PMU for DM8147
Other Parts Discussed in Thread: TPS51220
I am working on a new design with DM8147. The recommended PMU is TPS659113.
I have a 3S/3P 7200mAh pack with cut off of 9V. 15VIN for my current charging solution.
This makes the 5.5 Vin limit of TPS659113 a problem. When I look at other parts like TPS65232
they have a min VIN of 10.8V, a problem as well. I have other high power parts like Xilinx S6
and so I am trying to piece togeather a power solution using TI options (so I can take advantage
of DVS on the DM8147). I have not found good solution on the TI web so far. Can you suggest one?
Patrick
