I would like to check which is correct? Seems it different in below figure.
Thanks!
Jeff
Thanks!
Jeff
Hi Jeff,
SPI_POCI (SPI_MISO) should be pin 36 and SPI_PICO (SPI_MOSI) should be pin 37.
The "input" in the 4th column indicates the state of the pin in the reset state (Reset State indicates the state of a given pin immediately following power application, prior to any configuration from firmware).
Thank you for bringing this to our attention, I'll bring this up with my team to get this fix!
Thanks and Regards,
Raymond Lin
