TPS54360B: Regarding External Resistor to EN Pin
Part Number: TPS54360B
I am an FAE for a distributor that handles TI products.
I received the following question from my customer.
The datasheet shows the circuit below for the Undervoltage Lockout feature using the EN pin.
However, I made a mistake with another device I was designing and added a hysteresis resistor between the wiring between RUVLO1 and RUVLO2 and the EN pin(red square in the figure below).
(Question)
Is there any problem with such usage?
If there is no problem, are VSTART and VSTOP correct according to the following formula?
