BQ25100: Battery Charger TS Pin Input Impedance
Part Number: BQ25100
Hello, I would need to know whether pin TS is a high impedance node looking into it such that I can also route the thermistor terminals to a fuel gauge which also uses this thermistor. Both the BQ25100YFPR and the FG would be simultaneously connected to the thermistor. If both parts present a high impedance, then it should work.
Thank you.
