TPS40060: TPS40060 dead time and pmos choice
Part Number: TPS40060
Hi, team:
    When my customer test TPS40060 found out the the output signal abnormal:
    The green: PMOS ; The blue: NMOS
    It look like mos go-through due to too long Ton.
    I couldn’t find description about dead time in datasheet and requirement about PMOS.
    Could you kindly help analysis this issue and give more detail about TPS40060 dead-time
   In addition, when My customer choice si746dp(PMOS) and resistance use 4.7Ω;
  • Hello Hailey
    The typical value is 50ns based on equation 53, but it looks like the parameter hasn't been characterized.
    If you are using a gate resistor on the high-side, please try to retest after shorting the resistor.
    - Eric Lee
