First, let me thank you for an exciting and impressive roll-out.
1) The 5W Qi standard is the going trend now, and this is good. But if I designed my own transmitter, (not using your impressive chip), and placed a Qi receiver on it, as long as my design complied with the standard, they *should* work together, right?
2) More specifically, if I run to Best Buy or Target and purchase a Qi-Compliant Energizer charging pad, and then lay the bq51013EVM-725 Evaluation Module right on top of it, wouldn't I see that little LED come up, indicating functionality?
I ask that 2nd question, because I think it all comes down to that. If I design around your receiver, My customers can use most any Q-Compliant transmitter. I expect these chargers to be "ubi-Qi-tous".
It would be fun to know whether you have tried that Energizer idea on your own yet.
3) It looks like I still have to add my own little charger to the output of the bq51013EVM-725 Evaluation Module, right?
4) I am not seeking a recommendation here, but if you know about any other commercially available Qi-Compliant chargers, it would help us buy them to confirm interoperability.
Thanks again for all you do.
Yours truly
Michael A. Banak
http://eclectic-engineering.net
