Can you provide the DEMO configuration file of TPS6594?
Hi Xiaofu,
Can you tell us a little more about what you need? What's the exact EVM part number you're asking for? Have you checked the user guide for the EVM I guess?
Thanks!
Phil
Current Status:
1. PMIC (TPS65941111RWERQ1) evaluation board can be accessed normally through PC
2. The PC can read and write the EEPROM of the PMIC.
Fault: After the PFSM is configured according to the document, the PFSM cannot output the voltage and time sequence properly
Please help to review whether the PFSM configuration is OK?
{ "details": { "name": "sample_template", "description": "description for sample template", "revision": "0.4.0" }, "content": { "staticConfig": [ { "name": "TPS6594x", "devices": [] }, { "name": "TPS6594x_2p0", "devices": [ { "alias": "TPS65940", "type": "TPS6594x_2p0", "masterOrSlave": "master", "master": true, "staticConfigJSON": { "groups": [ { "name": "Buck", "blocks": [ { "name": "Buck1_2_3_4", "type": "visible", "registers": [ { "regID": "BUCK1_CTRL", "fixedFields": [ { "fieldID": "BUCK1_EN", "value": 0 }, { "fieldID": "BUCK1_PLDN", "value": 1 }, { "fieldID": "BUCK1_VMON_EN", "value": 0 } ], "hideFields": [ "BUCK1_EN", "BUCK1_PLDN", "BUCK1_VMON_EN" ], "fields": [ "BUCK1_EN", "BUCK1_FPWM", "BUCK1_FPWM_MP", "BUCK1_VSEL", "BUCK1_VMON_EN", "BUCK1_PLDN", "BUCK1_RV_SEL" ] }, { "regID": "BUCK1_CONF", "fields": [ "BUCK1_SLEW_RATE", "BUCK1_ILIM" ] }, { "regID": "BUCK1_VOUT_1", "fields": [ "BUCK1_VSET1" ] }, { "regID": "BUCK1_VOUT_2", "fields": [ "BUCK1_VSET2" ] }, { "regID": "BUCK1_PG_WINDOW", "fields": [ "BUCK1_OV_THR", "BUCK1_UV_THR" ] }, { "regID": "RAIL_SEL_1", "fields": [ "BUCK1_GRP_SEL" ] }, { "regID": "BUCK_RESET_REG", "fixedFields": [ { "fieldID": "BUCK1_RESET", "value": 0 } ], "hideFields": [ "BUCK1_RESET" ], "fields": [ "BUCK1_RESET" ] }, { "regID": "FREQ_SEL", "hideFields": [ "BUCK1_FREQ_SEL" ], "fields": [ "BUCK1_FREQ_SEL" ] }, { "regID": "BUCK_CONFIG_ANALOG_1", "hideFields": [ "BUCK1_SEL_NEG_OCP_HYST" ], "fields": [ "BUCK1_SEL_NEG_OCP_HYST" ] }, { "regID": "BUCK_CONFIG_DIGITAL_1", "hideFields": [ "BUCK1_SEL_POS_OCP_HYST" ], "fields": [ "BUCK1_SEL_POS_OCP_HYST" ] }, { "regID": "BUCK_CONFIG_ANALOG_3", "hideFields": [ "BUCK1_SEL_ISENSE_SLOPE_COMPENSATION", "BUCK1_SEL_VOUT_ADC_LEVEL" ], "fields": [ "BUCK1_SEL_ISENSE_SLOPE_COMPENSATION", "BUCK1_SEL_VOUT_ADC_LEVEL" ] }, { "regID": "BUCK_CONFIG_DIGITAL_0", "fixedFields": [ { "fieldID": "BUCK1_SEL_PHASE_ADD", "value": 1 }, { "fieldID": "BUCK1_SEL_PHASE_SHEDD", "value": 0 }, { "fieldID": "EN_LOAD_COMP_BLANK", "value": 1 } ], "hideFields": [ "BUCK1_SEL_PHASE_ADD", "BUCK1_SEL_PHASE_SHEDD", "EN_LOAD_COMP_BLANK" ], "fields": [ "BUCK1_SEL_PHASE_ADD", "BUCK1_SEL_PHASE_SHEDD", "EN_LOAD_COMP_BLANK" ] }, { "regID": "BUCK_CONFIG_DIGITAL_4", "hideFields": [ "BUCK1_SEL_OUTPUT_CAPS" ], "fields": [ "BUCK1_SEL_OUTPUT_CAPS" ] }, { "regID": "BUCK_CONFIG_DIGITAL_6", "hideFields": [ "BUCK1_SEL_RAMP" ], "fields": [ "BUCK1_SEL_RAMP" ] }, { "regID": "BUCK_CONFIG_DIGITAL_12", "hideFields": [ "BUCK1_FREQ_8MHZ" ], "fields": [ "BUCK1_FREQ_8MHZ" ] }, { "regID": "BUCK_CONFIG_DIGITAL_13", "hideFields": [ "BUCK1_EN_P_10M_BODY_DIODE" ], "fields": [ "BUCK1_EN_P_10M_BODY_DIODE" ] }, { "regID": "BUCK_CONFIG_DIGITAL_14", "hideFields": [ "BUCK1_DOUBLE_PFM_PULSE" ], "fields": [ "BUCK1_DOUBLE_PFM_PULSE" ] }, { "regID": "BUCK_CONFIG_DIGITAL_15", "hideFields": [ "BUCK1_CHANGE_2MHZ_BELOW_0V5" ], "fields": [ "BUCK1_CHANGE_2MHZ_BELOW_0V5" ] }, { "regID": "BUCK_CONFIG_RADAR", "hideFields": [ "BUCK1_EN_RADAR_MODE" ], "fields": [ "BUCK1_EN_RADAR_MODE" ] }, { "regID": "BUCK1_DTEST_REG_0", "fixedFields": [ { "fieldID": "swc_buck_hiz_1", "value": 0 } ], "hideFields": [ "swc_buck_hiz_1" ], "fields": [ "swc_buck_hiz_1" ] } ], "regConfig": { "question": "Is this rail used for VTT?", "id": "vtt_config", "selectedOption": "yes", "options": [ { "name": "yes", "configurationDisplayName": "2.2MHz Single Phase for DDR Termination", "configuration": "DDR VTT (SP)", "inductor": "470nH" }, { "name": "no", "question": "What is this rail's switching frequency?", "id": "switching_frequency_config", "selectedOption": "4.4MHz", "options": [ { "name": "4.4MHz", "question": "Does this rail want to be optimized for multiphase configuration?", "id": "multiphase_config", "selectedOption": "yes", "options": [ { "name": "yes", "configurationDisplayName": "4.4MHz Multiphase Configuration", "configuration": "4.4MHz HiCur (MP)", "inductor": "220nH" }, { "name": "no", "question": "What is the output of this rail?", "id": "output_rail_config", "selectedOption": "1.8V or less", "options": [ { "name": "1.8V or less", "question": "What is the output capacitance on this rail?", "id": "output_capacitance_config", "selectedOption": "greater than 100 uF", "options": [ { "name": "greater than 100 uF", "configurationDisplayName": "4.4MHz Multiphase Configuration", "configuration": "4.4MHz HiCur (MP)", "inductor": "220nH" }, { "name": "less than 100uF", "configurationDisplayName": "4.4MHz Single Phase Low Output Voltage", "configuration": "4.4MHz LoCur (SP)", "inductor": "220nH" } ] }, { "name": "greater than 1.8V", "configurationDisplayName": "4.4MHz Single Phase High Output Voltage", "configuration": "4.4MHz HiVolt (SP)", "inductor": "470nH" } ] } ] }, { "name": "2.2MHz", "question": "Does this rail want to be optimized for multiphase configuration?", "id": "multiphase_config", "selectedOption": "yes", "options": [ { "name": "yes", "configurationDisplayName": "2.2MHz Multiphase with Full Range VIN", "configuration": "2.2MHz (MP)", "inductor": "470nH" }, { "name": "no", "question": "What is the output of this rail?", "id": "output_rail_config", "selectedOption": "1.8V or less", "options": [ { "name": "1.8V or less", "configurationDisplayName": "2.2MHz Multiphase with Full Range VIN", "configuration": "2.2MHz (MP)", "inductor": "470nH" }, { "name": "full range", "question": "What is the input voltage of this rail?", "id": "input_voltage_config", "selectedOption": "Only greater than 4.5V", "options": [ { "name": "Only greater than 4.5V", "configurationDisplayName": "2.2MHz Single Phase with 5.0V VIN", "configuration": "5Vin (SP)", "inductor": "470nH" }, { "name": "Supports full input voltage range", "configurationDisplayName": "2.2MHz Single Phase with Full Range VIN", "configuration": "2.2MHz (SP)", "inductor": "1000nH" } ] } ] } ] } ] } ] } }, { "name": "Buck1_2_3", "type": "hidden", "registers": [ { "regID": "BUCK1_CTRL", "fixedFields": [ { "fieldID": "BUCK1_EN", "value": 0 }, { "fieldID": "BUCK1_PLDN", "value": 1 }, { "fieldID": "BUCK1_VMON_EN", "value": 0 } ], "hideFields": [ "BUCK1_EN", "BUCK1_PLDN", "BUCK1_VMON_EN" ], "fields": [ "BUCK1_EN", "BUCK1_FPWM", "BUCK1_FPWM_MP", "BUCK1_VSEL", "BUCK1_VMON_EN", "BUCK1_PLDN", "BUCK1_RV_SEL" ] }, { "regID": "BUCK1_CONF", "fields": [ "BUCK1_SLEW_RATE", "BUCK1_ILIM" ] }, { "regID": "BUCK1_VOUT_1", "fields": [ "BUCK1_VSET1" ] }, { "regID": "BUCK1_VOUT_2", "fields": [ "BUCK1_VSET2" ] }, { "regID": "BUCK1_PG_WINDOW", "fields": [ "BUCK1_OV_THR", "BUCK1_UV_THR" ] }, { "regID": "RAIL_SEL_1", "fields": [ "BUCK1_GRP_SEL" ] }, { "regID": "BUCK_RESET_REG", "fixedFields": [ { "fieldID": "BUCK1_RESET", "value": 0 } ], "hideFields": [ "BUCK1_RESET" ], "fields": [ "BUCK1_RESET" ] }, { "regID": "FREQ_SEL", "hideFields": [ "BUCK1_FREQ_SEL" ], "fields": [ "BUCK1_FREQ_SEL" ] }, { "regID": "BUCK_CONFIG_ANALOG_1", "hideFields": [ "BUCK1_SEL_NEG_OCP_HYST" ], "fields": [ "BUCK1_SEL_NEG_OCP_HYST" ] }, { "regID": "BUCK_CONFIG_DIGITAL_1", "hideFields": [ "BUCK1_SEL_POS_OCP_HYST" ], "fields": [ "BUCK1_SEL_POS_OCP_HYST" ] }, { "regID": "BUCK_CONFIG_ANALOG_3", "hideFields": [ "BUCK1_SEL_ISENSE_SLOPE_COMPENSATION", "BUCK1_SEL_VOUT_ADC_LEVEL" ], "fields": [ "BUCK1_SEL_ISENSE_SLOPE_COMPENSATION", "BUCK1_SEL_VOUT_ADC_LEVEL" ] }, { "regID": "BUCK_CONFIG_DIGITAL_0", "fixedFields": [ { "fieldID": "BUCK1_SEL_PHASE_ADD", "value": 1 }, { "fieldID": "BUCK1_SEL_PHASE_SHEDD", "value": 0 }, { "fieldID": "EN_LOAD_COMP_BLANK", "value": 1 } ], "hideFields": [ "BUCK1_SEL_PHASE_ADD", "BUCK1_SEL_PHASE_SHEDD", "EN_LOAD_COMP_BLANK" ], "fields": [ "BUCK1_SEL_PHASE_ADD", "BUCK1_SEL_PHASE_SHEDD", "EN_LOAD_COMP_BLANK" ] }, { "regID": "BUCK_CONFIG_DIGITAL_4", "hideFields": [ "BUCK1_SEL_OUTPUT_CAPS" ], "fields": [ "BUCK1_SEL_OUTPUT_CAPS" ] }, { "regID": "BUCK_CONFIG_DIGITAL_6", "hideFields": [ "BUCK1_SEL_RAMP" ], "fields": [ "BUCK1_SEL_RAMP" ] }, { "regID": "BUCK_CONFIG_DIGITAL_12", "hideFields": [ "BUCK1_FREQ_8MHZ" ], "fields": [ "BUCK1_FREQ_8MHZ" ] }, { "regID": "BUCK_CONFIG_DIGITAL_13", "hideFields": [ "BUCK1_EN_P_10M_BODY_DIODE" ], "fields": [ "BUCK1_EN_P_10M_BODY_DIODE" ] }, { "regID": "BUCK_CONFIG_DIGITAL_14", "hideFields": [ "BUCK1_DOUBLE_PFM_PULSE" ], "fields": [ "BUCK1_DOUBLE_PFM_PULSE" ] }, { "regID": "BUCK_CONFIG_DIGITAL_15", "hideFields": [ "BUCK1_CHANGE_2MHZ_BELOW_0V5" ], "fields": [ "BUCK1_CHANGE_2MHZ_BELOW_0V5" ] }, { "regID": "BUCK_CONFIG_RADAR", "hideFields": [ "BUCK1_EN_RADAR_MODE" ], "fields": [ "BUCK1_EN_RADAR_MODE" ] }, { "regID": "BUCK1_DTEST_REG_0", "fixedFields": [ { "fieldID": "swc_buck_hiz_1", "value": 0 } ], "hideFields": [ "swc_buck_hiz_1" ], "fields": [ "swc_buck_hiz_1" ] } ] }, { "name": "Buck1_2", "type": "hidden", "registers": [ { "regID": "BUCK1_CTRL", "fixedFields": [ { "fieldID": "BUCK1_EN", "value": 0 }, { "fieldID": "BUCK1_PLDN", "value": 1 }, { "fieldID": "BUCK1_VMON_EN", "value": 0 } ], "hideFields": [ "BUCK1_EN", "BUCK1_PLDN", "BUCK1_VMON_EN" ], "fields": [ "BUCK1_EN", "BUCK1_FPWM", "BUCK1_FPWM_MP", "BUCK1_VSEL", "BUCK1_VMON_EN", "BUCK1_PLDN", "BUCK1_RV_SEL" ] }, { "regID": "BUCK1_CONF", "fields": [ "BUCK1_SLEW_RATE", "BUCK1_ILIM" ] }, { "regID": "BUCK1_VOUT_1", "fields": [ "BUCK1_VSET1" ] }, { "regID": "BUCK1_VOUT_2", "fields": [ "BUCK1_VSET2" ] }, { "regID": "BUCK1_PG_WINDOW", "fields": [ "BUCK1_OV_THR", "BUCK1_UV_THR" ] }, { "regID": "RAIL_SEL_1", "fields": [ "BUCK1_GRP_SEL" ] }, { "regID": "BUCK_RESET_REG", "fixedFields": [ { "fieldID": "BUCK1_RESET", "value": 0 } ], "hideFields": [ "BUCK1_RESET" ], "fields": [ "BUCK1_RESET" ] }, { "regID": "FREQ_SEL", "hideFields": [ "BUCK1_FREQ_SEL" ], "fields": [ "BUCK1_FREQ_SEL" ] }, { "regID": "BUCK_CONFIG_ANALOG_1", "hideFields": [ "BUCK1_SEL_NEG_OCP_HYST" ], "fields": [ "BUCK1_SEL_NEG_OCP_HYST" ] }, { "regID": "BUCK_CONFIG_DIGITAL_1", "hideFields": [ "BUCK1_SEL_POS_OCP_HYST" ], "fields": [ "BUCK1_SEL_POS_OCP_HYST" ] }, { "regID": "BUCK_CONFIG_ANALOG_3", "hideFields": [ "BUCK1_SEL_ISENSE_SLOPE_COMPENSATION", "BUCK1_SEL_VOUT_ADC_LEVEL" ], "fields": [ "BUCK1_SEL_ISENSE_SLOPE_COMPENSATION", "BUCK1_SEL_VOUT_ADC_LEVEL" ] }, { "regID": "BUCK_CONFIG_DIGITAL_0", "fixedFields": [ { "fieldID": "BUCK1_SEL_PHASE_ADD", "value": 1 }, { "fieldID": "BUCK1_SEL_PHASE_SHEDD", "value": 0 }, { "fieldID": "EN_LOAD_COMP_BLANK", "value": 1 } ], "hideFields": [ "BUCK1_SEL_PHASE_ADD", "BUCK1_SEL_PHASE_SHEDD", "EN_LOAD_COMP_BLANK" ], "fields": [ "BUCK1_SEL_PHASE_ADD", "BUCK1_SEL_PHASE_SHEDD", "EN_LOAD_COMP_BLANK" ] }, { "regID": "BUCK_CONFIG_DIGITAL_4", "hideFields": [ "BUCK1_SEL_OUTPUT_CAPS" ], "fields": [ "BUCK1_SEL_OUTPUT_CAPS" ] }, { "regID": "BUCK_CONFIG_DIGITAL_6", "hideFields": [ "BUCK1_SEL_RAMP" ], "fields": [ "BUCK1_SEL_RAMP" ] }, { "regID": "BUCK_CONFIG_DIGITAL_12", "hideFields": [ "BUCK1_FREQ_8MHZ" ], "fields": [ "BUCK1_FREQ_8MHZ" ] }, { "regID": "BUCK_CONFIG_DIGITAL_13", "hideFields": [ "BUCK1_EN_P_10M_BODY_DIODE" ], "fields": [ "BUCK1_EN_P_10M_BODY_DIODE" ] }, { "regID": "BUCK_CONFIG_DIGITAL_14", "hideFields": [ "BUCK1_DOUBLE_PFM_PULSE" ], "fields": [ "BUCK1_DOUBLE_PFM_PULSE" ] }, { "regID": "BUCK_CONFIG_DIGITAL_15", "hideFields": [ "BUCK1_CHANGE_2MHZ_BELOW_0V5" ], "fields": [ "BUCK1_CHANGE_2MHZ_BELOW_0V5" ] }, { "regID": "BUCK_CONFIG_RADAR", "hideFields": [ "BUCK1_EN_RADAR_MODE" ], "fields": [ "BUCK1_EN_RADAR_MODE" ] }, { "regID": "BUCK1_DTEST_REG_0", "fixedFields": [ { "fieldID": "swc_buck_hiz_1", "value": 0 } ], "hideFields": [ "swc_buck_hiz_1" ], "fields": [ "swc_buck_hiz_1" ] } ] }, { "name": "Buck3_4", "type": "hidden", "registers": [ { "regID": "BUCK3_CTRL", "fixedFields": [ { "fieldID": "BUCK3_EN", "value": 0 }, { "fieldID": "BUCK3_PLDN", "value": 1 }, { "fieldID": "BUCK3_VMON_EN", "value": 0 } ], "hideFields": [ "BUCK3_EN", "BUCK3_PLDN", "BUCK3_VMON_EN" ], "fields": [ "BUCK3_EN", "BUCK3_FPWM", "BUCK3_FPWM_MP", "BUCK3_VSEL", "BUCK3_VMON_EN", "BUCK3_PLDN", "BUCK3_RV_SEL" ] }, { "regID": "BUCK3_CONF", "fields": [ "BUCK3_SLEW_RATE", "BUCK3_ILIM" ] }, { "regID": "BUCK3_VOUT_1", "fields": [ "BUCK3_VSET1" ] }, { "regID": "BUCK3_VOUT_2", "fields": [ "BUCK3_VSET2" ] }, { "regID": "BUCK3_PG_WINDOW", "fields": [ "BUCK3_OV_THR", "BUCK3_UV_THR" ] }, { "regID": "RAIL_SEL_1", "fields": [ "BUCK3_GRP_SEL" ] }, { "regID": "BUCK_RESET_REG", "fixedFields": [ { "fieldID": "BUCK3_RESET", "value": 0 } ], "hideFields": [ "BUCK3_RESET" ], "fields": [ "BUCK3_RESET" ] }, { "regID": "FREQ_SEL", "hideFields": [ "BUCK3_FREQ_SEL" ], "fields": [ "BUCK3_FREQ_SEL" ] }, { "regID": "BUCK_CONFIG_ANALOG_1", "hideFields": [ "BUCK3_SEL_NEG_OCP_HYST" ], "fields": [ "BUCK3_SEL_NEG_OCP_HYST" ] }, { "regID": "BUCK_CONFIG_DIGITAL_1", "hideFields": [ "BUCK3_SEL_POS_OCP_HYST" ], "fields": [ "BUCK3_SEL_POS_OCP_HYST" ] }, { "regID": "BUCK_CONFIG_ANALOG_5", "hideFields": [ "BUCK3_SEL_ISENSE_SLOPE_COMPENSATION", "BUCK3_SEL_VOUT_ADC_LEVEL" ], "fields": [ "BUCK3_SEL_ISENSE_SLOPE_COMPENSATION", "BUCK3_SEL_VOUT_ADC_LEVEL" ] }, { "regID": "BUCK_CONFIG_DIGITAL_0", "fixedFields": [ { "fieldID": "BUCK3_SEL_PHASE_SHEDD", "value": 0 }, { "fieldID": "BUCK3_SEL_PHASE_ADD", "value": 1 } ], "hideFields": [ "BUCK3_SEL_PHASE_ADD", "BUCK3_SEL_PHASE_SHEDD" ], "fields": [ "BUCK3_SEL_PHASE_ADD", "BUCK3_SEL_PHASE_SHEDD" ] }, { "regID": "BUCK_CONFIG_DIGITAL_4", "hideFields": [ "BUCK3_SEL_OUTPUT_CAPS" ], "fields": [ "BUCK3_SEL_OUTPUT_CAPS" ] }, { "regID": "BUCK_CONFIG_DIGITAL_7", "hideFields": [ "BUCK3_SEL_RAMP" ], "fields": [ "BUCK3_SEL_RAMP" ] }, { "regID": "BUCK_CONFIG_DIGITAL_12", "hideFields": [ "BUCK3_FREQ_8MHZ" ], "fields": [ "BUCK3_FREQ_8MHZ" ] }, { "regID": "BUCK_CONFIG_DIGITAL_13", "hideFields": [ "BUCK3_EN_P_10M_BODY_DIODE" ], "fields": [ "BUCK3_EN_P_10M_BODY_DIODE" ] }, { "regID": "BUCK_CONFIG_DIGITAL_14", "hideFields": [ "BUCK3_DOUBLE_PFM_PULSE" ], "fields": [ "BUCK3_DOUBLE_PFM_PULSE" ] }, { "regID": "BUCK_CONFIG_DIGITAL_15", "hideFields": [ "BUCK3_CHANGE_2MHZ_BELOW_0V5" ], "fields": [ "BUCK3_CHANGE_2MHZ_BELOW_0V5" ] }, { "regID": "BUCK_CONFIG_RADAR", "hideFields": [ "BUCK3_EN_RADAR_MODE" ], "fields": [ "BUCK3_EN_RADAR_MODE" ] }, { "regID": "BUCK3_DTEST_REG_0", "fixedFields": [ { "fieldID": "swc_buck_hiz_3", "value": 0 } ], "hideFields": [ "swc_buck_hiz_3" ], "fields": [ "swc_buck_hiz_3" ] } ] }, { "name": "Buck3 Monitor", "type": "visible", "registers": [ { "regID": "BUCK3_CTRL", "fields": [ "BUCK3_VSEL", "BUCK3_RV_SEL" ] }, { "regID": "BUCK3_CONF", "fields": [ "BUCK3_SLEW_RATE" ] }, { "regID": "BUCK3_VOUT_1", "fields": [ "BUCK3_VSET1" ] }, { "regID": "BUCK3_VOUT_2", "fields": [ "BUCK3_VSET2" ] }, { "regID": "BUCK3_PG_WINDOW", "fields": [ "BUCK3_OV_THR", "BUCK3_UV_THR" ] }, { "regID": "RAIL_SEL_1", "fields": [ "BUCK3_GRP_SEL" ] } ] }, { "name": "Buck4 Monitor", "type": "visible", "registers": [ { "regID": "BUCK4_CTRL", "fields": [ "BUCK4_VSEL", "BUCK4_RV_SEL" ] }, { "regID": "BUCK4_CONF", "fields": [ "BUCK4_SLEW_RATE" ] }, { "regID": "BUCK4_VOUT_1", "fields": [ "BUCK4_VSET1" ] }, { "regID": "BUCK4_VOUT_2", "fields": [ "BUCK4_VSET2" ] }, { "regID": "BUCK4_PG_WINDOW", "fields": [ "BUCK4_OV_THR", "BUCK4_UV_THR" ] }, { "regID": "RAIL_SEL_1", "fields": [ "BUCK4_GRP_SEL" ] } ] }, { "name": "Buck1", "registers": [ { "regID": "BUCK1_CTRL", "fixedFields": [ { "fieldID": "BUCK1_EN", "value": 0 }, { "fieldID": "BUCK1_PLDN", "value": 1 }, { "fieldID": "BUCK1_VMON_EN", "value": 0 } ], "hideFields": [ "BUCK1_EN", "BUCK1_PLDN", "BUCK1_VMON_EN" ], "fields": [ "BUCK1_EN", "BUCK1_FPWM", "BUCK1_FPWM_MP", "BUCK1_VSEL", "BUCK1_VMON_EN", "BUCK1_PLDN", "BUCK1_RV_SEL" ] }, { "regID": "BUCK1_CONF", "fields": [ "BUCK1_SLEW_RATE", "BUCK1_ILIM" ] }, { "regID": "BUCK1_VOUT_1", "fields": [ "BUCK1_VSET1" ] }, { "regID": "BUCK1_VOUT_2", "fields": [ "BUCK1_VSET2" ] }, { "regID": "BUCK1_PG_WINDOW", "fields": [ "BUCK1_OV_THR", "BUCK1_UV_THR" ] }, { "regID": "RAIL_SEL_1", "fields": [ "BUCK1_GRP_SEL" ] }, { "regID": "BUCK_RESET_REG", "fixedFields": [ { "fieldID": "BUCK1_RESET", "value": 0 } ], "hideFields": [ "BUCK1_RESET" ], "fields": [ "BUCK1_RESET" ] }, { "regID": "FREQ_SEL", "hideFields": [ "BUCK1_FREQ_SEL" ], "fields": [ "BUCK1_FREQ_SEL" ] }, { "regID": "BUCK_CONFIG_ANALOG_1", "hideFields": [ "BUCK1_SEL_NEG_OCP_HYST" ], "fields": [ "BUCK1_SEL_NEG_OCP_HYST" ] }, { "regID": "BUCK_CONFIG_DIGITAL_1", "hideFields": [ "BUCK1_SEL_POS_OCP_HYST" ], "fields": [ "BUCK1_SEL_POS_OCP_HYST" ] }, { "regID": "BUCK_CONFIG_ANALOG_3", "hideFields": [ "BUCK1_SEL_ISENSE_SLOPE_COMPENSATION", "BUCK1_SEL_VOUT_ADC_LEVEL" ], "fields": [ "BUCK1_SEL_ISENSE_SLOPE_COMPENSATION", "BUCK1_SEL_VOUT_ADC_LEVEL" ] }, { "regID": "BUCK_CONFIG_DIGITAL_0", "fixedFields": [ { "fieldID": "BUCK1_SEL_PHASE_ADD", "value": 1 }, { "fieldID": "BUCK1_SEL_PHASE_SHEDD", "value": 0 }, { "fieldID": "EN_LOAD_COMP_BLANK", "value": 1 } ], "hideFields": [ "BUCK1_SEL_PHASE_ADD", "BUCK1_SEL_PHASE_SHEDD", "EN_LOAD_COMP_BLANK" ], "fields": [ "BUCK1_SEL_PHASE_ADD", "BUCK1_SEL_PHASE_SHEDD", "EN_LOAD_COMP_BLANK" ] }, { "regID": "BUCK_CONFIG_DIGITAL_4", "hideFields": [ "BUCK1_SEL_OUTPUT_CAPS" ], "fields": [ "BUCK1_SEL_OUTPUT_CAPS" ] }, { "regID": "BUCK_CONFIG_DIGITAL_6", "hideFields": [ "BUCK1_SEL_RAMP" ], "fields": [ "BUCK1_SEL_RAMP" ] }, { "regID": "BUCK_CONFIG_DIGITAL_12", "hideFields": [ "BUCK1_FREQ_8MHZ" ], "fields": [ "BUCK1_FREQ_8MHZ" ] }, { "regID": "BUCK_CONFIG_DIGITAL_13", "hideFields": [ "BUCK1_EN_P_10M_BODY_DIODE" ], "fields": [ "BUCK1_EN_P_10M_BODY_DIODE" ] }, { "regID": "BUCK_CONFIG_DIGITAL_14", "hideFields": [ "BUCK1_DOUBLE_PFM_PULSE" ], "fields": [ "BUCK1_DOUBLE_PFM_PULSE" ] }, { "regID": "BUCK_CONFIG_DIGITAL_15", "hideFields": [ "BUCK1_CHANGE_2MHZ_BELOW_0V5" ], "fields": [ "BUCK1_CHANGE_2MHZ_BELOW_0V5" ] }, { "regID": "BUCK_CONFIG_RADAR", "hideFields": [ "BUCK1_EN_RADAR_MODE" ], "fields": [ "BUCK1_EN_RADAR_MODE" ] }, { "regID": "BUCK1_DTEST_REG_0", "fixedFields": [ { "fieldID": "swc_buck_hiz_1", "value": 0 } ], "hideFields": [ "swc_buck_hiz_1" ], "fields": [ "swc_buck_hiz_1" ] } ], "regConfig": { "question": "Is this rail used for VTT?", "id": "vtt_config", "selectedOption": "yes", "options": [ { "name": "yes", "configurationDisplayName": "2.2MHz Single Phase for DDR Termination", "configuration": "DDR VTT (SP)", "inductor": "470nH" }, { "name": "no", "question": "What is this rail's switching frequency?", "id": "switching_frequency_config", "selectedOption": "4.4MHz", "options": [ { "name": "4.4MHz", "question": "Does this rail want to be optimized for multiphase configuration?", "id": "multiphase_config", "selectedOption": "yes", "options": [ { "name": "yes", "configurationDisplayName": "4.4MHz Multiphase Configuration", "configuration": "4.4MHz HiCur (MP)", "inductor": "220nH" }, { "name": "no", "question": "What is the output of this rail?", "id": "output_rail_config", "selectedOption": "1.8V or less", "options": [ { "name": "1.8V or less", "question": "What is the output capacitance on this rail?", "id": "output_capacitance_config", "selectedOption": "greater than 100 uF", "options": [ { "name": "greater than 100 uF", "configurationDisplayName": "4.4MHz Multiphase Configuration", "configuration": "4.4MHz HiCur (MP)", "inductor": "220nH" }, { "name": "less than 100uF", "configurationDisplayName": "4.4MHz Single Phase Low Output Voltage", "configuration": "4.4MHz LoCur (SP)", "inductor": "220nH" } ] }, { "name": "greater than 1.8V", "configurationDisplayName": "4.4MHz Single Phase High Output Voltage", "configuration": "4.4MHz HiVolt (SP)", "inductor": "470nH" } ] } ] }, { "name": "2.2MHz", "question": "Does this rail want to be optimized for multiphase configuration?", "id": "multiphase_config", "selectedOption": "yes", "options": [ { "name": "yes", "configurationDisplayName": "2.2MHz Multiphase with Full Range VIN", "configuration": "2.2MHz (MP)", "inductor": "470nH" }, { "name": "no", "question": "What is the output of this rail?", "id": "output_rail_config", "selectedOption": "1.8V or less", "options": [ { "name": "1.8V or less", "configurationDisplayName": "2.2MHz Multiphase with Full Range VIN", "configuration": "2.2MHz (MP)", "inductor": "470nH" }, { "name": "full range", "question": "What is the input voltage of this rail?", "id": "input_voltage_config", "selectedOption": "Only greater than 4.5V", "options": [ { "name": "Only greater than 4.5V", "configurationDisplayName": "2.2MHz Single Phase with 5.0V VIN", "configuration": "5Vin (SP)", "inductor": "470nH" }, { "name": "Supports full input voltage range", "configurationDisplayName": "2.2MHz Single Phase with Full Range VIN", "configuration": "2.2MHz (SP)", "inductor": "1000nH" } ] } ] } ] } ] } ] } }, { "name": "Buck2", "registers": [ { "regID": "BUCK2_CTRL", "fixedFields": [ { "fieldID": "BUCK2_EN", "value": 0 }, { "fieldID": "BUCK2_PLDN", "value": 1 }, { "fieldID": "BUCK2_VMON_EN", "value": 0 } ], "hideFields": [ "BUCK2_EN", "BUCK2_PLDN", "BUCK2_VMON_EN" ], "fields": [ "BUCK2_EN", "BUCK2_FPWM", "BUCK2_VSEL", "BUCK2_VMON_EN", "BUCK2_PLDN", "BUCK2_RV_SEL" ] }, { "regID": "BUCK2_CONF", "fields": [ "BUCK2_SLEW_RATE", "BUCK2_ILIM" ] }, { "regID": "BUCK2_VOUT_1", "fields": [ "BUCK2_VSET1" ] }, { "regID": "BUCK2_VOUT_2", "fields": [ "BUCK2_VSET2" ] }, { "regID": "BUCK2_PG_WINDOW", "fields": [ "BUCK2_OV_THR", "BUCK2_UV_THR" ] }, { "regID": "RAIL_SEL_1", "fields": [ "BUCK2_GRP_SEL" ] }, { "regID": "BUCK_RESET_REG", "fixedFields": [ { "fieldID": "BUCK2_RESET", "value": 0 } ], "hideFields": [ "BUCK2_RESET" ], "fields": [ "BUCK2_RESET" ] }, { "regID": "FREQ_SEL", "hideFields": [ "BUCK2_FREQ_SEL" ], "fields": [ "BUCK2_FREQ_SEL" ] }, { "regID": "BUCK_CONFIG_ANALOG_1", "hideFields": [ "BUCK2_SEL_NEG_OCP_HYST" ], "fields": [ "BUCK2_SEL_NEG_OCP_HYST" ] }, { "regID": "BUCK_CONFIG_DIGITAL_1", "hideFields": [ "BUCK2_SEL_POS_OCP_HYST" ], "fields": [ "BUCK2_SEL_POS_OCP_HYST" ] }, { "regID": "BUCK_CONFIG_ANALOG_4", "hideFields": [ "BUCK2_SEL_ISENSE_SLOPE_COMPENSATION", "BUCK2_SEL_VOUT_ADC_LEVEL" ], "fields": [ "BUCK2_SEL_ISENSE_SLOPE_COMPENSATION", "BUCK2_SEL_VOUT_ADC_LEVEL" ] }, { "regID": "BUCK_CONFIG_DIGITAL_4", "hideFields": [ "BUCK2_SEL_OUTPUT_CAPS" ], "fields": [ "BUCK2_SEL_OUTPUT_CAPS" ] }, { "regID": "BUCK_CONFIG_DIGITAL_6", "hideFields": [ "BUCK2_SEL_RAMP" ], "fields": [ "BUCK2_SEL_RAMP" ] }, { "regID": "BUCK_CONFIG_DIGITAL_12", "hideFields": [ "BUCK2_FREQ_8MHZ" ], "fields": [ "BUCK2_FREQ_8MHZ" ] }, { "regID": "BUCK_CONFIG_DIGITAL_13", "hideFields": [ "BUCK2_EN_P_10M_BODY_DIODE" ], "fields": [ "BUCK2_EN_P_10M_BODY_DIODE" ] }, { "regID": "BUCK_CONFIG_DIGITAL_14", "hideFields": [ "BUCK2_DOUBLE_PFM_PULSE" ], "fields": [ "BUCK2_DOUBLE_PFM_PULSE" ] }, { "regID": "BUCK_CONFIG_DIGITAL_15", "hideFields": [ "BUCK2_CHANGE_2MHZ_BELOW_0V5" ], "fields": [ "BUCK2_CHANGE_2MHZ_BELOW_0V5" ] }, { "regID": "BUCK_CONFIG_RADAR", "hideFields": [ "BUCK2_EN_RADAR_MODE" ], "fields": [ "BUCK2_EN_RADAR_MODE" ] }, { "regID": "BUCK2_DTEST_REG_0", "fixedFields": [ { "fieldID": "swc_buck_hiz_2", "value": 0 } ], "hideFields": [ "swc_buck_hiz_2" ], "fields": [ "swc_buck_hiz_2" ] } ], "regConfig": { "question": "Is this rail used for VTT?", "id": "vtt_config", "selectedOption": "yes", "options": [ { "name": "yes", "configurationDisplayName": "2.2MHz Single Phase for DDR Termination", "configuration": "DDR VTT (SP)", "inductor": "470nH" }, { "name": "no", "question": "What is this rail's switching frequency?", "id": "switching_frequency_config", "selectedOption": "4.4MHz", "options": [ { "name": "4.4MHz", "question": "Does this rail want to be optimized for multiphase configuration?", "id": "multiphase_config", "selectedOption": "yes", "options": [ { "name": "yes", "configurationDisplayName": "4.4MHz Multiphase Configuration", "configuration": "4.4MHz HiCur (MP)", "inductor": "220nH" }, { "name": "no", "question": "What is the output of this rail?", "id": "output_rail_config", "selectedOption": "1.8V or less", "options": [ { "name": "1.8V or less", "question": "What is the output capacitance on this rail?", "id": "output_capacitance_config", "selectedOption": "greater than 100 uF", "options": [ { "name": "greater than 100 uF", "configurationDisplayName": "4.4MHz Multiphase Configuration", "configuration": "4.4MHz HiCur (MP)", "inductor": "220nH" }, { "name": "less than 100uF", "configurationDisplayName": "4.4MHz Single Phase Low Output Voltage", "configuration": "4.4MHz LoCur (SP)", "inductor": "220nH" } ] }, { "name": "greater than 1.8V", "configurationDisplayName": "4.4MHz Single Phase High Output Voltage", "configuration": "4.4MHz HiVolt (SP)", "inductor": "470nH" } ] } ] }, { "name": "2.2MHz", "question": "Does this rail want to be optimized for multiphase configuration?", "id": "multiphase_config", "selectedOption": "yes", "options": [ { "name": "yes", "configurationDisplayName": "2.2MHz Multiphase with Full Range VIN", "configuration": "2.2MHz (MP)", "inductor": "470nH" }, { "name": "no", "question": "What is the output of this rail?", "id": "output_rail_config", "selectedOption": "1.8V or less", "options": [ { "name": "1.8V or less", "configurationDisplayName": "2.2MHz Multiphase with Full Range VIN", "configuration": "2.2MHz (MP)", "inductor": "470nH" }, { "name": "full range", "question": "What is the input voltage of this rail?", "id": "input_voltage_config", "selectedOption": "Only greater than 4.5V", "options": [ { "name": "Only greater than 4.5V", "configurationDisplayName": "2.2MHz Single Phase with 5.0V VIN", "configuration": "5Vin (SP)", "inductor": "470nH" }, { "name": "Supports full input voltage range", "configurationDisplayName": "2.2MHz Single Phase with Full Range VIN", "configuration": "2.2MHz (SP)", "inductor": "1000nH" } ] } ] } ] } ] } ] } }, { "name": "Buck3", "registers": [ { "regID": "BUCK3_CTRL", "fixedFields": [ { "fieldID": "BUCK3_EN", "value": 0 }, { "fieldID": "BUCK3_PLDN", "value": 1 }, { "fieldID": "BUCK3_VMON_EN", "value": 0 } ], "hideFields": [ "BUCK3_EN", "BUCK3_PLDN", "BUCK3_VMON_EN" ], "fields": [ "BUCK3_EN", "BUCK3_FPWM", "BUCK3_FPWM_MP", "BUCK3_VSEL", "BUCK3_VMON_EN", "BUCK3_PLDN", "BUCK3_RV_SEL" ] }, { "regID": "BUCK3_CONF", "fields": [ "BUCK3_SLEW_RATE", "BUCK3_ILIM" ] }, { "regID": "BUCK3_VOUT_1", "fields": [ "BUCK3_VSET1" ] }, { "regID": "BUCK3_VOUT_2", "fields": [ "BUCK3_VSET2" ] }, { "regID": "BUCK3_PG_WINDOW", "fields": [ "BUCK3_OV_THR", "BUCK3_UV_THR" ] }, { "regID": "RAIL_SEL_1", "fields": [ "BUCK3_GRP_SEL" ] }, { "regID": "BUCK_RESET_REG", "fixedFields": [ { "fieldID": "BUCK3_RESET", "value": 0 } ], "hideFields": [ "BUCK3_RESET" ], "fields": [ "BUCK3_RESET" ] }, { "regID": "FREQ_SEL", "hideFields": [ "BUCK3_FREQ_SEL" ], "fields": [ "BUCK3_FREQ_SEL" ] }, { "regID": "BUCK_CONFIG_ANALOG_1", "hideFields": [ "BUCK3_SEL_NEG_OCP_HYST" ], "fields": [ "BUCK3_SEL_NEG_OCP_HYST" ] }, { "regID": "BUCK_CONFIG_DIGITAL_1", "hideFields": [ "BUCK3_SEL_POS_OCP_HYST" ], "fields": [ "BUCK3_SEL_POS_OCP_HYST" ] }, { "regID": "BUCK_CONFIG_ANALOG_5", "hideFields": [ "BUCK3_SEL_ISENSE_SLOPE_COMPENSATION", "BUCK3_SEL_VOUT_ADC_LEVEL" ], "fields": [ "BUCK3_SEL_ISENSE_SLOPE_COMPENSATION", "BUCK3_SEL_VOUT_ADC_LEVEL" ] }, { "regID": "BUCK_CONFIG_DIGITAL_0", "fixedFields": [ { "fieldID": "BUCK3_SEL_PHASE_SHEDD", "value": 0 }, { "fieldID": "BUCK3_SEL_PHASE_ADD", "value": 1 } ], "hideFields": [ "BUCK3_SEL_PHASE_ADD", "BUCK3_SEL_PHASE_SHEDD" ], "fields": [ "BUCK3_SEL_PHASE_ADD", "BUCK3_SEL_PHASE_SHEDD" ] }, { "regID": "BUCK_CONFIG_DIGITAL_4", "hideFields": [ "BUCK3_SEL_OUTPUT_CAPS" ], "fields": [ "BUCK3_SEL_OUTPUT_CAPS" ] }, { "regID": "BUCK_CONFIG_DIGITAL_7", "hideFields": [ "BUCK3_SEL_RAMP" ], "fields": [ "BUCK3_SEL_RAMP" ] }, { "regID": "BUCK_CONFIG_DIGITAL_12", "hideFields": [ "BUCK3_FREQ_8MHZ" ], "fields": [ "BUCK3_FREQ_8MHZ" ] }, { "regID": "BUCK_CONFIG_DIGITAL_13", "hideFields": [ "BUCK3_EN_P_10M_BODY_DIODE" ], "fields": [ "BUCK3_EN_P_10M_BODY_DIODE" ] }, { "regID": "BUCK_CONFIG_DIGITAL_14", "hideFields": [ "BUCK3_DOUBLE_PFM_PULSE" ], "fields": [ "BUCK3_DOUBLE_PFM_PULSE" ] }, { "regID": "BUCK_CONFIG_DIGITAL_15", "hideFields": [ "BUCK3_CHANGE_2MHZ_BELOW_0V5" ], "fields": [ "BUCK3_CHANGE_2MHZ_BELOW_0V5" ] }, { "regID": "BUCK_CONFIG_RADAR", "hideFields": [ "BUCK3_EN_RADAR_MODE" ], "fields": [ "BUCK3_EN_RADAR_MODE" ] }, { "regID": "BUCK3_DTEST_REG_0", "fixedFields": [ { "fieldID": "swc_buck_hiz_3", "value": 0 } ], "hideFields": [ "swc_buck_hiz_3" ], "fields": [ "swc_buck_hiz_3" ] } ], "regConfig": { "question": "Is this rail used for VTT?", "id": "vtt_config", "selectedOption": "yes", "options": [ { "name": "yes", "configurationDisplayName": "2.2MHz Single Phase for DDR Termination", "configuration": "DDR VTT (SP)", "inductor": "470nH" }, { "name": "no", "question": "What is this rail's switching frequency?", "id": "switching_frequency_config", "selectedOption": "4.4MHz", "options": [ { "name": "4.4MHz", "question": "Does this rail want to be optimized for multiphase configuration?", "id": "multiphase_config", "selectedOption": "yes", "options": [ { "name": "yes", "configurationDisplayName": "4.4MHz Multiphase Configuration", "configuration": "4.4MHz HiCur (MP)", "inductor": "220nH" }, { "name": "no", "question": "What is the output of this rail?", "id": "output_rail_config", "selectedOption": "1.8V or less", "options": [ { "name": "1.8V or less", "question": "What is the output capacitance on this rail?", "id": "output_capacitance_config", "selectedOption": "greater than 100 uF", "options": [ { "name": "greater than 100 uF", "configurationDisplayName": "4.4MHz Multiphase Configuration", "configuration": "4.4MHz HiCur (MP)", "inductor": "220nH" }, { "name": "less than 100uF", "configurationDisplayName": "4.4MHz Single Phase Low Output Voltage", "configuration": "4.4MHz LoCur (SP)", "inductor": "220nH" } ] }, { "name": "greater than 1.8V", "configurationDisplayName": "4.4MHz Single Phase High Output Voltage", "configuration": "4.4MHz HiVolt (SP)", "inductor": "470nH" } ] } ] }, { "name": "2.2MHz", "question": "Does this rail want to be optimized for multiphase configuration?", "id": "multiphase_config", "selectedOption": "yes", "options": [ { "name": "yes", "configurationDisplayName": "2.2MHz Multiphase with Full Range VIN", "configuration": "2.2MHz (MP)", "inductor": "470nH" }, { "name": "no", "question": "What is the output of this rail?", "id": "output_rail_config", "selectedOption": "1.8V or less", "options": [ { "name": "1.8V or less", "configurationDisplayName": "2.2MHz Multiphase with Full Range VIN", "configuration": "2.2MHz (MP)", "inductor": "470nH" }, { "name": "full range", "question": "What is the input voltage of this rail?", "id": "input_voltage_config", "selectedOption": "Only greater than 4.5V", "options": [ { "name": "Only greater than 4.5V", "configurationDisplayName": "2.2MHz Single Phase with 5.0V VIN", "configuration": "5Vin (SP)", "inductor": "470nH" }, { "name": "Supports full input voltage range", "configurationDisplayName": "2.2MHz Single Phase with Full Range VIN", "configuration": "2.2MHz (SP)", "inductor": "1000nH" } ] } ] } ] } ] } ] } }, { "name": "Buck4", "registers": [ { "regID": "BUCK4_CTRL", "fixedFields": [ { "fieldID": "BUCK4_EN", "value": 0 }, { "fieldID": "BUCK4_PLDN", "value": 1 }, { "fieldID": "BUCK4_VMON_EN", "value": 0 } ], "hideFields": [ "BUCK4_EN", "BUCK4_PLDN", "BUCK4_VMON_EN" ], "fields": [ "BUCK4_EN", "BUCK4_FPWM", "BUCK4_VSEL", "BUCK4_VMON_EN", "BUCK4_PLDN", "BUCK4_RV_SEL" ] }, { "regID": "BUCK4_CONF", "fields": [ "BUCK4_SLEW_RATE", "BUCK4_ILIM" ] }, { "regID": "BUCK4_VOUT_1", "fields": [ "BUCK4_VSET1" ] }, { "regID": "BUCK4_VOUT_2", "fields": [ "BUCK4_VSET2" ] }, { "regID": "BUCK4_PG_WINDOW", "fields": [ "BUCK4_OV_THR", "BUCK4_UV_THR" ] }, { "regID": "RAIL_SEL_1", "fields": [ "BUCK4_GRP_SEL" ] }, { "regID": "BUCK_RESET_REG", "fixedFields": [ { "fieldID": "BUCK4_RESET", "value": 0 } ], "hideFields": [ "BUCK4_RESET" ], "fields": [ "BUCK4_RESET" ] }, { "regID": "FREQ_SEL", "hideFields": [ "BUCK4_FREQ_SEL" ], "fields": [ "BUCK4_FREQ_SEL" ] }, { "regID": "BUCK_CONFIG_ANALOG_1", "hideFields": [ "BUCK4_SEL_NEG_OCP_HYST" ], "fields": [ "BUCK4_SEL_NEG_OCP_HYST" ] }, { "regID": "BUCK_CONFIG_DIGITAL_1", "hideFields": [ "BUCK4_SEL_POS_OCP_HYST" ], "fields": [ "BUCK4_SEL_POS_OCP_HYST" ] }, { "regID": "BUCK_CONFIG_ANALOG_6", "hideFields": [ "BUCK4_SEL_ISENSE_SLOPE_COMPENSATION", "BUCK4_SEL_VOUT_ADC_LEVEL" ], "fields": [ "BUCK4_SEL_ISENSE_SLOPE_COMPENSATION", "BUCK4_SEL_VOUT_ADC_LEVEL" ] }, { "regID": "BUCK_CONFIG_DIGITAL_4", "hideFields": [ "BUCK4_SEL_OUTPUT_CAPS" ], "fields": [ "BUCK4_SEL_OUTPUT_CAPS" ] }, { "regID": "BUCK_CONFIG_DIGITAL_7", "hideFields": [ "BUCK4_SEL_RAMP" ], "fields": [ "BUCK4_SEL_RAMP" ] }, { "regID": "BUCK_CONFIG_DIGITAL_12", "hideFields": [ "BUCK4_FREQ_8MHZ" ], "fields": [ "BUCK4_FREQ_8MHZ" ] }, { "regID": "BUCK_CONFIG_DIGITAL_13", "hideFields": [ "BUCK4_EN_P_10M_BODY_DIODE" ], "fields": [ "BUCK4_EN_P_10M_BODY_DIODE" ] }, { "regID": "BUCK_CONFIG_DIGITAL_14", "hideFields": [ "BUCK4_DOUBLE_PFM_PULSE" ], "fields": [ "BUCK4_DOUBLE_PFM_PULSE" ] }, { "regID": "BUCK_CONFIG_DIGITAL_15", "hideFields": [ "BUCK4_CHANGE_2MHZ_BELOW_0V5" ], "fields": [ "BUCK4_CHANGE_2MHZ_BELOW_0V5" ] }, { "regID": "BUCK_CONFIG_RADAR", "hideFields": [ "BUCK4_EN_RADAR_MODE" ], "fields": [ "BUCK4_EN_RADAR_MODE" ] }, { "regID": "BUCK4_DTEST_REG_0", "fixedFields": [ { "fieldID": "swc_buck_hiz_4", "value": 0 } ], "hideFields": [ "swc_buck_hiz_4" ], "fields": [ "swc_buck_hiz_4" ] } ], "regConfig": { "question": "Is this rail used for VTT?", "id": "vtt_config", "selectedOption": "yes", "options": [ { "name": "yes", "configurationDisplayName": "2.2MHz Single Phase for DDR Termination", "configuration": "DDR VTT (SP)", "inductor": "470nH" }, { "name": "no", "question": "What is this rail's switching frequency?", "id": "switching_frequency_config", "selectedOption": "4.4MHz", "options": [ { "name": "4.4MHz", "question": "Does this rail want to be optimized for multiphase configuration?", "id": "multiphase_config", "selectedOption": "yes", "options": [ { "name": "yes", "configurationDisplayName": "4.4MHz Multiphase Configuration", "configuration": "4.4MHz HiCur (MP)", "inductor": "220nH" }, { "name": "no", "question": "What is the output of this rail?", "id": "output_rail_config", "selectedOption": "1.8V or less", "options": [ { "name": "1.8V or less", "question": "What is the output capacitance on this rail?", "id": "output_capacitance_config", "selectedOption": "greater than 100 uF", "options": [ { "name": "greater than 100 uF", "configurationDisplayName": "4.4MHz Multiphase Configuration", "configuration": "4.4MHz HiCur (MP)", "inductor": "220nH" }, { "name": "less than 100uF", "configurationDisplayName": "4.4MHz Single Phase Low Output Voltage", "configuration": "4.4MHz LoCur (SP)", "inductor": "220nH" } ] }, { "name": "greater than 1.8V", "configurationDisplayName": "4.4MHz Single Phase High Output Voltage", "configuration": "4.4MHz HiVolt (SP)", "inductor": "470nH" } ] } ] }, { "name": "2.2MHz", "question": "Does this rail want to be optimized for multiphase configuration?", "id": "multiphase_config", "selectedOption": "yes", "options": [ { "name": "yes", "configurationDisplayName": "2.2MHz Multiphase with Full Range VIN", "configuration": "2.2MHz (MP)", "inductor": "470nH" }, { "name": "no", "question": "What is the output of this rail?", "id": "output_rail_config", "selectedOption": "1.8V or less", "options": [ { "name": "1.8V or less", "configurationDisplayName": "2.2MHz Multiphase with Full Range VIN", "configuration": "2.2MHz (MP)", "inductor": "470nH" }, { "name": "full range", "question": "What is the input voltage of this rail?", "id": "input_voltage_config", "selectedOption": "Only greater than 4.5V", "options": [ { "name": "Only greater than 4.5V", "configurationDisplayName": "2.2MHz Single Phase with 5.0V VIN", "configuration": "5Vin (SP)", "inductor": "470nH" }, { "name": "Supports full input voltage range", "configurationDisplayName": "2.2MHz Single Phase with Full Range VIN", "configuration": "2.2MHz (SP)", "inductor": "1000nH" } ] } ] } ] } ] } ] } }, { "name": "Buck5", "type": "visible", "registers": [ { "regID": "BUCK5_CTRL", "fixedFields": [ { "fieldID": "BUCK5_EN", "value": 0 }, { "fieldID": "BUCK5_PLDN", "value": 1 }, { "fieldID": "BUCK5_VMON_EN", "value": 0 } ], "hideFields": [ "BUCK5_EN", "BUCK5_PLDN", "BUCK5_VMON_EN" ], "fields": [ "BUCK5_EN", "BUCK5_FPWM", "BUCK5_VSEL", "BUCK5_VMON_EN", "BUCK5_PLDN", "BUCK5_RV_SEL" ] }, { "regID": "BUCK5_CONF", "fields": [ "BUCK5_SLEW_RATE", "BUCK5_ILIM" ] }, { "regID": "BUCK5_VOUT_1", "fields": [ "BUCK5_VSET1" ] }, { "regID": "BUCK5_VOUT_2", "fields": [ "BUCK5_VSET2" ] }, { "regID": "BUCK5_PG_WINDOW", "fields": [ "BUCK5_OV_THR", "BUCK5_UV_THR" ] }, { "regID": "RAIL_SEL_2", "fields": [ "BUCK5_GRP_SEL" ] }, { "regID": "BUCK_RESET_REG", "fixedFields": [ { "fieldID": "BUCK5_RESET", "value": 0 } ], "hideFields": [ "BUCK5_RESET" ], "fields": [ "BUCK5_RESET" ] }, { "regID": "FREQ_SEL", "hideFields": [ "BUCK5_FREQ_SEL" ], "fields": [ "BUCK5_FREQ_SEL" ] }, { "regID": "BUCK_CONFIG_ANALOG_1", "hideFields": [ "BUCK5_SEL_NEG_OCP_HYST" ], "fields": [ "BUCK5_SEL_NEG_OCP_HYST" ] }, { "regID": "BUCK_CONFIG_DIGITAL_1", "hideFields": [ "BUCK5_SEL_POS_OCP_HYST" ], "fields": [ "BUCK5_SEL_POS_OCP_HYST" ] }, { "regID": "BUCK_CONFIG_ANALOG_7", "hideFields": [ "BUCK5_SEL_ISENSE_SLOPE_COMPENSATION", "BUCK5_SEL_VOUT_ADC_LEVEL" ], "fields": [ "BUCK5_SEL_ISENSE_SLOPE_COMPENSATION", "BUCK5_SEL_VOUT_ADC_LEVEL" ] }, { "regID": "BUCK_CONFIG_DIGITAL_5", "hideFields": [ "BUCK5_SEL_OUTPUT_CAPS" ], "fields": [ "BUCK5_SEL_OUTPUT_CAPS" ] }, { "regID": "BUCK_CONFIG_DIGITAL_7", "hideFields": [ "BUCK5_SEL_RAMP" ], "fields": [ "BUCK5_SEL_RAMP" ] }, { "regID": "BUCK_CONFIG_DIGITAL_12", "hideFields": [ "BUCK5_FREQ_8MHZ" ], "fields": [ "BUCK5_FREQ_8MHZ" ] }, { "regID": "BUCK_CONFIG_DIGITAL_13", "hideFields": [ "BUCK5_EN_P_10M_BODY_DIODE" ], "fields": [ "BUCK5_EN_P_10M_BODY_DIODE" ] }, { "regID": "BUCK_CONFIG_DIGITAL_14", "hideFields": [ "BUCK5_DOUBLE_PFM_PULSE" ], "fields": [ "BUCK5_DOUBLE_PFM_PULSE" ] }, { "regID": "BUCK_CONFIG_DIGITAL_15", "hideFields": [ "BUCK5_CHANGE_2MHZ_BELOW_0V5" ], "fields": [ "BUCK5_CHANGE_2MHZ_BELOW_0V5" ] }, { "regID": "BUCK_CONFIG_RADAR", "hideFields": [ "BUCK5_EN_RADAR_MODE" ], "fields": [ "BUCK5_EN_RADAR_MODE" ] }, { "regID": "BUCK5_DTEST_REG_0", "fixedFields": [ { "fieldID": "swc_buck_hiz_5", "value": 0 } ], "hideFields": [ "swc_buck_hiz_5" ], "fields": [ "swc_buck_hiz_5" ] } ], "regConfig": { "question": "Is this rail used for VTT?", "id": "vtt_config", "selectedOption": "yes", "options": [ { "name": "yes", "configurationDisplayName": "2.2MHz Single Phase for DDR Termination", "configuration": "DDR VTT (SP)", "inductor": "470nH" }, { "name": "no", "question": "What is this rail's switching frequency?", "id": "switching_frequency_config", "selectedOption": "4.4MHz", "options": [ { "name": "4.4MHz", "question": "Does this rail want to be optimized for multiphase configuration?", "id": "multiphase_config", "selectedOption": "yes", "options": [ { "name": "yes", "configurationDisplayName": "4.4MHz Multiphase Configuration", "configuration": "4.4MHz HiCur (MP)", "inductor": "220nH" }, { "name": "no", "question": "What is the output of this rail?", "id": "output_rail_config", "selectedOption": "1.8V or less", "options": [ { "name": "1.8V or less", "question": "What is the output capacitance on this rail?", "id": "output_capacitance_config", "selectedOption": "greater than 100 uF", "options": [ { "name": "greater than 100 uF", "configurationDisplayName": "4.4MHz Multiphase Configuration", "configuration": "4.4MHz HiCur (MP)", "inductor": "220nH" }, { "name": "less than 100uF", "configurationDisplayName": "4.4MHz Single Phase Low Output Voltage", "configuration": "4.4MHz LoCur (SP)", "inductor": "220nH" } ] }, { "name": "greater than 1.8V", "configurationDisplayName": "4.4MHz Single Phase High Output Voltage", "configuration": "4.4MHz HiVolt (SP)", "inductor": "470nH" } ] } ] }, { "name": "2.2MHz", "question": "Does this rail want to be optimized for multiphase configuration?", "id": "multiphase_config", "selectedOption": "yes", "options": [ { "name": "yes", "configurationDisplayName": "2.2MHz Multiphase with Full Range VIN", "configuration": "2.2MHz (MP)", "inductor": "470nH" }, { "name": "no", "question": "What is the output of this rail?", "id": "output_rail_config", "selectedOption": "1.8V or less", "options": [ { "name": "1.8V or less", "configurationDisplayName": "2.2MHz Multiphase with Full Range VIN", "configuration": "2.2MHz (MP)", "inductor": "470nH" }, { "name": "full range", "question": "What is the input voltage of this rail?", "id": "input_voltage_config", "selectedOption": "Only greater than 4.5V", "options": [ { "name": "Only greater than 4.5V", "configurationDisplayName": "2.2MHz Single Phase with 5.0V VIN", "configuration": "5Vin (SP)", "inductor": "470nH" }, { "name": "Supports full input voltage range", "configurationDisplayName": "2.2MHz Single Phase with Full Range VIN", "configuration": "2.2MHz (SP)", "inductor": "1000nH" } ] } ] } ] } ] } ] } }, { "name": "Miscellaneous Buck", "type": "visible", "registers": [ { "regID": "BUCK_CONFIG_ANALOG_0", "fixedFields": [ { "fieldID": "SEL_LOOP_NEG_HYST", "value": 2 }, { "fieldID": "SEL_GATE_EARLY_SENSE", "value": 0 }, { "fieldID": "SEL_TRAD_NON_OVERLAP", "value": 0 } ], "hideFields": [ "SEL_LOOP_NEG_HYST", "SEL_GATE_EARLY_SENSE", "SEL_TRAD_NON_OVERLAP" ], "fields": [ "SEL_LOOP_NEG_HYST", "SEL_GATE_EARLY_SENSE", "SEL_TRAD_NON_OVERLAP" ] }, { "regID": "BUCK_CONFIG_ANALOG_1", "fixedFields": [ { "fieldID": "SEL_FB_FILTER", "value": 3 } ], "hideFields": [ "SEL_FB_FILTER" ], "fields": [ "SEL_FB_FILTER" ] }, { "regID": "BUCK_CONFIG_ANALOG_2", "fixedFields": [ { "fieldID": "SEL_RAMP_ARTIF", "value": 1 } ], "hideFields": [ "SEL_RAMP_ARTIF" ], "fields": [ "SEL_RAMP_ARTIF" ] }, { "regID": "BUCK_CONFIG_ANALOG_8", "fixedFields": [ { "fieldID": "EN_SW_RT_SHORT_DETECTORS", "value": 0 }, { "fieldID": "EN_IAVE_LOOP_INJECTOR", "value": 0 } ], "hideFields": [ "EN_SW_RT_SHORT_DETECTORS", "EN_IAVE_LOOP_INJECTOR" ], "fields": [ "EN_SW_RT_SHORT_DETECTORS", "EN_IAVE_LOOP_INJECTOR" ] }, { "regID": "BUCK_CONFIG_DIGITAL_1", "fixedFields": [ { "fieldID": "EN_PLL_PROP_EXTEND", "value": 1 }, { "fieldID": "EN_SMART_OCP_BLANK", "value": 1 } ], "hideFields": [ "EN_PLL_PROP_EXTEND", "EN_SMART_OCP_BLANK" ], "fields": [ "EN_PLL_PROP_EXTEND", "EN_SMART_OCP_BLANK" ] }, { "regID": "BUCK_CONFIG_DIGITAL_2", "fixedFields": [ { "fieldID": "SEL_HS_DETECTOR", "value": 1 }, { "fieldID": "EN_LONG_PFM_EXIT_CNTR", "value": 1 } ], "hideFields": [ "SEL_HS_DETECTOR", "EN_LONG_PFM_EXIT_CNTR" ], "fields": [ "SEL_HS_DETECTOR", "EN_LONG_PFM_EXIT_CNTR" ] }, { "regID": "BUCK_CONFIG_DIGITAL_3", "fixedFields": [ { "fieldID": "EN_NEG_OCP", "value": 1 }, { "fieldID": "EN_POS_OCP", "value": 1 }, { "fieldID": "EN_PFM_LOAD", "value": 1 }, { "fieldID": "EN_DOT_MODE", "value": 1 } ], "hideFields": [ "DOUBLE_PFM_PULSE", "EN_P_10M_BODY_DIODE", "EN_NEG_OCP", "EN_POS_OCP", "EN_PFM_LOAD", "EN_DOT_MODE" ], "fields": [ "EN_DOT_MODE", "EN_PFM_LOAD", "DOUBLE_PFM_PULSE", "EN_P_10M_BODY_DIODE", "EN_POS_OCP", "EN_NEG_OCP" ] }, { "regID": "BUCK_CONFIG_DIGITAL_5", "fixedFields": [ { "fieldID": "EN_AUTO_LOOP_COEFFS", "value": 1 }, { "fieldID": "LOOP_COEFF_FB_MSB", "value": 1 }, { "fieldID": "LOOP_COEFF_I_BALANCE", "value": 1 }, { "fieldID": "SEL_ZERO_CROSS_FILTER_AVE", "value": 1 }, { "fieldID": "EN_LONG_ZERO_CROSS_FILTER", "value": 0 } ], "hideFields": [ "EN_AUTO_LOOP_COEFFS", "LOOP_COEFF_FB_MSB", "LOOP_COEFF_I_BALANCE", "SEL_ZERO_CROSS_FILTER_AVE", "EN_LONG_ZERO_CROSS_FILTER" ], "fields": [ "EN_AUTO_LOOP_COEFFS", "LOOP_COEFF_FB_MSB", "LOOP_COEFF_I_BALANCE", "SEL_ZERO_CROSS_FILTER_AVE", "EN_LONG_ZERO_CROSS_FILTER" ] }, { "regID": "BUCK_CONFIG_DIGITAL_6", "fixedFields": [ { "fieldID": "EN_PFM_PULSE_WAIT_LS_OCP", "value": 1 }, { "fieldID": "EN_SLOW_PLL_COEFFS", "value": 0 }, { "fieldID": "FORCE_SS_ADAPT", "value": 0 } ], "hideFields": [ "EN_PFM_PULSE_WAIT_LS_OCP", "EN_SLOW_PLL_COEFFS", "FORCE_SS_ADAPT" ], "fields": [ "EN_PFM_PULSE_WAIT_LS_OCP", "EN_SLOW_PLL_COEFFS", "FORCE_SS_ADAPT" ] }, { "regID": "BUCK_CONFIG_DIGITAL_7", "fixedFields": [ { "fieldID": "EN_FAST_PLL_0P7", "value": 1 }, { "fieldID": "EN_SW_SHORT_DETECTORS", "value": 1 } ], "hideFields": [ "EN_FAST_PLL_0P7", "EN_SW_SHORT_DETECTORS" ], "fields": [ "EN_FAST_PLL_0P7", "EN_SW_SHORT_DETECTORS" ] }, { "regID": "BUCK_CONFIG_DIGITAL_8", "fixedFields": [ { "fieldID": "EN_FAST_VOUT_INTEGRATION", "value": 1 }, { "fieldID": "EN_I_BALANCE_INTEGRATOR", "value": 1 }, { "fieldID": "DIS_PFM_WAITS_LS_DETECTOR", "value": 0 }, { "fieldID": "DIS_PFM_WAITS_HS_DETECTOR", "value": 0 }, { "fieldID": "DIS_DVS_WAIT_COMPARATORS", "value": 0 }, { "fieldID": "EN_SLOW_PLL_0P3", "value": 1 }, { "fieldID": "EN_CONSTANT_PLL_DVS_COEFF", "value": 0 } ], "hideFields": [ "EN_FAST_VOUT_INTEGRATION", "EN_I_BALANCE_INTEGRATOR", "DIS_PFM_WAITS_LS_DETECTOR", "DIS_PFM_WAITS_HS_DETECTOR", "DIS_DVS_WAIT_COMPARATORS", "EN_CONSTANT_PLL_DVS_COEFF", "EN_SLOW_PLL_0P3" ], "fields": [ "EN_FAST_VOUT_INTEGRATION", "EN_I_BALANCE_INTEGRATOR", "DIS_PFM_WAITS_LS_DETECTOR", "DIS_PFM_WAITS_HS_DETECTOR", "DIS_DVS_WAIT_COMPARATORS", "EN_CONSTANT_PLL_DVS_COEFF", "EN_SLOW_PLL_0P3" ] }, { "regID": "BUCK_CONFIG_DIGITAL_9", "fixedFields": [ { "fieldID": "EN_M_10M_TRAN_DETECTOR", "value": 1 }, { "fieldID": "EN_LS_AFTER_HIZ", "value": 0 }, { "fieldID": "EN_PWM_LS_DETECTION", "value": 0 }, { "fieldID": "I_COEFF", "value": 1 }, { "fieldID": "EN_FAST_INTEGRATION_BYPASS_RAMP_RES", "value": 1 } ], "hideFields": [ "EN_M_10M_TRAN_DETECTOR", "EN_LS_AFTER_HIZ", "EN_PWM_LS_DETECTION", "I_COEFF", "EN_FAST_INTEGRATION_BYPASS_RAMP_RES" ], "fields": [ "EN_M_10M_TRAN_DETECTOR", "EN_LS_AFTER_HIZ", "EN_PWM_LS_DETECTION", "I_COEFF", "EN_FAST_INTEGRATION_BYPASS_RAMP_RES" ] }, { "regID": "BUCK_CONFIG_DIGITAL_10", "fixedFields": [ { "fieldID": "BUCK_NEG_ILIM", "value": 1 }, { "fieldID": "EN_ADAPTIVE_SINGLE_SHOT", "value": 1 } ], "hideFields": [ "BUCK_NEG_ILIM", "EN_ADAPTIVE_SINGLE_SHOT" ], "fields": [ "BUCK_NEG_ILIM", "EN_ADAPTIVE_SINGLE_SHOT" ] }, { "regID": "BUCK_CONFIG_DIGITAL_11", "fixedFields": [ { "fieldID": "FIXED_SS_LENGTH", "value": 24 }, { "fieldID": "LONG_SINGLE_SHOT", "value": 1 } ], "hideFields": [ "FIXED_SS_LENGTH", "LONG_SINGLE_SHOT" ], "fields": [ "FIXED_SS_LENGTH", "LONG_SINGLE_SHOT" ] } ] } ] } ] }, "registerJSON": { "regblocks": [ { "id": "UserRegisters1-user_mem", "registers": [ { "id": "DEV_REV", "value": "0", "fields": [ { "id": "TI_DEVICE_ID", "value": "0", "staticConfig": true } ] }, { "id": "NVM_CODE_1", "value": "0", "fields": [ { "id": "TI_NVM_ID", "value": "0", "staticConfig": true } ] }, { "id": "NVM_CODE_2", "value": "0", "fields": [ { "id": "TI_NVM_REV", "value": "0", "staticConfig": true } ] }, { "id": "BUCK1_CTRL", "value": "0", "fields": [ { "id": "BUCK1_EN", "value": 0 }, { "id": "BUCK1_FPWM", "value": "0" }, { "id": "BUCK1_FPWM_MP", "value": "0" }, { "id": "BUCK1_VMON_EN", "value": 0 }, { "id": "BUCK1_VSEL", "value": "0" }, { "id": "BUCK1_PLDN", "value": 1 }, { "id": "BUCK1_RV_SEL", "value": "0" } ] }, { "id": "BUCK1_CONF", "value": "0x22", "fields": [ { "id": "BUCK1_SLEW_RATE", "value": "2" }, { "id": "BUCK1_ILIM", "value": "4" } ] }, { "id": "BUCK2_CTRL", "value": "0", "fields": [ { "id": "BUCK2_EN", "value": 0 }, { "id": "BUCK2_FPWM", "value": 0 }, { "id": "BUCK2_VMON_EN", "value": 0 }, { "id": "BUCK2_VSEL", "value": 0 }, { "id": "BUCK2_PLDN", "value": 1 }, { "id": "BUCK2_RV_SEL", "value": 0 } ] }, { "id": "BUCK2_CONF", "value": "0x22", "fields": [ { "id": "BUCK2_SLEW_RATE", "value": 2 }, { "id": "BUCK2_ILIM", "value": 4 } ] }, { "id": "BUCK3_CTRL", "value": "0", "fields": [ { "id": "BUCK3_EN", "value": 0 }, { "id": "BUCK3_FPWM", "value": "0" }, { "id": "BUCK3_FPWM_MP", "value": "0" }, { "id": "BUCK3_VMON_EN", "value": 0 }, { "id": "BUCK3_VSEL", "value": "0" }, { "id": "BUCK3_PLDN", "value": 1 }, { "id": "BUCK3_RV_SEL", "value": "0" } ] }, { "id": "BUCK3_CONF", "value": "0x22", "fields": [ { "id": "BUCK3_SLEW_RATE", "value": "2" }, { "id": "BUCK3_ILIM", "value": "4" } ] }, { "id": "BUCK4_CTRL", "value": "0", "fields": [ { "id": "BUCK4_EN", "value": 0 }, { "id": "BUCK4_FPWM", "value": "0" }, { "id": "BUCK4_VMON_EN", "value": 0 }, { "id": "BUCK4_VSEL", "value": "0" }, { "id": "BUCK4_PLDN", "value": 1 }, { "id": "BUCK4_RV_SEL", "value": "0" } ] }, { "id": "BUCK4_CONF", "value": "0x22", "fields": [ { "id": "BUCK4_SLEW_RATE", "value": "2" }, { "id": "BUCK4_ILIM", "value": "4" } ] }, { "id": "BUCK5_CTRL", "value": "0", "fields": [ { "id": "BUCK5_EN", "value": 0 }, { "id": "BUCK5_FPWM", "value": "0" }, { "id": "BUCK5_VMON_EN", "value": 0 }, { "id": "BUCK5_VSEL", "value": "0" }, { "id": "BUCK5_PLDN", "value": 1 }, { "id": "BUCK5_RV_SEL", "value": "0" } ] }, { "id": "BUCK5_CONF", "value": "0x22", "fields": [ { "id": "BUCK5_SLEW_RATE", "value": "2" }, { "id": "BUCK5_ILIM", "value": "2" } ] }, { "id": "BUCK1_VOUT_1", "value": "0", "fields": [ { "id": "BUCK1_VSET1", "value": "0" } ] }, { "id": "BUCK1_VOUT_2", "value": "0", "fields": [ { "id": "BUCK1_VSET2", "value": "0" } ] }, { "id": "BUCK2_VOUT_1", "value": "0", "fields": [ { "id": "BUCK2_VSET1", "value": 0 } ] }, { "id": "BUCK2_VOUT_2", "value": "0", "fields": [ { "id": "BUCK2_VSET2", "value": 0 } ] }, { "id": "BUCK3_VOUT_1", "value": "0", "fields": [ { "id": "BUCK3_VSET1", "value": "0" } ] }, { "id": "BUCK3_VOUT_2", "value": "0", "fields": [ { "id": "BUCK3_VSET2", "value": "0" } ] }, { "id": "BUCK4_VOUT_1", "value": "0", "fields": [ { "id": "BUCK4_VSET1", "value": "0" } ] }, { "id": "BUCK4_VOUT_2", "value": "0", "fields": [ { "id": "BUCK4_VSET2", "value": "0" } ] }, { "id": "BUCK5_VOUT_1", "value": "0", "fields": [ { "id": "BUCK5_VSET1", "value": "0" } ] }, { "id": "BUCK5_VOUT_2", "value": "0", "fields": [ { "id": "BUCK5_VSET2", "value": "0" } ] }, { "id": "BUCK1_PG_WINDOW", "value": "0", "fields": [ { "id": "BUCK1_OV_THR", "value": "0" }, { "id": "BUCK1_UV_THR", "value": "0" } ] }, { "id": "BUCK2_PG_WINDOW", "value": "0", "fields": [ { "id": "BUCK2_OV_THR", "value": 0 }, { "id": "BUCK2_UV_THR", "value": 0 } ] }, { "id": "BUCK3_PG_WINDOW", "value": "0", "fields": [ { "id": "BUCK3_OV_THR", "value": "0" }, { "id": "BUCK3_UV_THR", "value": "0" } ] }, { "id": "BUCK4_PG_WINDOW", "value": "0", "fields": [ { "id": "BUCK4_OV_THR", "value": "0" }, { "id": "BUCK4_UV_THR", "value": "0" } ] }, { "id": "BUCK5_PG_WINDOW", "value": "0", "fields": [ { "id": "BUCK5_OV_THR", "value": "0" }, { "id": "BUCK5_UV_THR", "value": "0" } ] }, { "id": "LDO1_CTRL", "value": "0", "fields": [ { "id": "LDO1_EN", "value": 0 }, { "id": "LDO1_PLDN", "value": "0" }, { "id": "LDO1_VMON_EN", "value": 0 }, { "id": "LDO1_RV_SEL", "value": "0" }, { "id": "LDO1_SLOW_RAMP", "value": "0" } ] }, { "id": "LDO2_CTRL", "value": "0", "fields": [ { "id": "LDO2_EN", "value": 0 }, { "id": "LDO2_PLDN", "value": "0" }, { "id": "LDO2_VMON_EN", "value": 0 }, { "id": "LDO2_RV_SEL", "value": "0" }, { "id": "LDO2_SLOW_RAMP", "value": "0" } ] }, { "id": "LDO3_CTRL", "value": "0", "fields": [ { "id": "LDO3_EN", "value": 0 }, { "id": "LDO3_PLDN", "value": "0" }, { "id": "LDO3_VMON_EN", "value": 0 }, { "id": "LDO3_RV_SEL", "value": "0" }, { "id": "LDO3_SLOW_RAMP", "value": "0" } ] }, { "id": "LDO4_CTRL", "value": "0", "fields": [ { "id": "LDO4_EN", "value": 0 }, { "id": "LDO4_PLDN", "value": "0" }, { "id": "LDO4_VMON_EN", "value": 0 }, { "id": "LDO4_RV_SEL", "value": "0" }, { "id": "LDO4_SLOW_RAMP", "value": "0" } ] }, { "id": "LDOINT_CTRL", "value": "0", "fields": [ { "id": "LDOINT_DIS", "value": "0" } ] }, { "id": "LDORTC_CTRL", "value": "0", "fields": [ { "id": "LDORTC_DIS", "value": "0" } ] }, { "id": "LDO1_VOUT", "value": "0", "fields": [ { "id": "LDO1_VSET", "value": "4" }, { "id": "LDO1_BYPASS", "value": "0" } ] }, { "id": "LDO2_VOUT", "value": "0", "fields": [ { "id": "LDO2_VSET", "value": "4" }, { "id": "LDO2_BYPASS", "value": "0" } ] }, { "id": "LDO3_VOUT", "value": "0", "fields": [ { "id": "LDO3_VSET", "value": "4" }, { "id": "LDO3_BYPASS", "value": "0" } ] }, { "id": "LDO4_VOUT", "value": "0", "fields": [ { "id": "LDO4_VSET", "value": "32" } ] }, { "id": "LDO1_PG_WINDOW", "value": "0", "fields": [ { "id": "LDO1_OV_THR", "value": "0" }, { "id": "LDO1_UV_THR", "value": "0" } ] }, { "id": "LDO2_PG_WINDOW", "value": "0", "fields": [ { "id": "LDO2_OV_THR", "value": "0" }, { "id": "LDO2_UV_THR", "value": "0" } ] }, { "id": "LDO3_PG_WINDOW", "value": "0", "fields": [ { "id": "LDO3_OV_THR", "value": "0" }, { "id": "LDO3_UV_THR", "value": "0" } ] }, { "id": "LDO4_PG_WINDOW", "value": "0", "fields": [ { "id": "LDO4_OV_THR", "value": "0" }, { "id": "LDO4_UV_THR", "value": "0" } ] }, { "id": "VCCA_VMON_CTRL", "value": "0", "fields": [ { "id": "VCCA_VMON_EN", "value": "0" }, { "id": "VMON_DEGLITCH_SEL", "value": "0" } ] }, { "id": "VCCA_PG_WINDOW", "value": "0", "fields": [ { "id": "VCCA_OV_THR", "value": "0" }, { "id": "VCCA_UV_THR", "value": "0" }, { "id": "VCCA_PG_SET", "value": "0" } ] }, { "id": "GPIO1_CONF", "value": "0", "fields": [ { "id": "GPIO1_OD", "value": "0" }, { "id": "GPIO1_DIR", "value": "0" }, { "id": "GPIO1_SEL", "value": "0" }, { "id": "GPIO1_PU_SEL", "value": "0" }, { "id": "GPIO1_PU_PD_EN", "value": "0" }, { "id": "GPIO1_DEGLITCH_EN", "value": "0" } ] }, { "id": "GPIO2_CONF", "value": "0", "fields": [ { "id": "GPIO2_OD", "value": "0" }, { "id": "GPIO2_DIR", "value": "0" }, { "id": "GPIO2_SEL", "value": "0" }, { "id": "GPIO2_PU_SEL", "value": "0" }, { "id": "GPIO2_PU_PD_EN", "value": "0" }, { "id": "GPIO2_DEGLITCH_EN", "value": "0" } ] }, { "id": "GPIO3_CONF", "value": "0", "fields": [ { "id": "GPIO3_OD", "value": "0" }, { "id": "GPIO3_DIR", "value": "0" }, { "id": "GPIO3_SEL", "value": "0" }, { "id": "GPIO3_PU_SEL", "value": "0" }, { "id": "GPIO3_PU_PD_EN", "value": "0" }, { "id": "GPIO3_DEGLITCH_EN", "value": "0" } ] }, { "id": "GPIO4_CONF", "value": "0", "fields": [ { "id": "GPIO4_OD", "value": "0" }, { "id": "GPIO4_DIR", "value": "0" }, { "id": "GPIO4_SEL", "value": "0" }, { "id": "GPIO4_PU_SEL", "value": "0" }, { "id": "GPIO4_PU_PD_EN", "value": "0" }, { "id": "GPIO4_DEGLITCH_EN", "value": "0" } ] }, { "id": "GPIO5_CONF", "value": "0", "fields": [ { "id": "GPIO5_OD", "value": "0" }, { "id": "GPIO5_DIR", "value": "0" }, { "id": "GPIO5_SEL", "value": "0" }, { "id": "GPIO5_PU_SEL", "value": "0" }, { "id": "GPIO5_PU_PD_EN", "value": "0" }, { "id": "GPIO5_DEGLITCH_EN", "value": "0" } ] }, { "id": "GPIO6_CONF", "value": "0", "fields": [ { "id": "GPIO6_OD", "value": "0" }, { "id": "GPIO6_DIR", "value": "0" }, { "id": "GPIO6_SEL", "value": "0" }, { "id": "GPIO6_PU_SEL", "value": "0" }, { "id": "GPIO6_PU_PD_EN", "value": "0" }, { "id": "GPIO6_DEGLITCH_EN", "value": "0" } ] }, { "id": "GPIO7_CONF", "value": "0", "fields": [ { "id": "GPIO7_OD", "value": "0" }, { "id": "GPIO7_DIR", "value": "0" }, { "id": "GPIO7_SEL", "value": "0" }, { "id": "GPIO7_PU_SEL", "value": "0" }, { "id": "GPIO7_PU_PD_EN", "value": "0" }, { "id": "GPIO7_DEGLITCH_EN", "value": "0" } ] }, { "id": "GPIO8_CONF", "value": "0", "fields": [ { "id": "GPIO8_OD", "value": "0" }, { "id": "GPIO8_DIR", "value": "0" }, { "id": "GPIO8_SEL", "value": "0" }, { "id": "GPIO8_PU_SEL", "value": "0" }, { "id": "GPIO8_PU_PD_EN", "value": "0" }, { "id": "GPIO8_DEGLITCH_EN", "value": "0" } ] }, { "id": "GPIO9_CONF", "value": "0", "fields": [ { "id": "GPIO9_OD", "value": "0" }, { "id": "GPIO9_DIR", "value": "0" }, { "id": "GPIO9_SEL", "value": "0" }, { "id": "GPIO9_PU_SEL", "value": "0" }, { "id": "GPIO9_PU_PD_EN", "value": "0" }, { "id": "GPIO9_DEGLITCH_EN", "value": "0" } ] }, { "id": "GPIO10_CONF", "value": "0", "fields": [ { "id": "GPIO10_OD", "value": "0" }, { "id": "GPIO10_DIR", "value": "0" }, { "id": "GPIO10_SEL", "value": "0" }, { "id": "GPIO10_PU_SEL", "value": "0" }, { "id": "GPIO10_PU_PD_EN", "value": "0" }, { "id": "GPIO10_DEGLITCH_EN", "value": "0" } ] }, { "id": "GPIO11_CONF", "value": "0", "fields": [ { "id": "GPIO11_OD", "value": "0" }, { "id": "GPIO11_DIR", "value": "0" }, { "id": "GPIO11_SEL", "value": "0" }, { "id": "GPIO11_PU_SEL", "value": "0" }, { "id": "GPIO11_PU_PD_EN", "value": "0" }, { "id": "GPIO11_DEGLITCH_EN", "value": "0" } ] }, { "id": "NPWRON_CONF", "value": "0", "fields": [ { "id": "NPWRON_SEL", "value": "0" }, { "id": "ENABLE_PU_SEL", "value": "0" }, { "id": "ENABLE_PU_PD_EN", "value": "0" }, { "id": "ENABLE_DEGLITCH_EN", "value": "0" }, { "id": "ENABLE_POL", "value": "0" }, { "id": "NRSTOUT_OD", "value": "0" } ] }, { "id": "GPIO_OUT_1", "value": "0", "fields": [ { "id": "GPIO1_OUT", "value": 0 }, { "id": "GPIO2_OUT", "value": 0 }, { "id": "GPIO3_OUT", "value": 0 }, { "id": "GPIO4_OUT", "value": 0 }, { "id": "GPIO5_OUT", "value": 0 }, { "id": "GPIO6_OUT", "value": 0 }, { "id": "GPIO7_OUT", "value": 0 }, { "id": "GPIO8_OUT", "value": 0 } ] }, { "id": "GPIO_OUT_2", "value": "0", "fields": [ { "id": "GPIO9_OUT", "value": 0 }, { "id": "GPIO10_OUT", "value": 