TPS1HC30-Q1: Current Limit Occurs Every Startup
Guru 12175 points
Part Number: TPS1HC30-Q1
Since the inrush current exceeds 10A for a short time, the current limit always works when the power is turned on.
Is there any problem with this operation if the system power start-up delay due to current limit is acceptable? The current limit is planned to be around 4A.
Astro
