I read the TI fuel gauge guide and found it very helpful. However, there is also a question. The battery pack has many strings of cells. Which string do we use when calculating the FCC? Hope to answer, thanks
I'm not sure I fully understand your question, if you mean you have multiple parallel cells, like a 4S3P pack for example, the FCC should be close to 3 * DesignCapacity.
Sincerely,
Wyatt Keller
