TPS659037: TPS6590379
Part Number: TPS659037
Other Parts Discussed in Thread: AM5728, TPD12S015
Dear Sir,,
We are using AM5728 + TPS6590378 PIMC. However, it was changed to TPS6590379 PMIC due to difficult supply of TPS6590378. The power system was designed with reference to the reference document. However, while booting Linux, an error occurs like the attached content.
After changing the TPS6590378 PMIC to TPS6590379, is there anything I need to fix in Linux ?
[ error message ] -> In case of AM5728 + TPS6590379 PMIC system configuration
[ 0.004484] /cpus/cpu@0 missing clock-frequency property
[ 0.004512] /cpus/cpu@1 missing clock-frequency property
[ 1.005122] smps8: failed to apply 1800000-1800000uV constraint(-22)
[ 1.005146] palmas-pmic 48070000.i2c:tps659038@58:tps659038_pmic: failed to register 48070000.i2c:tps659038@58:tps659038_pmic regulator
[ 2.264190] dra7-pcie 51000000.pcie: phy link never came up
[ 2.321282] tpd12s015 encoder: failed to find video source
[ 2.327562] connector-hdmi connector: failed to find video source
[ 2.542948] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
[ 2.549405] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
[ 2.572871] tlv320aic3x-codec 0-0018: Failed to get supply 'IOVDD': -517
[ 2.579701] tlv320aic3x-codec 0-0018: Failed to request supplies: -517
[ 2.591530] omap_voltage_late_init: Voltage driver support not added
[ 2.636792] tpd12s015 encoder: failed to find video source
[ 2.642813] connector-hdmi connector: failed to find video source
[ 2.654811] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
[ 2.661296] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
[ 2.668663] tlv320aic3x-codec 0-0018: Failed to get supply 'IOVDD': -517
[ 2.675489] tlv320aic3x-codec 0-0018: Failed to request supplies: -517
[ 2.684949] tpd12s015 encoder: failed to find video source
[ 2.690982] connector-hdmi connector: failed to find video source
Please let us know if there is anything we need to review further.
I will wait for your kind reply
[ message ] -> In case of AM5728 + TPS6590378 PMIC system configuration (OK)
[ 0.004470] /cpus/cpu@0 missing clock-frequency property
[ 0.004498] /cpus/cpu@1 missing clock-frequency property
[ 2.299845] dra7-pcie 51000000.pcie: phy link never came up
[ 2.565003] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr104 mode
[ 2.571514] omap_hsmmc 4809c000.mmc: no pinctrl state for ddr50 mode
[ 2.577927] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr50 mode
[ 2.584337] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr25 mode
[ 2.591052] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr12 mode
[ 2.597467] omap_hsmmc 4809c000.mmc: no pinctrl state for hs mode
[ 2.648429] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
[ 2.654864] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
[ 2.661291] omap_hsmmc 480b4000.mmc: no pinctrl state for ddr_1_8v mode
[ 2.668004] omap_hsmmc 480b4000.mmc: no pinctrl state for hs mode
[ 2.736235] omap_voltage_late_init: Voltage driver support not added
[FAILED] Failed to start cmemk kernel modules.
See 'systemctl status cmemk-module.service' for details.