0 }, { "id": "GPIO11_OUT", "value": 0 } ] }, { "id": "GPIO_IN_1", "value": "0", "fields": [ { "id": "GPIO1_IN", "value": "0" }, { "id": "GPIO2_IN", "value": "0" }, { "id": "GPIO3_IN", "value": "0" }, { "id": "GPIO4_IN", "value": "0" }, { "id": "GPIO5_IN", "value": "0" }, { "id": "GPIO6_IN", "value": "0" }, { "id": "GPIO7_IN", "value": "0" }, { "id": "GPIO8_IN", "value": "0" } ] }, { "id": "GPIO_IN_2", "value": "0", "fields": [ { "id": "GPIO9_IN", "value": "0" }, { "id": "GPIO10_IN", "value": "0" }, { "id": "GPIO11_IN", "value": "0" }, { "id": "NPWRON_IN", "value": "0" } ] }, { "id": "RAIL_SEL_1", "value": "0", "fields": [ { "id": "BUCK1_GRP_SEL", "value": "0" }, { "id": "BUCK2_GRP_SEL", "value": 0 }, { "id": "BUCK3_GRP_SEL", "value": 0 }, { "id": "BUCK4_GRP_SEL", "value": 0 } ] }, { "id": "RAIL_SEL_2", "value": "0", "fields": [ { "id": "BUCK5_GRP_SEL", "value": "0" }, { "id": "LDO1_GRP_SEL", "value": "0" }, { "id": "LDO2_GRP_SEL", "value": "0" }, { "id": "LDO3_GRP_SEL", "value": "0" } ] }, { "id": "RAIL_SEL_3", "value": "0", "fields": [ { "id": "LDO4_GRP_SEL", "value": "0" }, { "id": "VCCA_GRP_SEL", "value": "0" } ] }, { "id": "FSM_TRIG_SEL_1", "value": "0", "fields": [ { "id": "MCU_RAIL_TRIG", "value": "0" }, { "id": "SOC_RAIL_TRIG", "value": "0" }, { "id": "OTHER_RAIL_TRIG", "value": "0" }, { "id": "SEVERE_ERR_TRIG", "value": "0" } ] }, { "id": "FSM_TRIG_SEL_2", "value": "0", "fields": [ { "id": "MODERATE_ERR_TRIG", "value": "0" } ] }, { "id": "FSM_TRIG_MASK_1", "value": "0", "fields": [ { "id": "GPIO1_FSM_MASK", "value": "0" }, { "id": "GPIO1_FSM_MASK_POL", "value": "0" }, { "id": "GPIO2_FSM_MASK", "value": "0" }, { "id": "GPIO2_FSM_MASK_POL", "value": "0" }, { "id": "GPIO3_FSM_MASK", "value": "0" }, { "id": "GPIO3_FSM_MASK_POL", "value": "0" }, { "id": "GPIO4_FSM_MASK", "value": "0" }, { "id": "GPIO4_FSM_MASK_POL", "value": "0" } ] }, { "id": "FSM_TRIG_MASK_2", "value": "0", "fields": [ { "id": "GPIO5_FSM_MASK", "value": "0" }, { "id": "GPIO5_FSM_MASK_POL", "value": "0" }, { "id": "GPIO6_FSM_MASK", "value": "0" }, { "id": "GPIO6_FSM_MASK_POL", "value": "0" }, { "id": "GPIO7_FSM_MASK", "value": "0" }, { "id": "GPIO7_FSM_MASK_POL", "value": "0" }, { "id": "GPIO8_FSM_MASK", "value": "0" }, { "id": "GPIO8_FSM_MASK_POL", "value": "0" } ] }, { "id": "FSM_TRIG_MASK_3", "value": "0", "fields": [ { "id": "GPIO9_FSM_MASK", "value": "0" }, { "id": "GPIO9_FSM_MASK_POL", "value": "0" }, { "id": "GPIO10_FSM_MASK", "value": "0" }, { "id": "GPIO10_FSM_MASK_POL", "value": "0" }, { "id": "GPIO11_FSM_MASK", "value": "0" }, { "id": "GPIO11_FSM_MASK_POL", "value": "0" } ] }, { "id": "MASK_BUCK1_2", "value": "0", "fields": [ { "id": "BUCK1_ILIM_MASK", "value": "0" }, { "id": "BUCK1_OV_MASK", "value": "0" }, { "id": "BUCK1_UV_MASK", "value": "0" }, { "id": "BUCK2_ILIM_MASK", "value": "0" }, { "id": "BUCK2_OV_MASK", "value": "0" }, { "id": "BUCK2_UV_MASK", "value": "0" } ] }, { "id": "MASK_BUCK3_4", "value": "0", "fields": [ { "id": "BUCK3_ILIM_MASK", "value": "0" }, { "id": "BUCK3_OV_MASK", "value": "0" }, { "id": "BUCK3_UV_MASK", "value": "0" }, { "id": "BUCK4_OV_MASK", "value": "0" }, { "id": "BUCK4_UV_MASK", "value": "0" }, { "id": "BUCK4_ILIM_MASK", "value": "0" } ] }, { "id": "MASK_BUCK5", "value": "0", "fields": [ { "id": "BUCK5_ILIM_MASK", "value": "0" }, { "id": "BUCK5_OV_MASK", "value": "0" }, { "id": "BUCK5_UV_MASK", "value": "0" } ] }, { "id": "MASK_LDO1_2", "value": "0", "fields": [ { "id": "LDO1_OV_MASK", "value": "0" }, { "id": "LDO1_UV_MASK", "value": "0" }, { "id": "LDO2_OV_MASK", "value": "0" }, { "id": "LDO2_UV_MASK", "value": "0" }, { "id": "LDO1_ILIM_MASK", "value": "0" }, { "id": "LDO2_ILIM_MASK", "value": "0" } ] }, { "id": "MASK_LDO3_4", "value": "0", "fields": [ { "id": "LDO3_OV_MASK", "value": "0" }, { "id": "LDO3_UV_MASK", "value": "0" }, { "id": "LDO4_OV_MASK", "value": "0" }, { "id": "LDO4_UV_MASK", "value": "0" }, { "id": "LDO3_ILIM_MASK", "value": "0" }, { "id": "LDO4_ILIM_MASK", "value": "0" } ] }, { "id": "MASK_VMON", "value": "0", "fields": [ { "id": "VCCA_OV_MASK", "value": "0" }, { "id": "VCCA_UV_MASK", "value": "0" } ] }, { "id": "MASK_GPIO1_8_FALL", "value": "0", "fields": [ { "id": "GPIO1_FALL_MASK", "value": "0" }, { "id": "GPIO2_FALL_MASK", "value": "0" }, { "id": "GPIO3_FALL_MASK", "value": "0" }, { "id": "GPIO4_FALL_MASK", "value": "0" }, { "id": "GPIO5_FALL_MASK", "value": "0" }, { "id": "GPIO6_FALL_MASK", "value": "0" }, { "id": "GPIO7_FALL_MASK", "value": "0" }, { "id": "GPIO8_FALL_MASK", "value": "0" } ] }, { "id": "MASK_GPIO1_8_RISE", "value": "0", "fields": [ { "id": "GPIO1_RISE_MASK", "value": "0" }, { "id": "GPIO2_RISE_MASK", "value": "0" }, { "id": "GPIO3_RISE_MASK", "value": "0" }, { "id": "GPIO4_RISE_MASK", "value": "0" }, { "id": "GPIO5_RISE_MASK", "value": "0" }, { "id": "GPIO6_RISE_MASK", "value": "0" }, { "id": "GPIO7_RISE_MASK", "value": "0" }, { "id": "GPIO8_RISE_MASK", "value": "0" } ] }, { "id": "MASK_GPIO9_11", "value": "0", "fields": [ { "id": "GPIO9_FALL_MASK", "value": "0" }, { "id": "GPIO9_RISE_MASK", "value": "0" }, { "id": "GPIO10_FALL_MASK", "value": "0" }, { "id": "GPIO11_FALL_MASK", "value": "0" }, { "id": "GPIO10_RISE_MASK", "value": "0" }, { "id": "GPIO11_RISE_MASK", "value": "0" } ] }, { "id": "MASK_STARTUP", "value": "0", "fields": [ { "id": "NPWRON_START_MASK", "value": "0" }, { "id": "ENABLE_MASK", "value": "0" }, { "id": "FSD_MASK", "value": "0" }, { "id": "SOFT_REBOOT_MASK", "value": "0" } ] }, { "id": "MASK_MISC", "value": "0", "fields": [ { "id": "TWARN_MASK", "value": "0" }, { "id": "BIST_PASS_MASK", "value": "0" }, { "id": "EXT_CLK_MASK", "value": "0" } ] }, { "id": "MASK_MODERATE_ERR", "value": "0", "fields": [ { "id": "BIST_FAIL_MASK", "value": "0" }, { "id": "REG_CRC_ERR_MASK", "value": "0" }, { "id": "SPMI_ERR_MASK", "value": "0" }, { "id": "NPWRON_LONG_MASK", "value": "0" }, { "id": "NINT_READBACK_MASK", "value": "0" }, { "id": "NRSTOUT_READBACK_MASK", "value": "0" } ] }, { "id": "MASK_FSM_ERR", "value": "0", "fields": [ { "id": "IMM_SHUTDOWN_MASK", "value": "0" }, { "id": "MCU_PWR_ERR_MASK", "value": "0" }, { "id": "SOC_PWR_ERR_MASK", "value": "0" }, { "id": "ORD_SHUTDOWN_MASK", "value": "0" } ] }, { "id": "MASK_COMM_ERR", "value": "0", "fields": [ { "id": "COMM_FRM_ERR_MASK", "value": "0" }, { "id": "COMM_CRC_ERR_MASK", "value": "0" }, { "id": "COMM_ADR_ERR_MASK", "value": "0" }, { "id": "I2C2_CRC_ERR_MASK", "value": "0" }, { "id": "I2C2_ADR_ERR_MASK", "value": "0" } ] }, { "id": "MASK_READBACK_ERR", "value": "0", "fields": [ { "id": "EN_DRV_READBACK_MASK", "value": "0" }, { "id": "NRSTOUT_SOC_READBACK_MASK", "value": "0" } ] }, { "id": "MASK_ESM", "value": "0", "fields": [ { "id": "ESM_SOC_PIN_MASK", "value": "0" }, { "id": "ESM_SOC_RST_MASK", "value": "0" }, { "id": "ESM_SOC_FAIL_MASK", "value": "0" }, { "id": "ESM_MCU_PIN_MASK", "value": "0" }, { "id": "ESM_MCU_RST_MASK", "value": "0" }, { "id": "ESM_MCU_FAIL_MASK", "value": "0" } ] }, { "id": "INT_TOP", "value": "0", "fields": [ { "id": "MODERATE_ERR_INT", "value": "0" }, { "id": "GPIO_INT", "value": "0" }, { "id": "SEVERE_ERR_INT", "value": "0" }, { "id": "BUCK_INT", "value": "0" }, { "id": "LDO_VMON_INT", "value": "0" }, { "id": "FSM_ERR_INT", "value": "0" }, { "id": "STARTUP_INT", "value": "0" }, { "id": "MISC_INT", "value": "0" } ] }, { "id": "INT_BUCK", "value": "0", "fields": [ { "id": "BUCK1_2_INT", "value": "0" }, { "id": "BUCK3_4_INT", "value": "0" }, { "id": "BUCK5_INT", "value": "0" } ] }, { "id": "INT_BUCK1_2", "value": "0", "fields": [ { "id": "BUCK1_OV_INT", "value": "0" }, { "id": "BUCK1_UV_INT", "value": "0" }, { "id": "BUCK1_ILIM_INT", "value": "0" }, { "id": "BUCK1_SC_INT", "value": "0" }, { "id": "BUCK2_OV_INT", "value": "0" }, { "id": "BUCK2_UV_INT", "value": "0" }, { "id": "BUCK2_SC_INT", "value": "0" }, { "id": "BUCK2_ILIM_INT", "value": "0" } ] }, { "id": "INT_BUCK3_4", "value": "0", "fields": [ { "id": "BUCK3_OV_INT", "value": "0" }, { "id": "BUCK3_UV_INT", "value": "0" }, { "id": "BUCK3_ILIM_INT", "value": "0" }, { "id": "BUCK3_SC_INT", "value": "0" }, { "id": "BUCK4_OV_INT", "value": "0" }, { "id": "BUCK4_UV_INT", "value": "0" }, { "id": "BUCK4_SC_INT", "value": "0" }, { "id": "BUCK4_ILIM_INT", "value": "0" } ] }, { "id": "INT_BUCK5", "value": "0", "fields": [ { "id": "BUCK5_OV_INT", "value": "0" }, { "id": "BUCK5_UV_INT", "value": "0" }, { "id": "BUCK5_ILIM_INT", "value": "0" }, { "id": "BUCK5_SC_INT", "value": "0" } ] }, { "id": "INT_LDO_VMON", "value": "0", "fields": [ { "id": "LDO1_2_INT", "value": "0" }, { "id": "LDO3_4_INT", "value": "0" }, { "id": "VCCA_INT", "value": "0" } ] }, { "id": "INT_LDO1_2", "value": "0", "fields": [ { "id": "LDO1_OV_INT", "value": "0" }, { "id": "LDO1_UV_INT", "value": "0" }, { "id": "LDO1_SC_INT", "value": "0" }, { "id": "LDO2_OV_INT", "value": "0" }, { "id": "LDO2_UV_INT", "value": "0" }, { "id": "LDO2_SC_INT", "value": "0" }, { "id": "LDO2_ILIM_INT", "value": "0" }, { "id": "LDO1_ILIM_INT", "value": "0" } ] }, { "id": "INT_LDO3_4", "value": "0", "fields": [ { "id": "LDO3_OV_INT", "value": "0" }, { "id": "LDO3_UV_INT", "value": "0" }, { "id": "LDO3_SC_INT", "value": "0" }, { "id": "LDO4_OV_INT", "value": "0" }, { "id": "LDO4_UV_INT", "value": "0" }, { "id": "LDO4_SC_INT", "value": "0" }, { "id": "LDO4_ILIM_INT", "value": "0" }, { "id": "LDO3_ILIM_INT", "value": "0" } ] }, { "id": "INT_VMON", "value": "0", "fields": [ { "id": "VCCA_OV_INT", "value": "0" }, { "id": "VCCA_UV_INT", "value": "0" } ] }, { "id": "INT_GPIO", "value": "0", "fields": [ { "id": "GPIO1_8_INT", "value": "0" }, { "id": "GPIO9_INT", "value": "0" }, { "id": "GPIO10_INT", "value": "0" }, { "id": "GPIO11_INT", "value": "0" } ] }, { "id": "INT_GPIO1_8", "value": "0", "fields": [ { "id": "GPIO1_INT", "value": "0" }, { "id": "GPIO2_INT", "value": "0" }, { "id": "GPIO3_INT", "value": "0" }, { "id": "GPIO4_INT", "value": "0" }, { "id": "GPIO5_INT", "value": "0" }, { "id": "GPIO6_INT", "value": "0" }, { "id": "GPIO7_INT", "value": "0" }, { "id": "GPIO8_INT", "value": "0" } ] }, { "id": "INT_STARTUP", "value": "0", "fields": [ { "id": "FSD_INT", "value": "0" }, { "id": "NPWRON_START_INT", "value": "0" }, { "id": "RTC_INT", "value": "0" }, { "id": "ENABLE_INT", "value": "0" }, { "id": "SOFT_REBOOT_INT", "value": "0" } ] }, { "id": "INT_MISC", "value": "0", "fields": [ { "id": "EXT_CLK_INT", "value": "0" }, { "id": "TWARN_INT", "value": "0" }, { "id": "BIST_PASS_INT", "value": "0" } ] }, { "id": "INT_MODERATE_ERR", "value": "0", "fields": [ { "id": "TSD_ORD_INT", "value": "0" }, { "id": "BIST_FAIL_INT", "value": "0" }, { "id": "SPMI_ERR_INT", "value": "0" }, { "id": "REG_CRC_ERR_INT", "value": "0" }, { "id": "NPWRON_LONG_INT", "value": "0" }, { "id": "RECOV_CNT_INT", "value": "0" }, { "id": "NINT_READBACK_INT", "value": "0" }, { "id": "NRSTOUT_READBACK_INT", "value": "0" } ] }, { "id": "INT_SEVERE_ERR", "value": "0", "fields": [ { "id": "TSD_IMM_INT", "value": "0" }, { "id": "VCCA_OVP_INT", "value": "0" }, { "id": "PFSM_ERR_INT", "value": "0" } ] }, { "id": "INT_FSM_ERR", "value": "0", "fields": [ { "id": "IMM_SHUTDOWN_INT", "value": "0" }, { "id": "MCU_PWR_ERR_INT", "value": "0" }, { "id": "SOC_PWR_ERR_INT", "value": "0" }, { "id": "ORD_SHUTDOWN_INT", "value": "0" }, { "id": "COMM_ERR_INT", "value": "0" }, { "id": "READBACK_ERR_INT", "value": "0" }, { "id": "ESM_INT", "value": "0" }, { "id": "WD_INT", "value": "0" } ] }, { "id": "INT_COMM_ERR", "value": "0", "fields": [ { "id": "COMM_FRM_ERR_INT", "value": "0" }, { "id": "COMM_CRC_ERR_INT", "value": "0" }, { "id": "COMM_ADR_ERR_INT", "value": "0" }, { "id": "I2C2_CRC_ERR_INT", "value": "0" }, { "id": "I2C2_ADR_ERR_INT", "value": "0" } ] }, { "id": "INT_READBACK_ERR", "value": "0", "fields": [ { "id": "NRSTOUT_SOC_READBACK_INT", "value": "0" }, { "id": "EN_DRV_READBACK_INT", "value": "0" } ] }, { "id": "INT_ESM", "value": "0", "fields": [ { "id": "ESM_MCU_RST_INT", "value": "0" }, { "id": "ESM_MCU_FAIL_INT", "value": "0" }, { "id": "ESM_MCU_PIN_INT", "value": "0" }, { "id": "ESM_SOC_PIN_INT", "value": "0" }, { "id": "ESM_SOC_RST_INT", "value": "0" }, { "id": "ESM_SOC_FAIL_INT", "value": "0" } ] }, { "id": "STAT_BUCK1_2", "value": "0", "fields": [ { "id": "BUCK1_OV_STAT", "value": "0" }, { "id": "BUCK1_UV_STAT", "value": "0" }, { "id": "BUCK1_ILIM_STAT", "value": "0" }, { "id": "BUCK2_OV_STAT", "value": "0" }, { "id": "BUCK2_UV_STAT", "value": "0" }, { "id": "BUCK2_ILIM_STAT", "value": "0" } ] }, { "id": "STAT_BUCK3_4", "value": "0", "fields": [ { "id": "BUCK3_OV_STAT", "value": "0" }, { "id": "BUCK3_UV_STAT", "value": "0" }, { "id": "BUCK3_ILIM_STAT", "value": "0" }, { "id": "BUCK4_OV_STAT", "value": "0" }, { "id": "BUCK4_UV_STAT", "value": "0" }, { "id": "BUCK4_ILIM_STAT", "value": "0" } ] }, { "id": "STAT_BUCK5", "value": "0", "fields": [ { "id": "BUCK5_OV_STAT", "value": "0" }, { "id": "BUCK5_UV_STAT", "value": "0" }, { "id": "BUCK5_ILIM_STAT", "value": "0" } ] }, { "id": "STAT_LDO1_2", "value": "0", "fields": [ { "id": "LDO1_OV_STAT", "value": "0" }, { "id": "LDO1_UV_STAT", "value": "0" }, { "id": "LDO2_OV_STAT", "value": "0" }, { "id": "LDO2_UV_STAT", "value": "0" }, { "id": "LDO1_ILIM_STAT", "value": "0" }, { "id": "LDO2_ILIM_STAT", "value": "0" } ] }, { "id": "STAT_LDO3_4", "value": "0", "fields": [ { "id": "LDO3_OV_STAT", "value": "0" }, { "id": "LDO3_UV_STAT", "value": "0" }, { "id": "LDO4_OV_STAT", "value": "0" }, { "id": "LDO4_UV_STAT", "value": "0" }, { "id": "LDO3_ILIM_STAT", "value": "0" }, { "id": "LDO4_ILIM_STAT", "value": "0" } ] }, { "id": "STAT_VMON", "value": "0", "fields": [ { "id": "VCCA_OV_STAT", "value": "0" }, { "id": "VCCA_UV_STAT", "value": "0" } ] }, { "id": "STAT_STARTUP", "value": "0", "fields": [ { "id": "ENABLE_STAT", "value": "0" } ] }, { "id": "STAT_MISC", "value": "0", "fields": [ { "id": "EXT_CLK_STAT", "value": "0" }, { "id": "TWARN_STAT", "value": "0" } ] }, { "id": "STAT_MODERATE_ERR", "value": "0", "fields": [ { "id": "TSD_ORD_STAT", "value": "0" } ] }, { "id": "STAT_SEVERE_ERR", "value": "0", "fields": [ { "id": "TSD_IMM_STAT", "value": "0" }, { "id": "VCCA_OVP_STAT", "value": "0" } ] }, { "id": "STAT_READBACK_ERR", "value": "0", "fields": [ { "id": "NRSTOUT_SOC_READBACK_STAT", "value": "0" }, { "id": "EN_DRV_READBACK_STAT", "value": "0" }, { "id": "NINT_READBACK_STAT", "value": "0" }, { "id": "NRSTOUT_READBACK_STAT", "value": "0" } ] }, { "id": "PGOOD_SEL_1", "value": "0", "fields": [ { "id": "PGOOD_SEL_BUCK1", "value": "0", "staticConfig": true }, { "id": "PGOOD_SEL_BUCK2", "value": "0", "staticConfig": true }, { "id": "PGOOD_SEL_BUCK3", "value": "0", "staticConfig": true }, { "id": "PGOOD_SEL_BUCK4", "value": "0", "staticConfig": true } ] }, { "id": "PGOOD_SEL_2", "value": "0", "fields": [ { "id": "PGOOD_SEL_BUCK5", "value": "0", "staticConfig": true } ] }, { "id": "PGOOD_SEL_3", "value": "0", "fields": [ { "id": "PGOOD_SEL_LDO1", "value": "0", "staticConfig": true }, { "id": "PGOOD_SEL_LDO2", "value": "0", "staticConfig": true }, { "id": "PGOOD_SEL_LDO3", "value": "0", "staticConfig": true }, { "id": "PGOOD_SEL_LDO4", "value": "0", "staticConfig": true } ] }, { "id": "PGOOD_SEL_4", "value": "0", "fields": [ { "id": "PGOOD_SEL_VCCA", "value": "0", "staticConfig": true }, { "id": "PGOOD_SEL_TDIE_WARN", "value": "0", "staticConfig": true }, { "id": "PGOOD_SEL_NRSTOUT", "value": "0", "staticConfig": true }, { "id": "PGOOD_SEL_NRSTOUT_SOC", "value": "0", "staticConfig": true }, { "id": "PGOOD_POL", "value": "0", "staticConfig": true }, { "id": "PGOOD_WINDOW", "value": "0", "staticConfig": true } ] }, { "id": "PLL_CTRL", "value": "0", "fields": [ { "id": "EXT_CLK_FREQ", "value": "0", "staticConfig": true, "isTouched": false } ] }, { "id": "CONFIG_1", "value": "0", "fields": [ { "id": "TWARN_LEVEL", "value": "0", "staticConfig": true, "isTouched": false }, { "id": "I2C1_HS", "value": "0", "staticConfig": true, "isTouched": false }, { "id": "I2C2_HS", "value": "0", "staticConfig": true, "isTouched": false }, { "id": "EN_ILIM_FSM_CTRL", "value": "0", "staticConfig": true, "isTouched": false }, { "id": "NSLEEP1_MASK", "value": "0", "staticConfig": true, "isTouched": false }, { "id": "NSLEEP2_MASK", "value": "0", "staticConfig": true, "isTouched": false }, { "id": "TSD_ORD_LEVEL", "value": "0", "staticConfig": true, "isTouched": false } ] }, { "id": "CONFIG_2", "value": "0", "fields": [ { "id": "BB_CHARGER_EN", "value": "0", "staticConfig": true, "isTouched": false }, { "id": "BB_VEOC", "value": "0", "staticConfig": true, "isTouched": false }, { "id": "BB_ICHR", "value": "0", "staticConfig": true, "isTouched": false }, { "id": "BB_EOC_RDY", "value": "0", "staticConfig": false } ] }, { "id": "ENABLE_DRV_REG", "value": "0", "fields": [ { "id": "ENABLE_DRV", "value": "0" } ] }, { "id": "MISC_CTRL", "value": "0", "fields": [ { "id": "NRSTOUT", "value": "0" }, { "id": "NRSTOUT_SOC", "value": "0" }, { "id": "LPM_EN", "value": "0" }, { "id": "CLKMON_EN", "value": "0" }, { "id": "AMUXOUT_EN", "value": "0" }, { "id": "SEL_EXT_CLK", "value": "0" }, { "id": "SYNCCLKOUT_FREQ_SEL", "value": "0" } ] }, { "id": "ENABLE_DRV_STAT", "value": "0", "fields": [ { "id": "EN_DRV_IN", "value": "0" }, { "id": "NRSTOUT_IN", "value": "0" }, { "id": "NRSTOUT_SOC_IN", "value": "0" }, { "id": "FORCE_EN_DRV_LOW", "value": "0" }, { "id": "SPMI_LPM_EN", "value": "0" } ] }, { "id": "RECOV_CNT_REG_1", "value": "0", "fields": [ { "id": "RECOV_CNT", "value": "0" } ] }, { "id": "RECOV_CNT_REG_2", "value": "0", "fields": [ { "id": "RECOV_CNT_THR", "value": "0" }, { "id": "RECOV_CNT_CLR", "value": "0" } ] }, { "id": "FSM_I2C_TRIGGERS", "value": "0", "fields": [ { "id": "TRIGGER_I2C_1", "value": "0" }, { "id": "TRIGGER_I2C_2", "value": "0" }, { "id": "TRIGGER_I2C_3", "value": "0" }, { "id": "TRIGGER_I2C_4", "value": "0" }, { "id": "TRIGGER_I2C_5", "value": "0" }, { "id": "TRIGGER_I2C_6", "value": "0" }, { "id": "TRIGGER_I2C_7", "value": "0" }, { "id": "TRIGGER_I2C_0", "value": "0" } ] }, { "id": "FSM_NSLEEP_TRIGGERS", "value": "0", "fields": [ { "id": "NSLEEP1B", "value": "0" }, { "id": "NSLEEP2B", "value": "0" } ] }, { "id": "BUCK_RESET_REG", "value": "0", "fields": [ { "id": "BUCK1_RESET", "value": 0 }, { "id": "BUCK2_RESET", "value": 0 }, { "id": "BUCK3_RESET", "value": 0 }, { "id": "BUCK4_RESET", "value": 0 }, { "id": "BUCK5_RESET", "value": 0 } ] }, { "id": "SPREAD_SPECTRUM_1", "value": "0", "fields": [ { "id": "SS_EN", "value": "0" }, { "id": "SS_DEPTH", "value": "0" } ] }, { "id": "FREQ_SEL", "value": "0", "fields": [ { "id": "BUCK1_FREQ_SEL", "value": 0 }, { "id": "BUCK2_FREQ_SEL", "value": 0 }, { "id": "BUCK3_FREQ_SEL", "value": 0 }, { "id": "BUCK4_FREQ_SEL", "value": 0 }, { "id": "BUCK5_FREQ_SEL", "value": 0 } ] }, { "id": "FSM_STEP_SIZE", "value": "0", "fields": [ { "id": "PFSM_DELAY_STEP", "value": 11, "staticConfig": true } ] }, { "id": "LDO_RV_TIMEOUT_REG_1", "value": "0", "fields": [ { "id": "LDO1_RV_TIMEOUT", "value": "0" }, { "id": "LDO2_RV_TIMEOUT", "value": "0" } ] }, { "id": "LDO_RV_TIMEOUT_REG_2", "value": "0", "fields": [ { "id": "LDO3_RV_TIMEOUT", "value": "0" }, { "id": "LDO4_RV_TIMEOUT", "value": "0" } ] }, { "id": "USER_SPARE_REGS", "value": "0", "fields": [ { "id": "USER_SPARE_1", "value": 0, "staticConfig": true }, { "id": "USER_SPARE_2", "value": 0, "staticConfig": true }, { "id": "USER_SPARE_3", "value": 0, "staticConfig": true }, { "id": "USER_SPARE_4", "value": 0, "staticConfig": true } ] }, { "id": "ESM_MCU_START_REG", "value": "0", "fields": [ { "id": "ESM_MCU_START", "value": "0" } ] }, { "id": "ESM_MCU_DELAY1_REG", "value": "0", "fields": [ { "id": "ESM_MCU_DELAY1", "value": "0" } ] }, { "id": "ESM_MCU_DELAY2_REG", "value": "0", "fields": [ { "id": "ESM_MCU_DELAY2", "value": "0" } ] }, { "id": "ESM_MCU_MODE_CFG", "value": "0", "fields": [ { "id": "ESM_MCU_ERR_CNT_TH", "value": "0" }, { "id": "ESM_MCU_ENDRV", "value": "0" }, { "id": "ESM_MCU_EN", "value": 0 }, { "id": "ESM_MCU_MODE", "value": "0" } ] }, { "id": "ESM_MCU_HMAX_REG", "value": "0", "fields": [ { "id": "ESM_MCU_HMAX", "value": "0" } ] }, { "id": "ESM_MCU_HMIN_REG", "value": "0", "fields": [ { "id": "ESM_MCU_HMIN", "value": "0" } ] }, { "id": "ESM_MCU_LMAX_REG", "value": "0", "fields": [ { "id": "ESM_MCU_LMAX", "value": "0" } ] }, { "id": "ESM_MCU_LMIN_REG", "value": "0", "fields": [ { "id": "ESM_MCU_LMIN", "value": "0" } ] }, { "id": "ESM_MCU_ERR_CNT_REG", "value": "0", "fields": [ { "id": "ESM_MCU_ERR_CNT", "value": "0" } ] }, { "id": "ESM_SOC_START_REG", "value": "0", "fields": [ { "id": "ESM_SOC_START", "value": "0" } ] }, { "id": "ESM_SOC_DELAY1_REG", "value": "0", "fields": [ { "id": "ESM_SOC_DELAY1", "value": "0" } ] }, { "id": "ESM_SOC_DELAY2_REG", "value": "0", "fields": [ { "id": "ESM_SOC_DELAY2", "value": "0" } ] }, { "id": "ESM_SOC_MODE_CFG", "value": "0", "fields": [ { "id": "ESM_SOC_ERR_CNT_TH", "value": "0" }, { "id": "ESM_SOC_ENDRV", "value": "0" }, { "id": "ESM_SOC_EN", "value": 0 }, { "id": "ESM_SOC_MODE", "value": "0" } ] }, { "id": "ESM_SOC_HMAX_REG", "value": "0", "fields": [ { "id": "ESM_SOC_HMAX", "value": "0" } ] }, { "id": "ESM_SOC_HMIN_REG", "value": "0", "fields": [ { "id": "ESM_SOC_HMIN", "value": "0" } ] }, { "id": "ESM_SOC_LMAX_REG", "value": "0", "fields": [ { "id": "ESM_SOC_LMAX", "value": "0" } ] }, { "id": "ESM_SOC_LMIN_REG", "value": "0", "fields": [ { "id": "ESM_SOC_LMIN", "value": "0" } ] }, { "id": "ESM_SOC_ERR_CNT_REG", "value": "0", "fields": [ { "id": "ESM_SOC_ERR_CNT", "value": "0" } ] }, { "id": "REGISTER_LOCK", "value": "0", "fields": [ { "id": "REGISTER_LOCK_STATUS", "value": "0" } ] }, { "id": "USER_EE_CTRL_1", "value": "0", "fields": [ { "id": "USER_EE_PROG_UNLOCK_SEQ", "value": "0" } ] }, { "id": "USER_EE_CTRL_2", "value": "0", "fields": [ { "id": "USER_PROG_ALLOWED", "value": "0" }, { "id": "USER_PROG_UNLOCKED", "value": "0" }, { "id": "EE_PROG_USER", "value": "0" }, { "id": "EE_PROG_PFSM", "value": "0" }, { "id": "EE_PROG_STATUS", "value": "0" }, { "id": "EE_PROG_MODE", "value": "0" } ] }, { "id": "SRAM_ADDR_CTRL", "value": "0", "fields": [ { "id": "SRAM_SEL", "value": "0" } ] }, { "id": "RECOV_CNT_PFSM_INCR", "value": "0", "fields": [ { "id": "INCREMENT_RECOV_CNT", "value": "0" } ] }, { "id": "MANUFACTURING_VER", "value": "0", "fields": [ { "id": "SILICON_REV", "value": "0" } ] }, { "id": "CUSTOMER_NVM_ID_REG", "value": "0", "fields": [ { "id": "CUSTOMER_NVM_ID", "value": "0", "staticConfig": true } ] }, { "id": "SOFT_REBOOT_REG", "value": "0", "fields": [ { "id": "SOFT_REBOOT", "value": "0" } ] } ] }, { "id": "UserRegisters2-user_mem", "registers": [ { "id": "RTC_SECONDS", "value": "0", "fields": [ { "id": "SECOND_0", "value": "0" }, { "id": "SECOND_1", "value": "0" } ] }, { "id": "RTC_MINUTES", "value": "0", "fields": [ { "id": "MINUTE_0", "value": "0" }, { "id": "MINUTE_1", "value": "0" } ] }, { "id": "RTC_HOURS", "value": "0", "fields": [ { "id": "HOUR_0", "value": "0" }, { "id": "HOUR_1", "value": "0" }, { "id": "PM_NAM", "value": "0" } ] }, { "id": "RTC_DAYS", "value": "0", "fields": [ { "id": "DAY_0", "value": "0" }, { "id": "DAY_1", "value": "0" } ] }, { "id": "RTC_MONTHS", "value": "0", "fields": [ { "id": "MONTH_0", "value": "0" }, { "id": "MONTH_1", "value": "0" } ] }, { "id": "RTC_YEARS", "value": "0", "fields": [ { "id": "YEAR_0", "value": "0" }, { "id": "YEAR_1", "value": "0" } ] }, { "id": "RTC_WEEKS", "value": "0", "fields": [ { "id": "WEEK", "value": "0" } ] }, { "id": "ALARM_SECONDS", "value": "0", "fields": [ { "id": "ALR_SECOND_0", "value": "0" }, { "id": "ALR_SECOND_1", "value": "0" } ] }, { "id": "ALARM_MINUTES", "value": "0", "fields": [ { "id": "ALR_MINUTE_0", "value": "0" }, { "id": "ALR_MINUTE_1", "value": "0" } ] }, { "id": "ALARM_HOURS", "value": "0", "fields": [ { "id": "ALR_HOUR_0", "value": "0" }, { "id": "ALR_HOUR_1", "value": "0" }, { "id": "ALR_PM_NAM", "value": "0" } ] }, { "id": "ALARM_DAYS", "value": "0", "fields": [ { "id": "ALR_DAY_0", "value": "0" }, { "id": "ALR_DAY_1", "value": "0" } ] }, { "id": "ALARM_MONTHS", "value": "0", "fields": [ { "id": "ALR_MONTH_0", "value": "0" }, { "id": "ALR_MONTH_1", "value": "0" } ] }, { "id": "ALARM_YEARS", "value": "0", "fields": [ { "id": "ALR_YEAR_0", "value": "0" }, { "id": "ALR_YEAR_1", "value": "0" } ] }, { "id": "RTC_CTRL_1", "value": "0", "fields": [ { "id": "STOP_RTC", "value": "0" }, { "id": "ROUND_30S", "value": "0" }, { "id": "AUTO_COMP", "value": "0" }, { "id": "MODE_12_24", "value": "0" }, { "id": "SET_32_COUNTER", "value": "0" }, { "id": "GET_TIME", "value": "0" }, { "id": "RTC_V_OPT", "value": "0" } ] }, { "id": "RTC_CTRL_2", "value": "0", "fields": [ { "id": "XTAL_EN", "value": "0", "staticConfig": true, "isTouched": false }, { "id": "LP_STANDBY_SEL", "value": "0", "staticConfig": true, "isTouched": false }, { "id": "FAST_BIST", "value": "0", "staticConfig": false }, { "id": "STARTUP_DEST", "value": "3", "staticConfig": true, "isTouched": true }, { "id": "FIRST_STARTUP_DONE", "value": "0", "staticConfig": false }, { "id": "XTAL_SEL", "value": "0", "staticConfig": true, "isTouched": false } ] }, { "id": "RTC_STATUS", "value": "0", "fields": [ { "id": "RUN", "value": "0" }, { "id": "TIMER", "value": "0" }, { "id": "ALARM", "value": "0" }, { "id": "POWER_UP", "value": "0" } ] }, { "id": "RTC_INTERRUPTS", "value": "0", "fields": [ { "id": "EVERY", "value": "0" }, { "id": "IT_TIMER", "value": "0" }, { "id": "IT_ALARM", "value": "0" } ] }, { "id": "RTC_COMP_LSB", "value": "0", "fields": [ { "id": "COMP_LSB_RTC", "value": "0" } ] }, { "id": "RTC_COMP_MSB", "value": "0", "fields": [ { "id": "COMP_MSB_RTC", "value": "0" } ] }, { "id": "RTC_RESET_STATUS", "value": "0", "fields": [ { "id": "RESET_STATUS_RTC", "value": "0" } ] }, { "id": "SCRATCH_PAD_REG_1", "value": "0", "fields": [ { "id": "SCRATCH_PAD_1", "value": "0" } ] }, { "id": "SCRATCH_PAD_REG_2", "value": "0", "fields": [ { "id": "SCRATCH_PAD_2", "value": "0" } ] }, { "id": "SCRATCH_PAD_REG_3", "value": "0", "fields": [ { "id": "SCRATCH_PAD_3", "value": "0" } ] }, { "id": "SCRATCH_PAD_REG_4", "value": "0", "fields": [ { "id": "SCRATCH_PAD_4", "value": "0" } ] }, { "id": "PFSM_DELAY_REG_1", "value": "0", "fields": [ { "id": "PFSM_DELAY1", "value": "0", "staticConfig": true, "isTouched": false } ] }, { "id": "PFSM_DELAY_REG_2", "value": "0", "fields": [ { "id": "PFSM_DELAY2", "value": "0", "staticConfig": true, "isTouched": false } ] }, { "id": "PFSM_DELAY_REG_3", "value": "0", "fields": [ { "id": "PFSM_DELAY3", "value": "0", "staticConfig": true, "isTouched": false } ] }, { "id": "PFSM_DELAY_REG_4", "value": "0", "fields": [ { "id": "PFSM_DELAY4", "value": "0", "staticConfig": true, "isTouched": false } ] }, { "id": "RTS_SPARE_REG", "value": "0", "fields": [ { "id": "RTC_SPARE_0", "value": "0", "staticConfig": true, "isTouched": false }, { "id": "RTC_SPARE_1", "value": "0", "staticConfig": true, "isTouched": false }, { "id": "RTC_SPARE_2", "value": "0", "staticConfig": true, "isTouched": false }, { "id": "RTC_SPARE_3", "value": "0", "staticConfig": true, "isTouched": false } ] } ] }, { "id": "CRCRegisters-user_mem", "registers": [ { "id": "CRC_CALC_CONTROL", "value": "0", "fields": [ { "id": "RUN_CRC_BIST", "value": "0" }, { "id": "RUN_CRC_UPDATE", "value": "0" } ] }, { "id": "CRC_1", "value": "0", "fields": [ { "id": "REGMAP_USER_INCLUDE_PERSIST_CRC16_LOW", "value": "0" } ] }, { "id": "CRC_2", "value": "0", "fields": [ { "id": "REGMAP_USER_INCLUDE_PERSIST_CRC16_HIGH", "value": "0" } ] }, { "id": "CRC_3", "value": "0", "fields": [ { "id": "REGMAP_USER_EXCLUDE_PERSIST_CRC16_LOW", "value": "0" } ] }, { "id": "CRC_4", "value": "0", "fields": [ { "id": "REGMAP_USER_EXCLUDE_PERSIST_CRC16_HIGH", "value": "0" } ] }, { "id": "CRC_5", "value": "0", "fields": [ { "id": "REGMAP_CONFIG_CRC16_LOW", "value": "0" } ] }, { "id": "CRC_6", "value": "0", "fields": [ { "id": "REGMAP_CONFIG_CRC16_HIGH", "value": "0" } ] }, { "id": "CRC_7", "value": "0", "fields": [ { "id": "SRAM_BANK0_CRC16_LOW", "value": "0" } ] }, { "id": "CRC_8", "value": "0", "fields": [ { "id": "SRAM_BANK0_CRC16_HIGH", "value": "0" } ] }, { "id": "CRC_9", "value": "0", "fields": [ { "id": "SRAM_BANK1_CRC16_LOW", "value": "0" } ] }, { "id": "CRC_10", "value": "0", "fields": [ { "id": "SRAM_BANK1_CRC16_HIGH", "value": "0" } ] }, { "id": "CRC_11", "value": "0", "fields": [ { "id": "SRAM_BANK2_CRC16_LOW", "value": "0" } ] }, { "id": "CRC_12", "value": "0", "fields": [ { "id": "SRAM_BANK2_CRC16_HIGH", "value": "0" } ] }, { "id": "CRC_15", "value": "0", "fields": [ { "id": "REGMAP_TRIM_CRC16_LOW", "value": "0" } ] }, { "id": "CRC_16", "value": "0", "fields": [ { "id": "REGMAP_TRIM_CRC16_HIGH", "value": "0" } ] } ] }, { "id": "ConfigRegisters-user_mem", "registers": [ { "id": "BUCK_CONFIG_ANALOG_0", "value": "0", "fields": [ { "id": "SEL_LOOP_NEG_HYST", "value": 2 }, { "id": "SEL_GATE_EARLY_SENSE", "value": 0 }, { "id": "SEL_TRAD_NON_OVERLAP", "value": 0 } ] }, { "id": "BUCK_CONFIG_ANALOG_1", "value": "0", "fields": [ { "id": "SEL_FB_FILTER", "value": 3 }, { "id": "BUCK1_SEL_NEG_OCP_HYST", "value": 1 }, { "id": "BUCK2_SEL_NEG_OCP_HYST", "value": 1 }, { "id": "BUCK3_SEL_NEG_OCP_HYST", "value": 1 }, { "id": "BUCK4_SEL_NEG_OCP_HYST", "value": 1 }, { "id": "BUCK5_SEL_NEG_OCP_HYST", "value": 1 } ] }, { "id": "BUCK_CONFIG_ANALOG_2", "value": "0", "fields": [ { "id": "SEL_RAMP_ARTIF", "value": 1 } ] }, { "id": "BUCK_CONFIG_ANALOG_3", "value": "0", "fields": [ { "id": "BUCK1_SEL_ISENSE_SLOPE_COMPENSATION", "value": 2 }, { "id": "BUCK1_SEL_VOUT_ADC_LEVEL", "value": 0 } ] }, { "id": "BUCK_CONFIG_ANALOG_4", "value": "0", "fields": [ { "id": "BUCK2_SEL_ISENSE_SLOPE_COMPENSATION", "value": 2 }, { "id": "BUCK2_SEL_VOUT_ADC_LEVEL", "value": 0 } ] }, { "id": "BUCK_CONFIG_ANALOG_5", "value": "0", "fields": [ { "id": "BUCK3_SEL_ISENSE_SLOPE_COMPENSATION", "value": 2 }, { "id": "BUCK3_SEL_VOUT_ADC_LEVEL", "value": 0 } ] }, { "id": "BUCK_CONFIG_ANALOG_6", "value": "0", "fields": [ { "id": "BUCK4_SEL_ISENSE_SLOPE_COMPENSATION", "value": 2 }, { "id": "BUCK4_SEL_VOUT_ADC_LEVEL", "value": 0 } ] }, { "id": "BUCK_CONFIG_ANALOG_7", "value": "0", "fields": [ { "id": "BUCK5_SEL_ISENSE_SLOPE_COMPENSATION", "value": 2 }, { "id": "BUCK5_SEL_VOUT_ADC_LEVEL", "value": 0 } ] }, { "id": "BUCK_CONFIG_ANALOG_8", "value": "0", "fields": [ { "id": "EN_SW_RT_SHORT_DETECTORS", "value": 0 }, { "id": "EN_IAVE_LOOP_INJECTOR", "value": 0 } ] }, { "id": "BUCK_CONFIG_RADAR", "value": "0", "fields": [ { "id": "BUCK1_EN_RADAR_MODE", "value": 0 }, { "id": "BUCK2_EN_RADAR_MODE", "value": 0 }, { "id": "BUCK3_EN_RADAR_MODE", "value": 0 }, { "id": "BUCK4_EN_RADAR_MODE", "value": 0 }, { "id": "BUCK5_EN_RADAR_MODE", "value": 0 } ] }, { "id": "BUCK_CONFIG_DIGITAL_0", "value": "0", "fields": [ { "id": "BUCK1_SEL_PHASE_SHEDD", "value": 0 }, { "id": "BUCK1_SEL_PHASE_ADD", "value": 1 }, { "id": "BUCK3_SEL_PHASE_SHEDD", "value": 0 }, { "id": "BUCK3_SEL_PHASE_ADD", "value": 1 }, { "id": "EN_LOAD_COMP_BLANK", "value": 1 } ] }, { "id": "BUCK_CONFIG_DIGITAL_1", "value": "0", "fields": [ { "id": "EN_PLL_PROP_EXTEND", "value": 1 }, { "id": "EN_SMART_OCP_BLANK", "value": 1 }, { "id": "BUCK1_SEL_POS_OCP_HYST", "value": 1 }, { "id": "BUCK2_SEL_POS_OCP_HYST", "value": 1 }, { "id": "BUCK3_SEL_POS_OCP_HYST", "value": 1 }, { "id": "BUCK4_SEL_POS_OCP_HYST", "value": 1 }, { "id": "BUCK5_SEL_POS_OCP_HYST", "value": 1 } ] }, { "id": "BUCK_CONFIG_DIGITAL_2", "value": "0", "fields": [ { "id": "SEL_HS_DETECTOR", "value": 1 }, { "id": "EN_LONG_PFM_EXIT_CNTR", "value": 1 } ] }, { "id": "BUCK_CONFIG_DIGITAL_3", "value": "0", "fields": [ { "id": "EN_NEG_OCP", "value": 1 }, { "id": "EN_POS_OCP", "value": 1 }, { "id": "EN_PFM_LOAD", "value": 1 }, { "id": "EN_DOT_MODE", "value": 1 } ] }, { "id": "BUCK_CONFIG_DIGITAL_4", "value": "0", "fields": [ { "id": "BUCK1_SEL_OUTPUT_CAPS", "value": 1 }, { "id": "BUCK2_SEL_OUTPUT_CAPS", "value": 1 }, { "id": "BUCK3_SEL_OUTPUT_CAPS", "value": 1 }, { "id": "BUCK4_SEL_OUTPUT_CAPS", "value": 1 } ] }, { "id": "BUCK_CONFIG_DIGITAL_5", "value": "0", "fields": [ { "id": "BUCK5_SEL_OUTPUT_CAPS", "value": 1 }, { "id": "LOOP_COEFF_I_BALANCE", "value": 1 }, { "id": "SEL_ZERO_CROSS_FILTER_AVE", "value": 1 }, { "id": "EN_AUTO_LOOP_COEFFS", "value": 1 }, { "id": "LOOP_COEFF_FB_MSB", "value": 1 }, { "id": "EN_LONG_ZERO_CROSS_FILTER", "value": 0 } ] }, { "id": "BUCK_CONFIG_DIGITAL_6", "value": "0", "fields": [ { "id": "FORCE_SS_ADAPT", "value": 0 }, { "id": "BUCK1_SEL_RAMP", "value": 1 }, { "id": "BUCK2_SEL_RAMP", "value": 1 }, { "id": "EN_PFM_PULSE_WAIT_LS_OCP", "value": 1 }, { "id": "EN_SLOW_PLL_COEFFS", "value": 0 } ] }, { "id": "BUCK_CONFIG_DIGITAL_7", "value": "0", "fields": [ { "id": "BUCK3_SEL_RAMP", "value": 1 }, { "id": "BUCK4_SEL_RAMP", "value": 1 }, { "id": "BUCK5_SEL_RAMP", "value": 1 }, { "id": "EN_SW_SHORT_DETECTORS", "value": 1 }, { "id": "EN_FAST_PLL_0P7", "value": 1 } ] }, { "id": "BUCK_CONFIG_DIGITAL_8", "value": "0", "fields": [ { "id": "EN_FAST_VOUT_INTEGRATION", "value": 1 }, { "id": "EN_I_BALANCE_INTEGRATOR", "value": 1 }, { "id": "DIS_PFM_WAITS_LS_DETECTOR", "value": 0 }, { "id": "DIS_PFM_WAITS_HS_DETECTOR", "value": 0 }, { "id": "DIS_DVS_WAIT_COMPARATORS", "value": 0 }, { "id": "EN_CONSTANT_PLL_DVS_COEFF", "value": 0 }, { "id": "EN_SLOW_PLL_0P3", "value": 1 } ] }, { "id": "BUCK_CONFIG_DIGITAL_9", "value": "0", "fields": [ { "id": "EN_M_10M_TRAN_DETECTOR", "value": 1 }, { "id": "EN_FAST_INTEGRATION_BYPASS_RAMP_RES", "value": 1 }, { "id": "EN_LS_AFTER_HIZ", "value": 0 }, { "id": "EN_PWM_LS_DETECTION", "value": 0 }, { "id": "I_COEFF", "value": 1 } ] }, { "id": "BUCK_CONFIG_DIGITAL_10", "value": "0", "fields": [ { "id": "BUCK_NEG_ILIM", "value": 1 }, { "id": "EN_ADAPTIVE_SINGLE_SHOT", "value": 1 } ] }, { "id": "BUCK_CONFIG_DIGITAL_11", "value": "0", "fields": [ { "id": "FIXED_SS_LENGTH", "value": 24 }, { "id": "LONG_SINGLE_SHOT", "value": 1 } ] }, { "id": "BUCK_CONFIG_DIGITAL_12", "value": "0", "fields": [ { "id": "BUCK1_FREQ_8MHZ", "value": 0 }, { "id": "BUCK2_FREQ_8MHZ", "value": 0 }, { "id": "BUCK3_FREQ_8MHZ", "value": 0 }, { "id": "BUCK4_FREQ_8MHZ", "value": 0 }, { "id": "BUCK5_FREQ_8MHZ", "value": 0 } ] }, { "id": "GENERAL_REG_0", "value": "0", "fields": [ { "id": "EN_OVP", "value": 1, "staticConfig": true }, { "id": "DIS_UVLO_OVP_RESET", "value": 0, "staticConfig": true }, { "id": "DIS_TSD", "value": 0, "staticConfig": true }, { "id": "FAST_BOOT_BIST", "value": "0", "staticConfig": false }, { "id": "VSYS_DEAD_LOCK_EN", "value": "0", "staticConfig": false }, { "id": "PFSM_ERR_RESET_DIS", "value": 0, "staticConfig": true }, { "id": "VMON_ABIST_EN", "value": "0", "staticConfig": false }, { "id": "ABIST_ERROR_MASK", "value": 0, "staticConfig": true } ] }, { "id": "GENERAL_REG_1", "value": "0", "fields": [ { "id": "MAX_ILIM", "value": 5, "staticConfig": true }, { "id": "FREQ_SEL_UNLOCK", "value": 0, "staticConfig": true }, { "id": "REG_CRC_EN", "value": "0", "staticConfig": true, "isTouched": false }, { "id": "EN_INITIALIZE_DPLL_RESTART", "value": 0, "staticConfig": true }, { "id": "PFSM_ERR_MASK", "value": 0, "staticConfig": true }, { "id": "FAST_VCCA_OVP", "value": "0", "staticConfig": true, "isTouched": false } ] }, { "id": "GENERAL_REG_2", "value": "0", "fields": [ { "id": "DIS_NRSTOUT_MCU_I2C_SPI_RESET", "value": 0, "staticConfig": true }, { "id": "SLOW_AUTOZERO_SEL", "value": 0, "staticConfig": true }, { "id": "EN_FIXED_DPLL_FREQ", "value": 0, "staticConfig": true }, { "id": "SEL_RC_OSC", "value": 0, "staticConfig": true }, { "id": "DISABLE_VM_NARROW_LIMITS", "value": 0, "staticConfig": true }, { "id": "DISABLE_CHANGE_BG", "value": 0, "staticConfig": true }, { "id": "DISABLE_USE_TRIMS", "value": 0, "staticConfig": true }, { "id": "WD_EN_EE", "value": 1, "staticConfig": true } ] }, { "id": "SERIAL_IF_CONFIG", "value": "0", "fields": [ { "id": "I2C_SPI_SEL", "value": "0" }, { "id": "I2C1_SPI_CRC_EN", "value": "0" }, { "id": "I2C2_CRC_EN", "value": "0" } ] }, { "id": "SPMI_CONFIG_1", "value": "0", "fields": [ { "id": "SPMI_CRC_EN", "value": 1 }, { "id": "SPMI_MASTER_SEL", "value": 1 }, { "id": "SPMI_CLK_SEL", "value": 2 }, { "id": "SPMI_SLAVE_PASSIVE", "value": 0 } ] }, { "id": "SPMI_CONFIG_2", "value": "0", "fields": [ { "id": "SPMI_IF_SEL", "value": 0 }, { "id": "SPMI_RETRY_LIMIT", "value": 3 }, { "id": "SPMI_SLAVE_ASR_HOLD", "value": 0 }, { "id": "SPMI_WD_AUTO_BOOT", "value": 1 }, { "id": "SPMI_EN", "value": 0 }, { "id": "SPMI_WD_EN", "value": 0 }, { "id": "SPMI_WAKEUP_EN", "value": 0 } ] }, { "id": "SPMI_CONFIG_3", "value": "0", "fields": [ { "id": "SPMI_WD_BOOT_INTERVAL", "value": 8 }, { "id": "SPMI_WD_RUNTIME_INTERVAL", "value": 8 } ] }, { "id": "SPMI_CONFIG_4", "value": "0", "fields": [ { "id": "SPMI_WD_RESPONSE_TIMEOUT", "value": 8 }, { "id": "SPMI_PFSM_RESPONSE_TIMEOUT", "value": 8 } ] }, { "id": "SPMI_CONFIG_5", "value": "0", "fields": [ { "id": "SPMI_WD_BOOT_BIST_TIMEOUT", "value": 8 }, { "id": "SPMI_WD_RUNTIME_BIST_TIMEOUT", "value": 8 } ] }, { "id": "SPMI_CONFIG_6", "value": "0", "fields": [ { "id": "BOOT_DELAY", "value": 0 } ] }, { "id": "SPMI_ID", "value": "0", "fields": [ { "id": "SPMI_SID", "value": 5 }, { "id": "SPMI_MID", "value": 0 } ] }, { "id": "I2C1_ID_REG", "value": 72, "fields": [ { "id": "I2C1_ID", "value": "72" } ] }, { "id": "I2C2_ID_REG", "value": 18, "fields": [ { "id": "I2C2_ID", "value": "18" } ] }, { "id": "CLOCK_REQS", "value": "0", "fields": [ { "id": "FORCE_CLK_GATE", "value": 0 }, { "id": "INT_LDO_PD_FORCE", "value": 0 }, { "id": "LDO1_PD_FORCE", "value": 0 }, { "id": "LDO2_PD_FORCE", "value": 0 }, { "id": "LDO3_PD_FORCE", "value": 0 }, { "id": "LDO4_PD_FORCE", "value": 0 } ] }, { "id": "PHASE_CONFIG", "value": "0", "fields": [ { "id": "MP_CONFIG", "value": "0" } ] }, { "id": "SPMI_SLAVE_COUNT", "value": "0", "fields": [ { "id": "SPMI_SLAVE_CNT", "value": 1 } ] }, { "id": "PFSM_CONFIG", "value": "0", "fields": [ { "id": "PFSM_SEQ_MIN_TIME", "value": 1, "staticConfig": true }, { "id": "SRAM_RELOAD_LIMIT", "value": 2, "staticConfig": true }, { "id": "PFSM_PROXY_BRANCH_DIS", "value": 0, "staticConfig": true } ] }, { "id": "GENERAL_REG_3", "value": "0", "fields": [ { "id": "LPM_EN_DISABLES_VCCA_VMON", "value": 1, "staticConfig": true } ] }, { "id": "XCOORD_REG", "value": "0", "fields": [ { "id": "XCOORD", "value": "0" } ] }, { "id": "YCOORD_REG", "value": "0", "fields": [ { "id": "YCOORD", "value": "0" } ] }, { "id": "WAFERNUM_REG", "value": "0", "fields": [ { "id": "WAFERNUM", "value": "0" } ] }, { "id": "WAFERLOTNUM_REG_1", "value": "0", "fields": [ { "id": "WAFERLOTNUM_23_16", "value": "0" } ] }, { "id": "WAFERLOTNUM_REG_2", "value": "0", "fields": [ { "id": "WAFERLOTNUM_15_8", "value": "0" } ] }, { "id": "WAFERLOTNUM_REG_3", "value": "0", "fields": [ { "id": "WAFERLOTNUM_7_0", "value": "0" } ] }, { "id": "WAFERFAB_REG", "value": "0", "fields": [ { "id": "WAFERFAB", "value": "0" } ] }, { "id": "BUCK_CONFIG_DIGITAL_13", "value": "0", "fields": [ { "id": "BUCK1_EN_P_10M_BODY_DIODE", "value": 0 }, { "id": "BUCK2_EN_P_10M_BODY_DIODE", "value": 0 }, { "id": "BUCK3_EN_P_10M_BODY_DIODE", "value": 0 }, { "id": "BUCK4_EN_P_10M_BODY_DIODE", "value": 0 }, { "id": "BUCK5_EN_P_10M_BODY_DIODE", "value": 0 } ] }, { "id": "BUCK_CONFIG_DIGITAL_14", "value": "0", "fields": [ { "id": "BUCK1_DOUBLE_PFM_PULSE", "value": 0 }, { "id": "BUCK2_DOUBLE_PFM_PULSE", "value": 0 }, { "id": "BUCK3_DOUBLE_PFM_PULSE", "value": 0 }, { "id": "BUCK4_DOUBLE_PFM_PULSE", "value": 0 }, { "id": "BUCK5_DOUBLE_PFM_PULSE", "value": 0 } ] }, { "id": "BUCK_CONFIG_DIGITAL_15", "value": "0", "fields": [ { "id": "BUCK1_CHANGE_2MHZ_BELOW_0V5", "value": 1 }, { "id": "BUCK2_CHANGE_2MHZ_BELOW_0V5", "value": 1 }, { "id": "BUCK3_CHANGE_2MHZ_BELOW_0V5", "value": 1 }, { "id": "BUCK4_CHANGE_2MHZ_BELOW_0V5", "value": 1 }, { "id": "BUCK5_CHANGE_2MHZ_BELOW_0V5", "value": 1 } ] }, { "id": "SPREAD_SPECTRUM_CONFIG_1", "value": "0", "fields": [ { "id": "SS_MODE", "value": 1 } ] }, { "id": "SPREAD_SPECTRUM_CONFIG_2", "value": "0", "fields": [ { "id": "SS_PARAM1", "value": 7 }, { "id": "SS_PARAM2", "value": 12 } ] }, { "id": "USER_EE_PROG_UNLOCK", "value": "0", "fields": [ { "id": "USER_EE_PROG_UNLOCK_CODE", "value": "0" } ] }, { "id": "INT_CONFIG_0", "value": "0", "fields": [ { "id": "refsys_bg_buf_hi_bw", "value": 0, "staticConfig": true }, { "id": "refsys_sel_ibias", "value": 0, "staticConfig": true } ] }, { "id": "SAFETY_CONFIG_0", "value": "0", "fields": [ { "id": "safety_speedup", "value": 0, "staticConfig": true }, { "id": "safety_sel_ibias", "value": 0, "staticConfig": true }, { "id": "safety_bg_buf_hi_bw", "value": 0, "staticConfig": true } ] }, { "id": "VM_VSYS_CONFIG_0", "value": "0", "fields": [ { "id": "vm_vsys_dummy_bit", "value": "0" } ] }, { "id": "RTC_CONFIG_0", "value": "0", "fields": [ { "id": "xtal_amp_reg_en", "value": 1, "staticConfig": true }, { "id": "xtal_amp_reg_mode", "value": 1, "staticConfig": true }, { "id": "xtal_comp_bias_lvl", "value": 0, "staticConfig": true }, { "id": "xtal_bias_fine", "value": 10, "staticConfig": true } ] }, { "id": "LDO1_3_FILT_CONFIG_0", "value": "0", "fields": [ { "id": "vbg_filt_config", "value": 0 } ] }, { "id": "LDO1_CONFIG_0", "value": "0", "fields": [ { "id": "ldo1_en_short_cp", "value": 0 }, { "id": "ldo1_dis_short_prot", "value": 0 }, { "id": "ldo1_dis_ilim", "value": 0 }, { "id": "ldo1_dis_cp_leak_comp", "value": 0 }, { "id": "ldo1_en_cp_low_sr", "value": 0 }, { "id": "ldo1_dis_ov_pldn", "value": 0 } ] }, { "id": "LDO2_CONFIG_0", "value": "0", "fields": [ { "id": "ldo2_en_short_cp", "value": 0 }, { "id": "ldo2_dis_short_prot", "value": 0 }, { "id": "ldo2_dis_ilim", "value": 0 }, { "id": "ldo2_dis_cp_leak_comp", "value": 0 }, { "id": "ldo2_en_cp_low_sr", "value": 0 }, { "id": "ldo2_dis_ov_pldn", "value": 0 } ] }, { "id": "LDO3_CONFIG_0", "value": "0", "fields": [ { "id": "ldo3_en_short_cp", "value": 0 }, { "id": "ldo3_dis_short_prot", "value": 0 }, { "id": "ldo3_dis_ilim", "value": 0 }, { "id": "ldo3_dis_cp_leak_comp", "value": 0 }, { "id": "ldo3_en_cp_low_sr", "value": 0 }, { "id": "ldo3_dis_ov_pldn", "value": 0 } ] }, { "id": "LDO4_CONFIG_0", "value": "0", "fields": [ { "id": "ldo4_sel_low_ilim", "value": 0 }, { "id": "ldo4_filter_current", "value": 3 } ] } ] }, { "id": "TestRegisters-tm_mem", "registers": [ { "id": "TEST_MODE_LOCK", "value": "0", "fields": [ { "id": "TM_UNLOCK_CODE", "value": "0" } ] }, { "id": "TEST_MODE_STATUS", "value": "0", "fields": [ { "id": "debug_mode", "value": "0" }, { "id": "test_mode", "value": "0" } ] }, { "id": "TEST_SET_SCAN_MODE", "value": "0", "fields": [ { "id": "SET_SCAN_MODE", "value": "0" }, { "id": "SET_SCAN_OVST_MODE", "value": "0" } ] }, { "id": "DMUX1_CTRL_1", "value": "0", "fields": [ { "id": "TM_DMUX1_MAIN_SEL", "value": "0" }, { "id": "TM_DMUX1_INV", "value": "0" }, { "id": "TM_DMUX1_MODE", "value": "0" } ] }, { "id": "DMUX1_CTRL_2", "value": "0", "fields": [ { "id": "TM_DMUX1_SUB_SEL", "value": "0" }, { "id": "TM_DMUX1_DIV", "value": "0" } ] }, { "id": "DMUX2_CTRL_1", "value": "0", "fields": [ { "id": "TM_DMUX2_MAIN_SEL", "value": "0" }, { "id": "TM_DMUX2_INV", "value": "0" }, { "id": "TM_DMUX2_MODE", "value": "0" } ] }, { "id": "DMUX2_CTRL_2", "value": "0", "fields": [ { "id": "TM_DMUX2_SUB_SEL", "value": "0" }, { "id": "TM_DMUX2_DIV", "value": "0" } ] }, { "id": "DMUX3_CTRL_1", "value": "0", "fields": [ { "id": "TM_DMUX3_MAIN_SEL", "value": "0" }, { "id": "TM_DMUX3_INV", "value": "0" }, { "id": "TM_DMUX3_MODE", "value": "0" } ] }, { "id": "DMUX3_CTRL_2", "value": "0", "fields": [ { "id": "TM_DMUX3_SUB_SEL", "value": "0" }, { "id": "TM_DMUX3_DIV", "value": "0" } ] }, { "id": "DMUX4_CTRL_1", "value": "0", "fields": [ { "id": "TM_DMUX4_MAIN_SEL", "value": "0" }, { "id": "TM_DMUX4_INV", "value": "0" }, { "id": "TM_DMUX4_MODE", "value": "0" } ] }, { "id": "DMUX4_CTRL_2", "value": "0", "fields": [ { "id": "TM_DMUX4_SUB_SEL", "value": "0" }, { "id": "TM_DMUX4_DIV", "value": "0" } ] }, { "id": "DMUX5_CTRL_1", "value": "0", "fields": [ { "id": "TM_DMUX5_MAIN_SEL", "value": "0" }, { "id": "TM_DMUX5_INV", "value": "0" }, { "id": "TM_DMUX5_MODE", "value": "0" } ] }, { "id": "DMUX5_CTRL_2", "value": "0", "fields": [ { "id": "TM_DMUX5_SUB_SEL", "value": "0" }, { "id": "TM_DMUX5_DIV", "value": "0" } ] }, { "id": "TEST_REG_8", "value": "0", "fields": [ { "id": "NINT_TX_DIS", "value": "0" }, { "id": "USE_TRIMS", "value": "0" }, { "id": "VM_NARROW_LIMITS", "value": "0" }, { "id": "NINT_TX", "value": "0" }, { "id": "CHANGE_BG", "value": "0" }, { "id": "START_ABIST", "value": "0" } ] }, { "id": "TEST_REG_9", "value": "0", "fields": [ { "id": "BUCK1_MODE", "value": "0" } ] }, { "id": "TEST_REG_10", "value": "0", "fields": [ { "id": "BUCK2_MODE", "value": "0" } ] }, { "id": "TEST_REG_11", "value": "0", "fields": [ { "id": "BUCK3_MODE", "value": "0" } ] }, { "id": "TEST_REG_12", "value": "0", "fields": [ { "id": "BUCK4_MODE", "value": "0" } ] }, { "id": "TEST_REG_13", "value": "0", "fields": [ { "id": "BUCK5_MODE", "value": "0" } ] }, { "id": "TEST_REG_14", "value": "0", "fields": [ { "id": "BUCK1_VSET_MSB", "value": "0" }, { "id": "TEST_SINGLE_SHOT", "value": "0" }, { "id": "BUCK2_VSET_MSB", "value": "0" }, { "id": "BUCK3_VSET_MSB", "value": "0" }, { "id": "BUCK4_VSET_MSB", "value": "0" }, { "id": "BUCK5_VSET_MSB", "value": "0" } ] }, { "id": "TEST_REG_15", "value": "0", "fields": [ { "id": "LDO_EE_EN", "value": "0" }, { "id": "LDO_EE_PLDN", "value": "0" }, { "id": "BG_XMON_EN", "value": "0" }, { "id": "SAFETY_EN_REFS", "value": "0" }, { "id": "TEST_WLBI_MODE", "value": "0" }, { "id": "TEST_RTC_LDO_UVLO_DIS", "value": "0" } ] }, { "id": "TEST_REG_16", "value": "0", "fields": [ { "id": "TSD_FORCE", "value": "0" }, { "id": "TSD_SEL_THRESHOLD", "value": "0" }, { "id": "TSD_SEL_SENSOR", "value": "0" } ] }, { "id": "TEST_SPMI_1", "value": "0", "fields": [ { "id": "TM_SPMI_TX_PAYLOAD", "value": "0" } ] }, { "id": "TEST_SPMI_2", "value": "0", "fields": [ { "id": "TM_SPMI_TX_ADDRESS", "value": "0" } ] }, { "id": "TEST_SPMI_5", "value": "0", "fields": [ { "id": "TM_SPMI_TEST_MODE", "value": "0" }, { "id": "TM_SPMI_TX_REQ", "value": "0" }, { "id": "TM_SPMI_TX_REQ_HIGH", "value": "0" }, { "id": "TM_SPMI_TX_SLAVE_SEL", "value": "0" }, { "id": "SPMI_TX_DONE", "value": "0" }, { "id": "SPMI_RX_DONE", "value": "0" } ] }, { "id": "TEST_SPMI_6", "value": "0", "fields": [ { "id": "SPMI_RX_CMD", "value": "0" } ] }, { "id": "TEST_SPMI_7", "value": "0", "fields": [ { "id": "SPMI_RX_PAYLOAD", "value": "0" } ] }, { "id": "TEST_PFSM_0", "value": "0", "fields": [ { "id": "pfsm_debug_trigger_id", "value": "0" }, { "id": "pfsm_branch_self", "value": "0" }, { "id": "op_ready", "value": "0" }, { "id": "op_end", "value": "0" } ] }, { "id": "TEST_PFSM_1", "value": "0", "fields": [ { "id": "FREEZE_PFSM", "value": "0" }, { "id": "TM_PFSM_SINGLE_STEP_EN", "value": "0" }, { "id": "TM_PFSM_SINGLE_STEP_PULSE", "value": "0" }, { "id": "TM_PFSM_BREAKPOINT_EN", "value": "0" }, { "id": "op_debug_halt", "value": "0" }, { "id": "op_breakpoint_match", "value": "0" } ] }, { "id": "TEST_PFSM_2", "value": "0", "fields": [ { "id": "TM_PFSM_BREAKPOINT_ADDRESS_12_8", "value": "0" } ] }, { "id": "TEST_PFSM_3", "value": "0", "fields": [ { "id": "TM_PFSM_BREAKPOINT_ADDRESS_7_0", "value": "0" } ] }, { "id": "TEST_FFSM_1", "value": "0", "fields": [ { "id": "fixed_fsm_state", "value": "0" } ] }, { "id": "TEST_FFSM_2", "value": "0", "fields": [ { "id": "next_fixed_fsm_state", "value": "0" }, { "id": "force_fixed_fsm_state", "value": "0" } ] }, { "id": "TEST_REG_29", "value": "0", "fields": [ { "id": "LDO1_PD_DISABLE", "value": "0" }, { "id": "LDO2_PD_DISABLE", "value": "0" }, { "id": "LDO3_PD_DISABLE", "value": "0" }, { "id": "LDO4_PD_DISABLE", "value": "0" }, { "id": "LDO_INT_PLDN", "value": "0" }, { "id": "TM_LDOINT_DIS", "value": "0" }, { "id": "FORCE_AUTOZERO_LOW", "value": "0" }, { "id": "FORCE_AUTOZERO_HIGH", "value": "0" } ] }, { "id": "TEST_REG_30", "value": "0", "fields": [ { "id": "OSC_128KHZ_EN", "value": "0" }, { "id": "DPLL_EN", "value": "0" }, { "id": "OSC_52M8HZ_EN", "value": "0" }, { "id": "OSC_20MHZ_EN", "value": "0" }, { "id": "OSC_MONITOR_20MHZ_EN", "value": "0" } ] }, { "id": "TEST_SRAM_1", "value": "0", "fields": [ { "id": "TM_SRAM_MARGIN0", "value": "0" }, { "id": "TM_SRAM_MARGIN1", "value": "0" } ] }, { "id": "TEST_RTC_CAL_0", "value": "0", "fields": [ { "id": "RTC_TEST_MODE1", "value": "0" }, { "id": "RTC_TEST_MODE2", "value": "0" } ] }, { "id": "TEST_PADRING_0", "value": "0", "fields": [ { "id": "test_en_nint_cp_osc", "value": "0" }, { "id": "test_en_atab_loop_cp", "value": "0" }, { "id": "test_en_atab_loop_cp_current", "value": "0" }, { "id": "test_en_drv_tx_dis", "value": "0" } ] }, { "id": "TEST_PADRING_1", "value": "0", "fields": [ { "id": "test_en_atab_1v8", "value": "0" } ] }, { "id": "TEST_PADRING_3", "value": "0", "fields": [ { "id": "test_en_atab_5v", "value": "0" } ] }, { "id": "TEST_PADRING_4", "value": "0", "fields": [ { "id": "test_en_kelvin_12_8", "value": "0" } ] }, { "id": "TEST_PADRING_5", "value": "0", "fields": [ { "id": "test_en_kelvin_7_0", "value": "0" } ] }, { "id": "TEST_PADRING_6", "value": "0", "fields": [ { "id": "test_en_atab_loop_rc", "value": "0" } ] }, { "id": "TEST_PADRING_7", "value": "0", "fields": [ { "id": "TEST_PADRING_SPARE", "value": "0" }, { "id": "test_dis_nint_cp_pd", "value": "0" } ] }, { "id": "TEST_VMVCCA_0", "value": "0", "fields": [ { "id": "test_vmvcca_bg", "value": "0" }, { "id": "test_vmvcca_vref_1v2", "value": "0" }, { "id": "test_vmvcca_iptat", "value": "0" } ] }, { "id": "TEST_VMPVIN_0", "value": "0", "fields": [ { "id": "test_vmpvin_bg", "value": "0" }, { "id": "test_vmpvin_vref_1v2", "value": "0" }, { "id": "test_vmpvin_iptat", "value": "0" } ] }, { "id": "TEST_INT_0", "value": "0", "fields": [ { "id": "test_refsys_ibias", "value": "0" }, { "id": "test_refsys_bg", "value": "0" }, { "id": "test_refsys_ldo_int_en_vout_kelvin", "value": "0" }, { "id": "test_refsys_ldo_int_en_ovst", "value": "0" }, { "id": "test_refsys_ldo_int_pupd_hiz", "value": "0" }, { "id": "test_refsys_ldo_int_en_ilim", "value": "0" }, { "id": "test_refsys_ldo_int_en_ilim2", "value": "0" }, { "id": "test_refsys_iptat", "value": "0" } ] }, { "id": "TEST_INT_1", "value": "0", "fields": [ { "id": "test_refsys_bg_buffer", "value": "0" }, { "id": "test_refsys_bg_buffer_en_hiz", "value": "0" }, { "id": "test_refsys_amux_buffer_en_hiz", "value": "0" }, { "id": "test_refsys_ldo_int_out_stage_dis", "value": "0" } ] }, { "id": "TEST_SAFETY_0", "value": "0", "fields": [ { "id": "test_tsd", "value": "0" }, { "id": "test_vmon_buck", "value": "0" } ] }, { "id": "TEST_SAFETY_1", "value": "0", "fields": [ { "id": "test_safety_ibias", "value": "0" }, { "id": "test_vmon_ldo", "value": "0" }, { "id": "test_vmon_vcca", "value": "0" }, { "id": "test_safety_bg_buffer_en_hiz", "value": "0" } ] }, { "id": "TEST_SAFETY_2", "value": "0", "fields": [ { "id": "test_safety_bias_dist", "value": "0" }, { "id": "test_safety_vref_1v2", "value": "0" }, { "id": "test_tsd2", "value": "0" } ] }, { "id": "TEST_VM_VSYS_0", "value": "0", "fields": [ { "id": "test_vsys_en_ovst", "value": "0" }, { "id": "test_vsys_vdda_voltage", "value": "0" }, { "id": "test_vsys_bg", "value": "0" }, { "id": "test_vsys_ibias", "value": "0" }, { "id": "test_vsys_cp_voltage", "value": "0" }, { "id": "test_vsys_en_cp_osc", "value": "0" }, { "id": "test_vsys_vref_ramp", "value": "0" }, { "id": "test_vsys_dis_osc_and_vcca_pd", "value": "0" } ] }, { "id": "TEST_RTC_0", "value": "0", "fields": [ { "id": "test_rtc_bg", "value": "0" }, { "id": "test_rtc_force_int_on", "value": "0" }, { "id": "test_rtc_ldo_en_ovst", "value": "0" }, { "id": "test_rtc_ldo_pupd_hiz", "value": "0" }, { "id": "test_rtc_ldo_en_ilim", "value": "0" }, { "id": "test_rtc_ldo_en_ilim2", "value": "0" }, { "id": "test_rtc_iptat", "value": "0" }, { "id": "test_rtc_ldo_pldn", "value": "0" } ] }, { "id": "TEST_RTC_1", "value": "0", "fields": [ { "id": "test_rtc_xtal", "value": "0" }, { "id": "test_rtc_ldo_out_stage_dis", "value": "0" } ] }, { "id": "TEST_LDO1_3_FILT_0", "value": "0", "fields": [ { "id": "vbg_filt_test", "value": "0" } ] }, { "id": "TEST_LDO1_0", "value": "0", "fields": [ { "id": "ldo1_en_ovst", "value": "0" }, { "id": "ldo1_en_unity_gain", "value": "0" }, { "id": "ldo1_dis_ilim1", "value": "0" }, { "id": "ldo1_dis_ilim2", "value": "0" }, { "id": "ldo1_en_hiz", "value": "0" }, { "id": "ldo1_en_ldo_vref", "value": "0" }, { "id": "ldo1_en_ldo_vref_hiz", "value": "0" }, { "id": "ldo1_en_ilim_trim", "value": "0" } ] }, { "id": "TEST_LDO1_1", "value": "0", "fields": [ { "id": "ldo1_cp_test_sel", "value": "0" }, { "id": "ldo1_en_cp_test_mode", "value": "0" } ] }, { "id": "TEST_LDO2_0", "value": "0", "fields": [ { "id": "ldo2_en_ovst", "value": "0" }, { "id": "ldo2_en_unity_gain", "value": "0" }, { "id": "ldo2_dis_ilim1", "value": "0" }, { "id": "ldo2_dis_ilim2", "value": "0" }, { "id": "ldo2_en_hiz", "value": "0" }, { "id": "ldo2_en_ldo_vref", "value": "0" }, { "id": "ldo2_en_ldo_vref_hiz", "value": "0" }, { "id": "ldo2_en_ilim_trim", "value": "0" } ] }, { "id": "TEST_LDO2_1", "value": "0", "fields": [ { "id": "ldo2_cp_test_sel", "value": "0" }, { "id": "ldo2_en_cp_test_mode", "value": "0" } ] }, { "id": "TEST_LDO3_0", "value": "0", "fields": [ { "id": "ldo3_en_ovst", "value": "0" }, { "id": "ldo3_en_unity_gain", "value": "0" }, { "id": "ldo3_dis_ilim1", "value": "0" }, { "id": "ldo3_dis_ilim2", "value": "0" }, { "id": "ldo3_en_hiz", "value": "0" }, { "id": "ldo3_en_ldo_vref", "value": "0" }, { "id": "ldo3_en_ldo_vref_hiz", "value": "0" }, { "id": "ldo3_en_ilim_trim", "value": "0" } ] }, { "id": "TEST_LDO3_1", "value": "0", "fields": [ { "id": "ldo3_cp_test_sel", "value": "0" }, { "id": "ldo3_en_cp_test_mode", "value": "0" } ] }, { "id": "TEST_LDO4_0", "value": "0", "fields": [ { "id": "ldo4_test_en_ilim", "value": "0" }, { "id": "ldo4_test_en_ilim2", "value": "0" }, { "id": "ldo4_en_ovst", "value": "0" }, { "id": "ldo4_en_kelvin", "value": "0" }, { "id": "ldo4_en_hiz", "value": "0" }, { "id": "ldo4_en_ovst2", "value": "0" }, { "id": "ldo4_test_en_faster_trim", "value": "0" } ] }, { "id": "TEST_EE_LDO_0", "value": "0", "fields": [ { "id": "test_dft_iddq_scale", "value": "0" }, { "id": "test_en_tmux1_in", "value": "0" }, { "id": "test_en_tmux2_in", "value": "0" } ] }, { "id": "TEST_BB_0", "value": "0", "fields": [ { "id": "TEST_BB_SPARE", "value": "0" } ] }, { "id": "BUCK1_ATEST_REG_0", "value": "0", "fields": [ { "id": "buck_atab_sel_1", "value": "0" }, { "id": "test_integ_dac_short_output_1", "value": "0" }, { "id": "test_ramp_artif_1", "value": "0" }, { "id": "test_ramp_artif_pd_1", "value": "0" }, { "id": "test_ramp_emu_1", "value": "0" } ] }, { "id": "BUCK1_ATEST_REG_1", "value": "0", "fields": [ { "id": "test_iave_1", "value": "0" }, { "id": "test_hs_gate_1", "value": "0" }, { "id": "test_ovst_1", "value": "0" }, { "id": "test_ramp_emu_pd_1", "value": "0" }, { "id": "test_sw_short_detector_1", "value": "0" } ] }, { "id": "BUCK1_ATEST_REG_2", "value": "0", "fields": [ { "id": "test_spare_1", "value": "0" } ] }, { "id": "BUCK1_DTEST_REG_0", "value": "0", "fields": [ { "id": "buck_dtab0_sel_1", "value": "0" }, { "id": "swc_buck_hs_1", "value": "0" }, { "id": "swc_buck_hiz_1", "value": 0 }, { "id": "force_pfm_1", "value": "0" } ] }, { "id": "BUCK1_DTEST_REG_1", "value": "0", "fields": [ { "id": "buck_dtab1_sel_1", "value": "0" }, { "id": "test_iave_pd_1", "value": "0" }, { "id": "test_sample_izero_1", "value": "0" }, { "id": "test_pulse_generator_1", "value": "0" } ] }, { "id": "BUCK1_DTEST_REG_2", "value": "0", "fields": [ { "id": "test_buck_weak_driver_1", "value": "0" }, { "id": "dis_loop_comp_hyst_1", "value": "0" }, { "id": "dis_vref_filter_1", "value": "0" }, { "id": "test_blank_1", "value": "0" }, { "id": "test_single_shot_1", "value": "0" }, { "id": "test_bypass_ramp_bias_res_1", "value": "0" } ] }, { "id": "BUCK1_DTEST_REG_3", "value": "0", "fields": [ { "id": "test_integrator_word_1", "value": "0" } ] }, { "id": "BUCK1_DTEST_REG_4", "value": "0", "fields": [ { "id": "test_carousel_ctrl_1", "value": "0" }, { "id": "test_bypass_sw_latches_1", "value": "0" }, { "id": "test_dis_autozero_1", "value": "0" }, { "id": "test_pulse_gen_fixed_1", "value": "0" } ] }, { "id": "BUCK2_ATEST_REG_0", "value": "0", "fields": [ { "id": "buck_atab_sel_2", "value": "0" }, { "id": "test_integ_dac_short_output_2", "value": "0" }, { "id": "test_ramp_artif_2", "value": "0" }, { "id": "test_ramp_artif_pd_2", "value": "0" }, { "id": "test_ramp_emu_2", "value": "0" } ] }, { "id": "BUCK2_ATEST_REG_1", "value": "0", "fields": [ { "id": "test_iave_2", "value": "0" }, { "id": "test_hs_gate_2", "value": "0" }, { "id": "test_ovst_2", "value": "0" }, { "id": "test_ramp_emu_pd_2", "value": "0" }, { "id": "test_sw_short_detector_2", "value": "0" } ] }, { "id": "BUCK2_ATEST_REG_2", "value": "0", "fields": [ { "id": "test_spare_2", "value": "0" } ] }, { "id": "BUCK2_DTEST_REG_0", "value": "0", "fields": [ { "id": "buck_dtab0_sel_2", "value": 0 }, { "id": "swc_buck_hs_2", "value": 0 }, { "id": "swc_buck_hiz_2", "value": 0 }, { "id": "force_pfm_2", "value": 0 } ] }, { "id": "BUCK2_DTEST_REG_1", "value": "0", "fields": [ { "id": "buck_dtab1_sel_2", "value": "0" }, { "id": "test_iave_pd_2", "value": "0" }, { "id": "test_sample_izero_2", "value": "0" }, { "id": "test_pulse_generator_2", "value": "0" } ] }, { "id": "BUCK2_DTEST_REG_2", "value": "0", "fields": [ { "id": "dis_loop_comp_hyst_2", "value": "0" }, { "id": "dis_vref_filter_2", "value": "0" }, { "id": "test_blank_2", "value": "0" }, { "id": "test_single_shot_2", "value": "0" }, { "id": "test_buck_weak_driver_2", "value": "0" }, { "id": "test_bypass_ramp_bias_res_2", "value": "0" } ] }, { "id": "BUCK2_DTEST_REG_3", "value": "0", "fields": [ { "id": "test_integrator_word_2", "value": "0" } ] }, { "id": "BUCK2_DTEST_REG_4", "value": "0", "fields": [ { "id": "test_carousel_ctrl_2", "value": "0" }, { "id": "test_bypass_sw_latches_2", "value": "0" }, { "id": "test_dis_autozero_2", "value": "0" }, { "id": "test_pulse_gen_fixed_2", "value": "0" } ] }, { "id": "BUCK3_ATEST_REG_0", "value": "0", "fields": [ { "id": "buck_atab_sel_3", "value": "0" }, { "id": "test_integ_dac_short_output_3", "value": "0" }, { "id": "test_ramp_artif_3", "value": "0" }, { "id": "test_ramp_artif_pd_3", "value": "0" }, { "id": "test_ramp_emu_3", "value": "0" } ] }, { "id": "BUCK3_ATEST_REG_1", "value": "0", "fields": [ { "id": "test_iave_3", "value": "0" }, { "id": "test_hs_gate_3", "value": "0" }, { "id": "test_ovst_3", "value": "0" }, { "id": "test_ramp_emu_pd_3", "value": "0" }, { "id": "test_sw_short_detector_3", "value": "0" } ] }, { "id": "BUCK3_ATEST_REG_2", "value": "0", "fields": [ { "id": "test_spare_3", "value": "0" } ] }, { "id": "BUCK3_DTEST_REG_0", "value": "0", "fields": [ { "id": "buck_dtab0_sel_3", "value": "0" }, { "id": "swc_buck_hs_3", "value": "0" }, { "id": "swc_buck_hiz_3", "value": 0 }, { "id": "force_pfm_3", "value": "0" } ] }, { "id": "BUCK3_DTEST_REG_1", "value": "0", "fields": [ { "id": "buck_dtab1_sel_3", "value": "0" }, { "id": "test_iave_pd_3", "value": "0" }, { "id": "test_sample_izero_3", "value": "0" }, { "id": "test_pulse_generator_3", "value": "0" } ] }, { "id": "BUCK3_DTEST_REG_2", "value": "0", "fields": [ { "id": "dis_loop_comp_hyst_3", "value": "0" }, { "id": "dis_vref_filter_3", "value": "0" }, { "id": "test_blank_3", "value": "0" }, { "id": "test_single_shot_3", "value": "0" }, { "id": "test_buck_weak_driver_3", "value": "0" }, { "id": "test_bypass_ramp_bias_res_3", "value": "0" } ] }, { "id": "BUCK3_DTEST_REG_3", "value": "0", "fields": [ { "id": "test_integrator_word_3", "value": "0" } ] }, { "id": "BUCK3_DTEST_REG_4", "value": "0", "fields": [ { "id": "test_carousel_ctrl_3", "value": "0" }, { "id": "test_bypass_sw_latches_3", "value": "0" }, { "id": "test_dis_autozero_3", "value": "0" }, { "id": "test_pulse_gen_fixed_3", "value": "0" } ] }, { "id": "BUCK4_ATEST_REG_0", "value": "0", "fields": [ { "id": "buck_atab_sel_4", "value": "0" }, { "id": "test_integ_dac_short_output_4", "value": "0" }, { "id": "test_ramp_artif_4", "value": "0" }, { "id": "test_ramp_artif_pd_4", "value": "0" }, { "id": "test_ramp_emu_4", "value": "0" } ] }, { "id": "BUCK4_ATEST_REG_1", "value": "0", "fields": [ { "id": "test_iave_4", "value": "0" }, { "id": "test_hs_gate_4", "value": "0" }, { "id": "test_ovst_4", "value": "0" }, { "id": "test_ramp_emu_pd_4", "value": "0" }, { "id": "test_sw_short_detector_4", "value": "0" } ] }, { "id": "BUCK4_ATEST_REG_2", "value": "0", "fields": [ { "id": "test_spare_4", "value": "0" } ] }, { "id": "BUCK4_DTEST_REG_0", "value": "0", "fields": [ { "id": "buck_dtab0_sel_4", "value": "0" }, { "id": "swc_buck_hs_4", "value": "0" }, { "id": "swc_buck_hiz_4", "value": 0 }, { "id": "force_pfm_4", "value": "0" } ] }, { "id": "BUCK4_DTEST_REG_1", "value": "0", "fields": [ { "id": "buck_dtab1_sel_4", "value": "0" }, { "id": "test_iave_pd_4", "value": "0" }, { "id": "test_sample_izero_4", "value": "0" }, { "id": "test_pulse_generator_4", "value": "0" } ] }, { "id": "BUCK4_DTEST_REG_2", "value": "0", "fields": [ { "id": "dis_loop_comp_hyst_4", "value": "0" }, { "id": "dis_vref_filter_4", "value": "0" }, { "id": "test_blank_4", "value": "0" }, { "id": "test_single_shot_4", "value": "0" }, { "id": "test_buck_weak_driver_4", "value": "0" }, { "id": "test_bypass_ramp_bias_res_4", "value": "0" } ] }, { "id": "BUCK4_DTEST_REG_3", "value": "0", "fields": [ { "id": "test_integrator_word_4", "value": "0" } ] }, { "id": "BUCK4_DTEST_REG_4", "value": "0", "fields": [ { "id": "test_carousel_ctrl_4", "value": "0" }, { "id": "test_bypass_sw_latches_4", "value": "0" }, { "id": "test_dis_autozero_4", "value": "0" }, { "id": "test_pulse_gen_fixed_4", "value": "0" } ] }, { "id": "BUCK5_ATEST_REG_0", "value": "0", "fields": [ { "id": "buck_atab_sel_5", "value": "0" }, { "id": "test_integ_dac_short_output_5", "value": "0" }, { "id": "test_ramp_artif_5", "value": "0" }, { "id": "test_ramp_artif_pd_5", "value": "0" }, { "id": "test_ramp_emu_5", "value": "0" } ] }, { "id": "BUCK5_ATEST_REG_1", "value": "0", "fields": [ { "id": "test_iave_5", "value": "0" }, { "id": "test_hs_gate_5", "value": "0" }, { "id": "test_ovst_5", "value": "0" }, { "id": "test_ramp_emu_pd_5", "value": "0" }, { "id": "test_sw_short_detector_5", "value": "0" } ] }, { "id": "BUCK5_ATEST_REG_2", "value": "0", "fields": [ { "id": "test_spare_5", "value": "0" } ] }, { "id": "BUCK5_DTEST_REG_0", "value": "0", "fields": [ { "id": "buck_dtab0_sel_5", "value": "0" }, { "id": "swc_buck_hs_5", "value": "0" }, { "id": "swc_buck_hiz_5", "value": 0 }, { "id": "force_pfm_5", "value": "0" } ] }, { "id": "BUCK5_DTEST_REG_1", "value": "0", "fields": [ { "id": "buck_dtab1_sel_5", "value": "0" }, { "id": "test_iave_pd_5", "value": "0" }, { "id": "test_sample_izero_5", "value": "0" }, { "id": "test_pulse_generator_5", "value": "0" } ] }, { "id": "BUCK5_DTEST_REG_2", "value": "0", "fields": [ { "id": "dis_loop_comp_hyst_5", "value": "0" }, { "id": "dis_vref_filter_5", "value": "0" }, { "id": "test_blank_5", "value": "0" }, { "id": "test_single_shot_5", "value": "0" }, { "id": "test_buck_weak_driver_5", "value": "0" }, { "id": "test_bypass_ramp_bias_res_5", "value": "0" } ] }, { "id": "BUCK5_DTEST_REG_3", "value": "0", "fields": [ { "id": "test_integrator_word_5", "value": "0" } ] }, { "id": "BUCK5_DTEST_REG_4", "value": "0", "fields": [ { "id": "test_carousel_ctrl_5", "value": "0" }, { "id": "test_bypass_sw_latches_5", "value": "0" }, { "id": "test_dis_autozero_5", "value": "0" }, { "id": "test_pulse_gen_fixed_5", "value": "0" } ] } ] }, { "id": "BuckStatus-tm_mem", "registers": [ { "id": "BUCK1_STATE", "value": "0", "fields": [ { "id": "buck_state_1", "value": "0" } ] }, { "id": "BUCK2_STATE", "value": "0", "fields": [ { "id": "buck_state_2", "value": "0" } ] }, { "id": "BUCK3_STATE", "value": "0", "fields": [ { "id": "buck_state_3", "value": "0" } ] }, { "id": "BUCK4_STATE", "value": "0", "fields": [ { "id": "buck_state_4", "value": "0" } ] }, { "id": "BUCK5_STATE", "value": "0", "fields": [ { "id": "buck_state_5", "value": "0" } ] }, { "id": "BUCK1_INTEGRATOR", "value": "0", "fields": [ { "id": "buck_integrator_word_1", "value": "0" } ] }, { "id": "BUCK2_INTEGRATOR", "value": "0", "fields": [ { "id": "buck_integrator_word_2", "value": "0" } ] }, { "id": "BUCK3_INTEGRATOR", "value": "0", "fields": [ { "id": "buck_integrator_word_3", "value": "0" } ] }, { "id": "BUCK4_INTEGRATOR", "value": "0", "fields": [ { "id": "buck_integrator_word_4", "value": "0" } ] }, { "id": "BUCK5_INTEGRATOR", "value": "0", "fields": [ { "id": "buck_integrator_word_5", "value": "0" } ] }, { "id": "BUCK_STATUS", "value": "0", "fields": [ { "id": "buck1_active", "value": "0" }, { "id": "buck2_active", "value": "0" }, { "id": "buck3_active", "value": "0" }, { "id": "buck4_active", "value": "0" }, { "id": "buck5_active", "value": "0" } ] } ] }, { "id": "EEPROMProgControl-tm_mem", "registers": [ { "id": "EEPROM_CONTROL_1", "value": "0", "fields": [ { "id": "TM_EE_CFG_BULK_PROG", "value": "0" }, { "id": "TM_EE_CFG_CKB_PROG", "value": "0" }, { "id": "TM_EE_CFG_MARGIN_READ", "value": "0" }, { "id": "TM_EE_CFG_BULK_ERASE", "value": "0" }, { "id": "TM_EE_CFG_SHADOW_WRITE_DIS", "value": "0" } ] }, { "id": "EEPROM_CONTROL_2", "value": "0", "fields": [ { "id": "TM_EE_CFG_BANK_DIS", "value": "0" }, { "id": "TM_EE_CFG_SINGLE", "value": "0" } ] }, { "id": "EEPROM_CONTROL_3", "value": "0", "fields": [ { "id": "TM_EE_ADDR", "value": "0" } ] }, { "id": "EEPROM_CONTROL_8", "value": "0", "fields": [ { "id": "TM_EE_WRITE_DATA3", "value": "0" } ] }, { "id": "EEPROM_CONTROL_9", "value": "0", "fields": [ { "id": "TM_EE_WRITE_DATA2", "value": "0" } ] }, { "id": "EEPROM_CONTROL_10", "value": "0", "fields": [ { "id": "TM_EE_WRITE_DATA1", "value": "0" } ] }, { "id": "EEPROM_CONTROL_11", "value": "0", "fields": [ { "id": "TM_EE_WRITE_DATA0", "value": "0" } ] }, { "id": "EEPROM_CONTROL_12", "value": "0", "fields": [ { "id": "TM_EE_READ_DATA3", "value": "0" } ] }, { "id": "EEPROM_CONTROL_13", "value": "0", "fields": [ { "id": "TM_EE_READ_DATA2", "value": "0" } ] }, { "id": "EEPROM_CONTROL_14", "value": "0", "fields": [ { "id": "TM_EE_READ_DATA1", "value": "0" } ] }, { "id": "EEPROM_CONTROL_15", "value": "0", "fields": [ { "id": "TM_EE_READ_DATA0", "value": "0" } ] }, { "id": "EEPROM_CONTROL_16", "value": "0", "fields": [ { "id": "TM_EE_CMD_PROG", "value": "0" }, { "id": "TM_EE_CMD_READ", "value": "0" } ] }, { "id": "EEPROM_CONTROL_17", "value": "0", "fields": [ { "id": "TM_EE_FORCE_CP_EN", "value": "0" }, { "id": "TM_EE_FORCE_IP_EN", "value": "0" }, { "id": "TM_EE_FORCE_ERASE", "value": "0" }, { "id": "TM_EE_FORCE_PROG", "value": "0" }, { "id": "TM_EE_FORCE_READ", "value": "0" }, { "id": "TM_EE_FORCE_EN", "value": "0" } ] }, { "id": "EEPROM_CONTROL_18", "value": "0", "fields": [ { "id": "TM_EE_FAST_ERASE_PROG_EN", "value": "0" }, { "id": "TM_EE_TEST_BULK_ODD_EN", "value": "0" }, { "id": "TM_EE_TEST_BULK_EVEN_EN", "value": "0" }, { "id": "TM_EE_TEST_MARGIN_READ_EN", "value": "0" }, { "id": "TM_EE_TEST_MARGIN_OVR_EN", "value": "0" }, { "id": "TM_EE_TEST_HV_BIAS_WEAK_RATIO_EN", "value": "0" }, { "id": "TM_EE_TEST_OSC_MON_EN", "value": "0" }, { "id": "TM_EE_TEST_CELL_CURRENT_MON_EN", "value": "0" } ] }, { "id": "EEPROM_CONTROL_19", "value": "0", "fields": [ { "id": "TM_EE_MARGIN_TRIM", "value": "0" }, { "id": "TM_EE_TEST_VTUN_MON_EN", "value": "0" }, { "id": "TM_EE_TEST_V1V_MON_OVR_EN", "value": "0" }, { "id": "TM_EE_PROG_SERIAL", "value": "0" } ] }, { "id": "EEPROM_CONTROL_20", "value": "0", "fields": [ { "id": "tm_ee_ready", "value": "0" }, { "id": "ee_active", "value": "0" }, { "id": "tm_ee_read_fail", "value": "0" } ] } ] }, { "id": "Trim_ocore", "registers": [ { "id": "TRIM_VMVCCA_0", "value": "0", "fields": [ { "id": "trim_vmvcca_bg", "value": "0" } ] }, { "id": "TRIM_VMVCCA_1", "value": "0", "fields": [ { "id": "trim_vmvcca_rdiv_1v2", "value": "0" } ] }, { "id": "TRIM_VMVCCA_2", "value": "0", "fields": [ { "id": "trim_vmvcca_rdiv_0v6", "value": "0" } ] }, { "id": "TRIM_VMPVIN_0", "value": "0", "fields": [ { "id": "trim_vmpvin_bg", "value": "0" } ] }, { "id": "TRIM_VMPVIN_1", "value": "0", "fields": [ { "id": "trim_vmpvin_rdiv_1v2", "value": "0" } ] }, { "id": "TRIM_INT_0", "value": "0", "fields": [ { "id": "trim_refsys_bg", "value": "0" } ] }, { "id": "TRIM_INT_1", "value": "0", "fields": [ { "id": "trim_refsys_rdiv_1v2", "value": "0" } ] }, { "id": "TRIM_INT_2", "value": "0", "fields": [ { "id": "trim_refsys_ibias", "value": "0" } ] }, { "id": "TRIM_INT_3", "value": "0", "fields": [ { "id": "trim_ldo_int", "value": "0" } ] }, { "id": "TRIM_INT_4", "value": "0", "fields": [ { "id": "trim_osc_20mhz", "value": "0" } ] }, { "id": "TRIM_INT_5", "value": "0", "fields": [ { "id": "trim_osc_128khz", "value": "0" } ] }, { "id": "TRIM_INT_6", "value": "0", "fields": [ { "id": "trim_osc_52mhz", "value": "0" } ] }, { "id": "TRIM_INT_7", "value": "0", "fields": [ { "id": "trim_amux_buffer", "value": "0" } ] }, { "id": "TRIM_INT_8", "value": "0", "fields": [ { "id": "trim_monitor_osc_20mhz", "value": "0" } ] }, { "id": "TRIM_SAFETY_0", "value": "0", "fields": [ { "id": "trim_safety_ibias", "value": "0" } ] }, { "id": "TRIM_SAFETY_1", "value": "0", "fields": [ { "id": "trim_vmon_buck1_lshift_ov", "value": "0" } ] }, { "id": "TRIM_SAFETY_2", "value": "0", "fields": [ { "id": "trim_vmon_buck1_lshift_uv", "value": "0" } ] }, { "id": "TRIM_SAFETY_3", "value": "0", "fields": [ { "id": "trim_vmon_buck1_vref_dac", "value": "0" } ] }, { "id": "TRIM_SAFETY_4", "value": "0", "fields": [ { "id": "trim_vmon_buck1_rdiv_uv", "value": "0" } ] }, { "id": "TRIM_SAFETY_5", "value": "0", "fields": [ { "id": "trim_vmon_buck2_lshift_ov", "value": "0" } ] }, { "id": "TRIM_SAFETY_6", "value": "0", "fields": [ { "id": "trim_vmon_buck2_lshift_uv", "value": "0" } ] }, { "id": "TRIM_SAFETY_7", "value": "0", "fields": [ { "id": "trim_vmon_buck2_vref_dac", "value": "0" } ] }, { "id": "TRIM_SAFETY_8", "value": "0", "fields": [ { "id": "trim_vmon_buck2_rdiv_uv", "value": "0" } ] }, { "id": "TRIM_SAFETY_9", "value": "0", "fields": [ { "id": "trim_vmon_buck3_lshift_ov", "value": "0" } ] }, { "id": "TRIM_SAFETY_10", "value": "0", "fields": [ { "id": "trim_vmon_buck3_lshift_uv", "value": "0" } ] }, { "id": "TRIM_SAFETY_11", "value": "0", "fields": [ { "id": "trim_vmon_buck3_vref_dac", "value": "0" } ] }, { "id": "TRIM_SAFETY_12", "value": "0", "fields": [ { "id": "trim_vmon_buck3_rdiv_uv", "value": "0" } ] }, { "id": "TRIM_SAFETY_13", "value": "0", "fields": [ { "id": "trim_vmon_buck4_lshift_ov", "value": "0" } ] }, { "id": "TRIM_SAFETY_14", "value": "0", "fields": [ { "id": "trim_vmon_buck4_lshift_uv", "value": "0" } ] }, { "id": "TRIM_SAFETY_15", "value": "0", "fields": [ { "id": "trim_vmon_buck4_vref_dac", "value": "0" } ] }, { "id": "TRIM_SAFETY_16", "value": "0", "fields": [ { "id": "trim_vmon_buck4_rdiv_uv", "value": "0" } ] }, { "id": "TRIM_SAFETY_17", "value": "0", "fields": [ { "id": "trim_vmon_buck5_lshift_ov", "value": "0" } ] }, { "id": "TRIM_SAFETY_18", "value": "0", "fields": [ { "id": "trim_vmon_buck5_lshift_uv", "value": "0" } ] }, { "id": "TRIM_SAFETY_19", "value": "0", "fields": [ { "id": "trim_vmon_buck5_vref_dac", "value": "0" } ] }, { "id": "TRIM_SAFETY_20", "value": "0", "fields": [ { "id": "trim_vmon_buck5_rdiv_uv", "value": "0" } ] }, { "id": "TRIM_SAFETY_21", "value": "0", "fields": [ { "id": "trim_vmon_ldo1_lshift_ov", "value": "0" } ] }, { "id": "TRIM_SAFETY_22", "value": "0", "fields": [ { "id": "trim_vmon_ldo1_lshift_uv", "value": "0" } ] }, { "id": "TRIM_SAFETY_23", "value": "0", "fields": [ { "id": "trim_vmon_ldo1_vref_dac", "value": "0" } ] }, { "id": "TRIM_SAFETY_24", "value": "0", "fields": [ { "id": "trim_vmon_ldo1_rdiv_uv", "value": "0" } ] }, { "id": "TRIM_SAFETY_25", "value": "0", "fields": [ { "id": "trim_vmon_ldo2_lshift_ov", "value": "0" } ] }, { "id": "TRIM_SAFETY_26", "value": "0", "fields": [ { "id": "trim_vmon_ldo2_lshift_uv", "value": "0" } ] }, { "id": "TRIM_SAFETY_27", "value": "0", "fields": [ { "id": "trim_vmon_ldo2_vref_dac", "value": "0" } ] }, { "id": "TRIM_SAFETY_28", "value": "0", "fields": [ { "id": "trim_vmon_ldo2_rdiv_uv", "value": "0" } ] }, { "id": "TRIM_SAFETY_29", "value": "0", "fields": [ { "id": "trim_vmon_ldo3_lshift_ov", "value": "0" } ] }, { "id": "TRIM_SAFETY_30", "value": "0", "fields": [ { "id": "trim_vmon_ldo3_lshift_uv", "value": "0" } ] }, { "id": "TRIM_SAFETY_31", "value": "0", "fields": [ { "id": "trim_vmon_ldo3_vref_dac", "value": "0" } ] }, { "id": "TRIM_SAFETY_32", "value": "0", "fields": [ { "id": "trim_vmon_ldo3_rdiv_uv", "value": "0" } ] }, { "id": "TRIM_SAFETY_33", "value": "0", "fields": [ { "id": "trim_vmon_ldo4_lshift_ov", "value": "0" } ] }, { "id": "TRIM_SAFETY_34", "value": "0", "fields": [ { "id": "trim_vmon_ldo4_lshift_uv", "value": "0" } ] }, { "id": "TRIM_SAFETY_35", "value": "0", "fields": [ { "id": "trim_vmon_ldo4_vref_dac", "value": "0" } ] }, { "id": "TRIM_SAFETY_36", "value": "0", "fields": [ { "id": "trim_vmon_ldo4_rdiv_uv", "value": "0" } ] }, { "id": "TRIM_SAFETY_37", "value": "0", "fields": [ { "id": "trim_tsd_offset", "value": "0" } ] }, { "id": "TRIM_SAFETY_38", "value": "0", "fields": [ { "id": "trim_tsd_gain", "value": "0" } ] }, { "id": "TRIM_SAFETY_39", "value": "0", "fields": [ { "id": "trim_tsd_offset2", "value": "0" } ] }, { "id": "TRIM_SAFETY_40", "value": "0", "fields": [ { "id": "trim_tsd_gain2", "value": "0" } ] }, { "id": "TRIM_VM_VSYS_0", "value": "0", "fields": [ { "id": "trim_vsys_mon_bg", "value": "0" } ] }, { "id": "TRIM_VM_VSYS_1", "value": "0", "fields": [ { "id": "trim_vsys_mon_rdiv_1v2", "value": "0" } ] }, { "id": "TRIM_RTC_0", "value": "0", "fields": [ { "id": "trim_rtc_bg", "value": "0" } ] }, { "id": "TRIM_RTC_1", "value": "0", "fields": [ { "id": "trim_rtc_rdiv_1v2", "value": "0" } ] }, { "id": "TRIM_RTC_2", "value": "0", "fields": [ { "id": "trim_rtc_ldo", "value": "0" } ] }, { "id": "TRIM_DPLL_0", "value": "0", "fields": [ { "id": "trim_dco", "value": "0" } ] }, { "id": "TRIM_LDO1_0", "value": "0", "fields": [ { "id": "trim_ldo1_ref", "value": "0" } ] }, { "id": "TRIM_LDO1_1", "value": "0", "fields": [ { "id": "trim_ldo1", "value": "0" } ] }, { "id": "TRIM_LDO1_2", "value": "0", "fields": [ { "id": "trim_ldo1_ilim1", "value": "0" } ] }, { "id": "TRIM_LDO1_3", "value": "0", "fields": [ { "id": "trim_ldo1_ilim2", "value": "0" } ] }, { "id": "TRIM_LDO2_0", "value": "0", "fields": [ { "id": "trim_ldo2_ref", "value": "0" } ] }, { "id": "TRIM_LDO2_1", "value": "0", "fields": [ { "id": "trim_ldo2", "value": "0" } ] }, { "id": "TRIM_LDO2_2", "value": "0", "fields": [ { "id": "trim_ldo2_ilim1", "value": "0" } ] }, { "id": "TRIM_LDO2_3", "value": "0", "fields": [ { "id": "trim_ldo2_ilim2", "value": "0" } ] }, { "id": "TRIM_LDO3_0", "value": "0", "fields": [ { "id": "trim_ldo3_ref", "value": "0" } ] }, { "id": "TRIM_LDO3_1", "value": "0", "fields": [ { "id": "trim_ldo3", "value": "0" } ] }, { "id": "TRIM_LDO3_2", "value": "0", "fields": [ { "id": "trim_ldo3_ilim1", "value": "0" } ] }, { "id": "TRIM_LDO3_3", "value": "0", "fields": [ { "id": "trim_ldo3_ilim2", "value": "0" } ] }, { "id": "TRIM_LDO4_0", "value": "0", "fields": [ { "id": "trim_ldo4_low", "value": "0" } ] }, { "id": "TRIM_LDO4_1", "value": "0", "fields": [ { "id": "trim_ldo4_high", "value": "0" } ] }, { "id": "TRIM_LDO4_2", "value": "0", "fields": [ { "id": "trim_ldo4_ilim", "value": "0" } ] }, { "id": "TRIM_LDO4_3", "value": "0", "fields": [ { "id": "trim_ldo4_sr_fast", "value": "0" } ] }, { "id": "TRIM_LDO4_4", "value": "0", "fields": [ { "id": "trim_ldo4_sr_slow", "value": "0" } ] }, { "id": "BUCK1_TRIM_REG_0", "value": "0", "fields": [ { "id": "trim_vref_dac_1", "value": "0" } ] }, { "id": "BUCK1_TRIM_REG_1", "value": "0", "fields": [ { "id": "trim_level_shift_gain_1", "value": "0" } ] }, { "id": "BUCK1_TRIM_REG_2", "value": "0", "fields": [ { "id": "trim_loop_comp_1", "value": "0" } ] }, { "id": "BUCK1_TRIM_REG_3", "value": "0", "fields": [ { "id": "trim_vout_adc_gain_1", "value": "0" } ] }, { "id": "BUCK1_TRIM_REG_4", "value": "0", "fields": [ { "id": "trim_vout_adc_offset_1", "value": "0" } ] }, { "id": "BUCK1_TRIM_REG_5", "value": "0", "fields": [ { "id": "trim_vout_adc_ptat_1", "value": "0" } ] }, { "id": "BUCK1_TRIM_REG_6", "value": "0", "fields": [ { "id": "trim_emu_ramp_1", "value": "0" } ] }, { "id": "BUCK1_TRIM_REG_7", "value": "0", "fields": [ { "id": "trim_artif_ramp_1", "value": "0" } ] }, { "id": "BUCK1_TRIM_REG_8", "value": "0", "fields": [ { "id": "trim_hs_replica_1", "value": "0" } ] }, { "id": "BUCK1_TRIM_REG_9", "value": "0", "fields": [ { "id": "trim_ls_replica_1", "value": "0" } ] }, { "id": "BUCK1_TRIM_REG_10", "value": "0", "fields": [ { "id": "trim_fb_gain_stage_offset_1", "value": "0" } ] }, { "id": "BUCK1_TRIM_REG_11", "value": "0", "fields": [ { "id": "trim_integ_dac_gain_1", "value": "0" } ] }, { "id": "BUCK1_TRIM_REG_12", "value": "0", "fields": [ { "id": "trim_slope_1", "value": "0" } ] }, { "id": "BUCK1_TRIM_REG_13", "value": "0", "fields": [ { "id": "trim_spare_1", "value": "0" } ] }, { "id": "BUCK2_TRIM_REG_0", "value": "0", "fields": [ { "id": "trim_vref_dac_2", "value": "0" } ] }, { "id": "BUCK2_TRIM_REG_1", "value": "0", "fields": [ { "id": "trim_level_shift_gain_2", "value": "0" } ] }, { "id": "BUCK2_TRIM_REG_2", "value": "0", "fields": [ { "id": "trim_loop_comp_2", "value": "0" } ] }, { "id": "BUCK2_TRIM_REG_3", "value": "0", "fields": [ { "id": "trim_vout_adc_gain_2", "value": "0" } ] }, { "id": "BUCK2_TRIM_REG_4", "value": "0", "fields": [ { "id": "trim_vout_adc_offset_2", "value": "0" } ] }, { "id": "BUCK2_TRIM_REG_5", "value": "0", "fields": [ { "id": "trim_vout_adc_ptat_2", "value": "0" } ] }, { "id": "BUCK2_TRIM_REG_6", "value": "0", "fields": [ { "id": "trim_emu_ramp_2", "value": "0" } ] }, { "id": "BUCK2_TRIM_REG_7", "value": "0", "fields": [ { "id": "trim_artif_ramp_2", "value": "0" } ] }, { "id": "BUCK2_TRIM_REG_8", "value": "0", "fields": [ { "id": "trim_hs_replica_2", "value": "0" } ] }, { "id": "BUCK2_TRIM_REG_9", "value": "0", "fields": [ { "id": "trim_ls_replica_2", "value": "0" } ] }, { "id": "BUCK2_TRIM_REG_10", "value": "0", "fields": [ { "id": "trim_fb_gain_stage_offset_2", "value": "0" } ] }, { "id": "BUCK2_TRIM_REG_11", "value": "0", "fields": [ { "id": "trim_integ_dac_gain_2", "value": "0" } ] }, { "id": "BUCK2_TRIM_REG_12", "value": "0", "fields": [ { "id": "trim_slope_2", "value": "0" } ] }, { "id": "BUCK2_TRIM_REG_13", "value": "0", "fields": [ { "id": "trim_spare_2", "value": "0" } ] }, { "id": "BUCK3_TRIM_REG_0", "value": "0", "fields": [ { "id": "trim_vref_dac_3", "value": "0" } ] }, { "id": "BUCK3_TRIM_REG_1", "value": "0", "fields": [ { "id": "trim_level_shift_gain_3", "value": "0" } ] }, { "id": "BUCK3_TRIM_REG_2", "value": "0", "fields": [ { "id": "trim_loop_comp_3", "value": "0" } ] }, { "id": "BUCK3_TRIM_REG_3", "value": "0", "fields": [ { "id": "trim_vout_adc_gain_3", "value": "0" } ] }, { "id": "BUCK3_TRIM_REG_4", "value": "0", "fields": [ { "id": "trim_vout_adc_offset_3", "value": "0" } ] }, { "id": "BUCK3_TRIM_REG_5", "value": "0", "fields": [ { "id": "trim_vout_adc_ptat_3", "value": "0" } ] }, { "id": "BUCK3_TRIM_REG_6", "value": "0", "fields": [ { "id": "trim_emu_ramp_3", "value": "0" } ] }, { "id": "BUCK3_TRIM_REG_7", "value": "0", "fields": [ { "id": "trim_artif_ramp_3", "value": "0" } ] }, { "id": "BUCK3_TRIM_REG_8", "value": "0", "fields": [ { "id": "trim_hs_replica_3", "value": "0" } ] }, { "id": "BUCK3_TRIM_REG_9", "value": "0", "fields": [ { "id": "trim_ls_replica_3", "value": "0" } ] }, { "id": "BUCK3_TRIM_REG_10", "value": "0", "fields": [ { "id": "trim_fb_gain_stage_offset_3", "value": "0" } ] }, { "id": "BUCK3_TRIM_REG_11", "value": "0", "fields": [ { "id": "trim_integ_dac_gain_3", "value": "0" } ] }, { "id": "BUCK3_TRIM_REG_12", "value": "0", "fields": [ { "id": "trim_slope_3", "value": "0" } ] }, { "id": "BUCK3_TRIM_REG_13", "value": "0", "fields": [ { "id": "trim_spare_3", "value": "0" } ] }, { "id": "BUCK4_TRIM_REG_0", "value": "0", "fields": [ { "id": "trim_vref_dac_4", "value": "0" } ] }, { "id": "BUCK4_TRIM_REG_1", "value": "0", "fields": [ { "id": "trim_level_shift_gain_4", "value": "0" } ] }, { "id": "BUCK4_TRIM_REG_2", "value": "0", "fields": [ { "id": "trim_loop_comp_4", "value": "0" } ] }, { "id": "BUCK4_TRIM_REG_3", "value": "0", "fields": [ { "id": "trim_vout_adc_gain_4", "value": "0" } ] }, { "id": "BUCK4_TRIM_REG_4", "value": "0", "fields": [ { "id": "trim_vout_adc_offset_4", "value": "0" } ] }, { "id": "BUCK4_TRIM_REG_5", "value": "0", "fields": [ { "id": "trim_vout_adc_ptat_4", "value": "0" } ] }, { "id": "BUCK4_TRIM_REG_6", "value": "0", "fields": [ { "id": "trim_emu_ramp_4", "value": "0" } ] }, { "id": "BUCK4_TRIM_REG_7", "value": "0", "fields": [ { "id": "trim_artif_ramp_4", "value": "0" } ] }, { "id": "BUCK4_TRIM_REG_8", "value": "0", "fields": [ { "id": "trim_hs_replica_4", "value": "0" } ] }, { "id": "BUCK4_TRIM_REG_9", "value": "0", "fields": [ { "id": "trim_ls_replica_4", "value": "0" } ] }, { "id": "BUCK4_TRIM_REG_10", "value": "0", "fields": [ { "id": "trim_fb_gain_stage_offset_4", "value": "0" } ] }, { "id": "BUCK4_TRIM_REG_11", "value": "0", "fields": [ { "id": "trim_integ_dac_gain_4", "value": "0" } ] }, { "id": "BUCK4_TRIM_REG_12", "value": "0", "fields": [ { "id": "trim_slope_4", "value": "0" } ] }, { "id": "BUCK4_TRIM_REG_13", "value": "0", "fields": [ { "id": "trim_spare_4", "value": "0" } ] }, { "id": "BUCK5_TRIM_REG_0", "value": "0", "fields": [ { "id": "trim_vref_dac_5", "value": "0" } ] }, { "id": "BUCK5_TRIM_REG_1", "value": "0", "fields": [ { "id": "trim_level_shift_gain_5", "value": "0" } ] }, { "id": "BUCK5_TRIM_REG_2", "value": "0", "fields": [ { "id": "trim_loop_comp_5", "value": "0" } ] }, { "id": "BUCK5_TRIM_REG_3", "value": "0", "fields": [ { "id": "trim_vout_adc_gain_5", "value": "0" } ] }, { "id": "BUCK5_TRIM_REG_4", "value": "0", "fields": [ { "id": "trim_vout_adc_offset_5", "value": "0" } ] }, { "id": "BUCK5_TRIM_REG_5", "value": "0", "fields": [ { "id": "trim_vout_adc_ptat_5", "value": "0" } ] }, { "id": "BUCK5_TRIM_REG_6", "value": "0", "fields": [ { "id": "trim_emu_ramp_5", "value": "0" } ] }, { "id": "BUCK5_TRIM_REG_7", "value": "0", "fields": [ { "id": "trim_artif_ramp_5", "value": "0" } ] }, { "id": "BUCK5_TRIM_REG_8", "value": "0", "fields": [ { "id": "trim_hs_replica_5", "value": "0" } ] }, { "id": "BUCK5_TRIM_REG_9", "value": "0", "fields": [ { "id": "trim_ls_replica_5", "value": "0" } ] }, { "id": "BUCK5_TRIM_REG_10", "value": "0", "fields": [ { "id": "trim_fb_gain_stage_offset_5", "value": "0" } ] }, { "id": "BUCK5_TRIM_REG_11", "value": "0", "fields": [ { "id": "trim_integ_dac_gain_5", "value": "0" } ] }, { "id": "BUCK5_TRIM_REG_12", "value": "0", "fields": [ { "id": "trim_slope_5", "value": "0" } ] }, { "id": "BUCK5_TRIM_REG_13", "value": "0", "fields": [ { "id": "trim_spare_5", "value": "0" } ] } ] }, { "id": "WatchDogRegisters-user_mem", "registers": [ { "id": "WD_ANSWER_REG", "value": "0", "fields": [ { "id": "WD_ANSWER", "value": "0" } ] }, { "id": "WD_QUESTION_ANSW_CNT", "value": "0", "fields": [ { "id": "WD_QUESTION", "value": "0" }, { "id": "WD_ANSW_CNT", "value": "0" } ] }, { "id": "WD_WIN1_CFG", "value": "0", "fields": [ { "id": "WD_WIN1", "value": "0" } ] }, { "id": "WD_WIN2_CFG", "value": "0", "fields": [ { "id": "WD_WIN2", "value": "0" } ] }, { "id": "WD_LONGWIN_CFG", "value": "0", "fields": [ { "id": "WD_LONGWIN", "value": "0" } ] }, { "id": "WD_MODE_REG", "value": "0", "fields": [ { "id": "WD_PWRHOLD", "value": "0" }, { "id": "WD_MODE_SELECT", "value": "0" }, { "id": "WD_RETURN_LONGWIN", "value": "0" } ] }, { "id": "WD_QA_CFG", "value": "0", "fields": [ { "id": "WD_QA_FDBK", "value": "0" }, { "id": "WD_QA_LFSR", "value": "0" }, { "id": "WD_QUESTION_SEED", "value": "0" } ] }, { "id": "WD_ERR_STATUS", "value": "0", "fields": [ { "id": "WD_ANSW_EARLY", "value": "0" }, { "id": "WD_TIMEOUT", "value": "0" }, { "id": "WD_SEQ_ERR", "value": "0" }, { "id": "WD_LONGWIN_TIMEOUT_INT", "value": "0" }, { "id": "WD_ANSW_ERR", "value": "0" }, { "id": "WD_TRIG_EARLY", "value": "0" }, { "id": "WD_RST_INT", "value": "0" }, { "id": "WD_FAIL_INT", "value": "0" } ] }, { "id": "WD_THR_CFG", "value": "0", "fields": [ { "id": "WD_EN", "value": "0", "staticConfig": false }, { "id": "WD_RST_EN", "value": 1, "staticConfig": true }, { "id": "WD_FAIL_TH", "value": 7, "staticConfig": true }, { "id": "WD_RST_TH", "value": 7, "staticConfig": true } ] }, { "id": "WD_FAIL_CNT_REG", "value": "0", "fields": [ { "id": "WD_FAIL_CNT", "value": "0" }, { "id": "WD_FIRST_OK", "value": "0" }, { "id": "WD_BAD_EVENT", "value": "0" } ] } ] } ] } } ] }, { "name": "TPS6593x_2p0", "devices": [] }, { "name": "LP8764x", "devices": [] } ], "fsmConfig": { "states": [ { "id": 0, "title": "ACTIVE", "x": 248.80233764648438, "y": 100, "isHardwareState": false, "isUserDefinedState": true }, { "id": 1, "title": "STANDBY", "x": 250, "y": 300, "mandatoryState": true, "isHardwareState": false, "isUserDefinedState": true } ], "transitions": [ { "source": { "id": 0, "title": "ACTIVE", "x": 248.80233764648438, "y": 100, "isHardwareState": false, "isUserDefinedState": true }, "target": { "id": 1, "title": "STANDBY", "x": 250, "y": 300, "mandatoryState": true, "isHardwareState": false, "isUserDefinedState": true }, "order": 1, "label": "", "priority": 0, "triggers": [] }, { "source": { "id": 1, "title": "STANDBY", "x": 250, "y": 300, "mandatoryState": true, "isHardwareState": false, "isUserDefinedState": true }, "target": { "id": 0, "title": "ACTIVE", "x": 248.80233764648438, "y": 100, "isHardwareState": false, "isUserDefinedState": true }, "order": 2, "label": "", "priority": 0, "triggers": [ { "id": 0 } ] } ], "triggers": [ { "trigger": { "trigSel": 12, "name": "SU_ACTIVE" }, "type": "HIGH", "isImmediate": true, "isEXT": false, "isReentrant": false, "devices": [ "TPS65940" ], "sequence": { "id": 0 }, "id": 0 } ], "triggerPriorityList": [ { "transition": [ { "source": "STANDBY", "target": "ACTIVE", "priority": 0 } ], "triggerBase": { "id": 0 } } ], "globalSequences": [ { "name": "any2active", "id": 0, "sequences": [ { "command": { "name": "LDO2", "registerName": "LDO2_CTRL", "selectedFields": [ "LDO2_EN" ], "register": { "id": "LDO2_CTRL", "name": "LDO2_CTRL", "desc": "", "anchor": "", "addr": "0x1e", "mode": "", "size": "8", "default": "0", "value": 1, "fields": [ { "id": "LDO2_EN", "helpTag": "", "name": "LDO2_EN", "desc": "Enable LDO2 regulator:\r\n(Default from NVM memory)", "anchor": "", "mode": "RW", "start": "0", "stop": "0", "value": 1, "attrs": { "isHidden": "0", "isReserved": "0", "isLocked": "0" }, "options": [ { "display": "Disabled; LDO2 regulator.", "value": 0 }, { "display": "Enabled; LDO2 regulator.", "value": 1 } ], "maskOptions": [ { "type": "Unchanged", "value": "mask" }, { "type": "HIGH", "value": 1 }, { "type": "LOW", "value": 0 } ] }, { "id": "LDO2_PLDN", "helpTag": "", "name": "LDO2_PLDN", "desc": "Enable output pull-down resistor when LDO2 is disabled:\r\n(Default from NVM memory)", "anchor": "", "mode": "RW", "start": "5", "stop": "6", "value": "mask", "attrs": { "isHidden": "0", "isReserved": "0", "isLocked": "0" }, "options": [ { "display": "50 kOhm", "value": 0 }, { "display": "125 Ohm", "value": 1 }, { "display": "250 Ohm", "value": 2 }, { "display": "500 Ohm\r\n", "value": 3 } ], "maskOptions": [ { "type": "Unchanged", "value": "mask" }, { "type": "50 kOhm", "value": 0 }, { "type": "125 Ohm", "value": 1 }, { "type": "250 Ohm", "value": 2 }, { "type": "500 Ohm\r\n", "value": 3 } ] }, { "id": "LDO2_VMON_EN", "helpTag": "", "name": "LDO2_VMON_EN", "desc": "Enable LDO2 OV and UV comparators:\r\n(Default from NVM memory)", "anchor": "", "mode": "RW", "start": "4", "stop": "4", "value": "mask", "attrs": { "isHidden": "0", "isReserved": "0", "isLocked": "0" }, "options": [ { "display": "Disabled; OV and UV comparators.", "value": 0 }, { "display": "Enabled; OV and UV comparators.", "value": 1 } ], "maskOptions": [ { "type": "Unchanged", "value": "mask" }, { "type": "HIGH", "value": 1 }, { "type": "LOW", "value": 0 } ] }, { "id": "LDO2_RV_SEL", "helpTag": "", "name": "LDO2_RV_SEL", "desc": "Select residual voltage checking for LDO2 output pin.\r\n(Default from NVM memory)", "anchor": "", "mode": "RW", "start": "7", "stop": "7", "value": "mask", "attrs": { "isHidden": "0", "isReserved": "0", "isLocked": "0" }, "options": [ { "display": "Disabled", "value": 0 }, { "display": "Enabled", "value": 1 } ], "maskOptions": [ { "type": "Unchanged", "value": "mask" }, { "type": "HIGH", "value": 1 }, { "type": "LOW", "value": 0 } ] }, { "id": "LDO2_SLOW_RAMP", "helpTag": "", "name": "LDO2_SLOW_RAMP", "desc": "LDO2 startup slew rate selection", "anchor": "", "mode": "RW", "start": "1", "stop": "1", "value": "mask", "attrs": { "isHidden": "0", "isReserved": "0", "isLocked": "0" }, "options": [ { "display": "25mV/us max ramp up slew rate for LDO output from 0.3V to 90% of LDOn_VSET", "value": 0 }, { "display": "3mV/us max ramp up slew rate for LDO output from 0.3V to 90% of LDOn_VSET", "value": 1 } ], "maskOptions": [ { "type": "Unchanged", "value": "mask" }, { "type": "HIGH", "value": 1 }, { "type": "LOW", "value": 0 } ] } ], "mask": 254 } }, "visible": true, "name": "Rail1", "delay": 0, "delayUnit": "us", "timeout": 0, "timeoutUnit": "us", "waitCondition": { "condSel": 0, "condName": "GPIO1" }, "conditionType": "LOW", "delayMode": "ALWAYS", "resourceControl": "VOUT", "resourceControlSelect": 0, "scratchRegister": "R0", "bypass": false, "outputVoltageUnit": "V", "outputVoltage": "1.2", "voltageTarget": "VSEL1", "scratchAddress": null, "scratchMask": null, "subSequence": null, "calculatedDelay": 0, "isSubRoutineAction": false, "sequences": [], "destination": null, "vccaVmon": "unchanged", "clkmon": "unchanged", "amuxout": "unchanged", "buckCtrlResetReg": null, "enableDRV": 0, "deviceAlias": "TPS65940", "trigMask": { "value": null, "unmaskTriggerList": [] } }, { "command": { "name": "LDO3", "registerName": "LDO3_CTRL", "selectedFields": [ "LDO3_EN" ], "visibility": true, "showInSeq": true, "register": { "id": "LDO3_CTRL", "name": "LDO3_CTRL", "desc": "", "anchor": "", "addr": "0x1f", "mode": "", "size": "8", "default": "0", "value": 1, "fields": [ { "id": "LDO3_EN", "helpTag": "", "name": "LDO3_EN", "desc": "Enable LDO3 regulator:\r\n(Default from NVM memory)", "anchor": "", "mode": "RW", "start": "0", "stop": "0", "value": 1, "attrs": { "isHidden": "0", "isReserved": "0", "isLocked": "0" }, "options": [ { "display": "Disabled; LDO3 regulator.", "value": 0 }, { "display": "Enabled; LDO3 regulator.", "value": 1 } ], "maskOptions": [ { "type": "Unchanged", "value": "mask" }, { "type": "HIGH", "value": 1 }, { "type": "LOW", "value": 0 } ] }, { "id": "LDO3_PLDN", "helpTag": "", "name": "LDO3_PLDN", "desc": "Enable output pull-down resistor when LDO3 is disabled:\r\n(Default from NVM memory)", "anchor": "", "mode": "RW", "start": "5", "stop": "6", "value": "mask", "attrs": { "isHidden": "0", "isReserved": "0", "isLocked": "0" }, "options": [ { "display": "50 kOhm", "value": 0 }, { "display": "125 Ohm", "value": 1 }, { "display": "250 Ohm", "value": 2 }, { "display": "500 Ohm\r\n", "value": 3 } ], "maskOptions": [ { "type": "Unchanged", "value": "mask" }, { "type": "50 kOhm", "value": 0 }, { "type": "125 Ohm", "value": 1 }, { "type": "250 Ohm", "value": 2 }, { "type": "500 Ohm\r\n", "value": 3 } ] }, { "id": "LDO3_VMON_EN", "helpTag": "", "name": "LDO3_VMON_EN", "desc": "Enable LDO3 OV and UV comparators:\r\n(Default from NVM memory)", "anchor": "", "mode": "RW", "start": "4", "stop": "4", "value": "mask", "attrs": { "isHidden": "0", "isReserved": "0", "isLocked": "0" }, "options": [ { "display": "Disabled; OV and UV comparators.", "value": 0 }, { "display": "Enabled; OV and UV comparators.", "value": 1 } ], "maskOptions": [ { "type": "Unchanged", "value": "mask" }, { "type": "HIGH", "value": 1 }, { "type": "LOW", "value": 0 } ] }, { "id": "LDO3_RV_SEL", "helpTag": "", "name": "LDO3_RV_SEL", "desc": "Select residual voltage checking for LDO3 output pin.\r\n(Default from NVM memory)", "anchor": "", "mode": "RW", "start": "7", "stop": "7", "value": "mask", "attrs": { "isHidden": "0", "isReserved": "0", "isLocked": "0" }, "options": [ { "display": "Disabled", "value": 0 }, { "display": "Enabled", "value": 1 } ], "maskOptions": [ { "type": "Unchanged", "value": "mask" }, { "type": "HIGH", "value": 1 }, { "type": "LOW", "value": 0 } ] }, { "id": "LDO3_SLOW_RAMP", "helpTag": "", "name": "LDO3_SLOW_RAMP", "desc": "LDO3 startup slew rate selection", "anchor": "", "mode": "RW", "start": "1", "stop": "1", "value": "mask", "attrs": { "isHidden": "0", "isReserved": "0", "isLocked": "0" }, "options": [ { "display": "25mV/us max ramp up slew rate for LDO output from 0.3V to 90% of LDOn_VSET", "value": 0 }, { "display": "3mV/us max ramp up slew rate for LDO output from 0.3V to 90% of LDOn_VSET", "value": 1 } ], "maskOptions": [ { "type": "Unchanged", "value": "mask" }, { "type": "HIGH", "value": 1 }, { "type": "LOW", "value": 0 } ] } ], "mask": 254 } }, "visible": true, "name": "Rail2", "delay": "100", "delayUnit": "ms", "timeout": 0, "timeoutUnit": "us", "waitCondition": { "condSel": 0, "condName": "GPIO1" }, "conditionType": "LOW", "delayMode": "ALWAYS", "resourceControl": "VOUT", "resourceControlSelect": 0, "scratchRegister": "R0", "bypass": false, "outputVoltageUnit": "V", "outputVoltage": "1.8", "voltageTarget": "VSEL1", "scratchAddress": null, "scratchMask": null, "subSequence": null, "calculatedDelay": 100, "isSubRoutineAction": false, "sequences": [], "destination": null, "vccaVmon": "unchanged", "clkmon": "unchanged", "amuxout": "unchanged", "buckCtrlResetReg": null, "enableDRV": 0, "selectedTimeoutUnit": "us", "deviceAlias": "TPS65940", "trigMask": { "value": null, "unmaskTriggerList": [] } }, { "command": { "name": "TRIG_MASK", "visibility": true, "showInSeq": false }, "visible": false, "name": "", "delay": 0, "delayUnit": "us", "timeout": 0, "timeoutUnit": "us", "waitCondition": { "condSel": 0, "condName": "GPIO1" }, "conditionType": "LOW", "delayMode": "ALWAYS", "resourceControl": "VCTRL", "resourceControlSelect": 0, "scratchRegister": null, "bypass": false, "outputVoltageUnit": "V", "outputVoltage": 0, "voltageTarget": "VSEL1", "scratchAddress": null, "scratchMask": null, "subSequence": null, "calculatedDelay": 100000, "isSubRoutineAction": false, "sequences": [], "destination": null, "vccaVmon": "unchanged", "clkmon": "unchanged", "amuxout": "unchanged", "buckCtrlResetReg": null, "enableDRV": 0, "deviceAlias": "TPS65940", "trigMask": { "value": null, "unmaskTriggerList": [] } } ], "targetState": { "id": 0, "title": "ACTIVE", "x": 248.80233764648438, "y": 100, "isHardwareState": false, "isUserDefinedState": true }, "subRoutineList": [], "sequenceType": "others" } ], "pfsmGlobalDelay": 102.4, "autoShuffle": true, "overridenStandbyReadyTrigMask": null, "startState": { "id": 0, "title": "ACTIVE", "x": 248.80233764648438, "y": 100, "isHardwareState": false, "isUserDefinedState": true } } } }
Hi Xiaofu,
The TPS65941111EVM was factory pre-programmed for a 4+1 phase configuration. By design, it should work with TPS65941212EVM or TPS65941213EVM together. Please check its user guide for more details.
The TPS65941111EVM has its own PFSM configuration through its factory pre-programmed. It should need no more PFSM configuration if it works with TPS65941212EVM or TPS65941213EVM.
I'm wondering where you get the PFSM configuration above.
Thanks!
Phil
