TPS74801 shared outputs
Other Parts Discussed in Thread: TPS74801, TPS74901
If multiple TPS74801 are connected in parallel, can the outputs be shared?
  • Since each IC has its own internal reference voltage that it is trying to regulate to, there is no guarantee of current sharing.
    This app note shows how to get them to current share: http://focus.ti.com/lit/an/slva250/slva250.pdf
    Hi Luke,
    And based on my reading of that article, it seems to me that current sharing is poor at best though usable in some circumstances.  The article recommends adding ballast resistors to each output.  As to your original question, without the ballast resistors, one of the two regulators will end up biasing off the other due to the slight part to part differences in reference voltage.
    Bill
  • Hi Luke,
    If you simply need higher current, we have the TPS74901 which can support up to 3A. If you concern is thermal, are you just trying to spread the heat? Also, for these higher currents, I am curious to understand why you would prefer an LDO over a switcher.
    John Cummings
    Strategic Marketing Manager
    High Power Linear
