Other Parts Discussed in Thread: TPS61193Q1EVM
Hi team,
Do we have a data of the delay from PWM signal to LED current?
It means T1 and T2 in the below figure.
Saito
Hi team,
Saito
Hi Saito-san,
We don't have such data for TPS61193-Q1. Could you pls tell me which customer is caring about this spec and why?
BR, Gracie
Hi Gracie-san,
Customer is measuring the delay between PWM signal and the current. They wants to know if the delay value is correct or not. That's why they are asking the delay. They don't need the exact value of the delay, but is it possible to check the rough value of the delay like micro second order?
Saito
OK, I will test this data for you. Unfortunately I don't have a TPS61193Q1EVM right now. Maybe need a little more time.
BR, Gracie
Hi Saito-san,
Sorry about replying late. I set PWM as 50% duty 10kHz and 20KHz. The tdelay is about 550ns.
BR, Gracie
