Part Number: TPS650861
Below are the desired sequence of the voltages for the device part# TPS650861
| Sequence | Outputs | Voltage(V) |
| 1 | BUCK4 | 0.9 |
| 2 | BUCK1 | 1.8 |
| 2 | BUCK6 | 1.2 |
| 2 | BUCK2 | 0.85 |
| 3 | SWB1 | 1.8 |
| 3 | SWB2 | 1.8 |
| any | BUCK3 | 1.2 |
| any | LOAD1 | 2.5 |
| 3 | BUCK5 | 3.3 |
I have filled the OTP generator excel sheet as per above requirement.
Kindly verify the register set values generated for the OTP programming. I have attached the excel sheet for your review.
FYI: We have an external I2C master via which we will program the device.
Jainendra
