Hi, I need to drive 8 HBLED in series with a series voltage of 28Vcc at 700mA current.
Does TI have any driver that can boost 7.4Vcc to 28V to drive these LED at the specified current ?
Thanks.
Thanks.
Hi Ubiratan,
I recommend you to use TPS92390 as your LED driver.
This device has 4 channels and output current is up to 200mA per channel.
You can tight the 4 channels together and set the output current to 175mA per channel to get the total current as 700mA.
More details in TPS92390 datasheet
Patrick Yao
Hi Ubiratan,
Do you have more questions about TPS92390?
If not, I'll close this case later.
BR
Patrick Yao
