LM5032: some question about LM5032 APPLICATION
Part Number: LM5032
When I use your product LM5032 in interleaved boost circuit, I meet some question. In my application, I connect two loop COMP signal together, I find that there are big difference between the duty cycle of two loop output(we change two lm5032,the test result is same, CS1,CS2 are below 0.5V ), the attached file is one video, that show two loop output signals when I adjust comp voltage.I want to know the difference is reasonable or there are some wrong with the LM5032 that I bought.
