Other Parts Discussed in Thread: TPS3850, , TPS35, TPS36
Hi team,
I would like to know if I can disable lower boundary of watchdog timer in TPS3850 to use it as simple Time out type watchdog.
Is that possible?
regards,
Hi team,
Is that possible?
regards,
Hello Shinji-san,
TPS3850-Q1 does not support this feature.
Also, does the customer want to change the type of watchdog on the fly using a pin or he wants to use window watchdog in one variant of application and time out watchdog in another.
We are working on TPS35 and TPS36 family of supervisor + WD family device which offer pin compatible devices with time out and window watchdog devices respectively.
Will this work?
Thanks and Regards,
Shridhar
Hi Shridhar-san,
Thank you. I just found this device and it looks it meets my requirement.
regards,
