could you advise an alternative to MAX1606?
Please attach a datasheet whenever you need a cross. Also, specify whether you need a pin to pin or functional cross.
This seems to be a fairly generic boost converter, so without additional requirements, I would direct you to the parametric search at power.ti.com. If you need the isolation switch, you could look at the TPS61093 or the TPS61080/1.
Chris, thank you very much for the answer.
the datasheet link is here: http://www.maxim-ic.com/datasheet/index.mvp/id/2312
We're trying to look into the TPS61080/1
