, and you probably just have to reconfirm the image right?
